Audi Original "S" Cars Discussion forum for the Audi Audi Ur S4, Ur S6, S2 & RS2
HELP! BOOST LEAK BIG TIME
Old Jan 1, 2004 | 09:25 AM
Skunns256's Avatar
New Member
Default HELP! BOOST LEAK BIG TIME
Every time i bring the RPMS around 4500 my turbo just cuts out and I lose all boost. This is then followed by the check engine light temporarily coming on and then going off again. I have no idea what to look for. Please help.
Old Jan 1, 2004 | 10:20 AM
s4master1's Avatar
Default where are you located?
i can help
Old Jan 1, 2004 | 05:15 PM
UrS4boy's Avatar
Tech Guru
Default This sounds suspiciously like at TAP wastegate spring-induced overboost problem. You need to...
Pull the codes (search the archives or go to SJM's audi website to find out how) and/or go to someone with the proper VAG tool to read the codes. That will be the start. I can't tell you how it will finish. (Too many variables).
Dave F.
Old Jan 2, 2004 | 12:15 AM
parkpy's Avatar
Default pull up some codes like UrS4boy said.
then check under the wire cover, near the back of the firewall, pull it off, and see if the hoses closest to the brake fluid reservoir has popped off.
Old Jan 2, 2004 | 02:41 PM
Skunns256's Avatar
New Member
Default Re: pull up some codes like UrS4boy said.
could it possibly be the O2 sensor?
4rings1.8cT
New England Discussion
Dec 28, 2007 03:48 PM
S4runner
Jul 20, 2006 10:07 AM
c2atb
Jul 12, 2005 01:07 PM
Matt Devo
May 17, 2004 04:14 AM
240
Dec 26, 2001 12:42 PM
