Battery issue or wrong calculation
Today at 27F I drove 60 miles. I started with 70% SOC.
The car showed 2.1 Miles/Kwh avg consumption for the trip (screenshot below).
that means 60 miles / 2.1 = 28.57 Kw of energy should've been consumed.
Again I started at 70 % means (86.5 *.7 = ) 60.55 Kw in tank to start with.
So at the end of the trip I should end up with (60.55 - 28.57 = ) 31.98 kw. Which is (31.98 / 86.5 = ) .36 or 36% SOC at destination.
Guess what. my SOC at destination is 28 %. -- that's a almost 7 Kw difference which is about a tenth of the usable battery pack.
So either 2.1 miles/kwh consumption is not accurate or there is a battery defect/degradation which is causing battery to lose juice beyond consumption.
Thoughts? Am I doing it wrong?
let’s see if myself or someone else could retest the same in a warmer climate.
also what temperature range you suggest is optimum for battery performance?
Battery packs having issues isn't unheard of. As others have said, the cold temp might reduce your range, but you should be able to track kWh into and out of the battery like you said and really see what's going on. I would suggest charging to 100% and discharging (by driving) to around 10%. Then charge back up to 100% with a charger that allows you to track energy into the battery. If everything makes sense, then you should be good. Being out of whack by 7kWh overall is a lot and probably not normal.
Also, if you have an issue with your battery (i.e. bank of cells is out), you will notice sub-optimal charging speed when using a DCFC (i.e. when you get to 80% you will be below 50 kW) and / or you might have an issue under max acceleration where you get a power cut off if you have boost enabled in sport mode.
Did you pre-condition the battery whilst plugged into your charger as well as warming up the interior and seats prior to driving off?
What temperature was the cabin set to during your drive?
How high were the seat warmers set to and how many seats were being heated?
What speeds were you driving at?
Over 11,126 miles my average energy consumption is 2.3 mi/kWh. The summer I’m getting around 2.7 mi/kWh but in the winter I’m lucky to get around 2.0 mi/kWh during my daily drive to/from work, and the above is with pre-conditioning.
I don't believe what you suggested about other variables is entirely true though. The cabin temp and seat warmer should've been built into avg consumption. that's why (as you pointed out too) we get 2.7 m/kw in summer but 2.1 in winter. I was still basing my calculation on avg consumption which takes into account the consumption by those variables.
But again 7 KWs (around 10 % of total usable battery pack) is too big of a discrepancy.
