Audi Original "S" Cars Discussion forum for the Audi Audi Ur S4, Ur S6, S2 & RS2
Part number for rubber fuel hose between fuel rail and hard line going to filter?
Old Sep 10, 2007 | 09:30 PM
ThetaTau87's Avatar
Default Part number for rubber fuel hose between fuel rail and hard line going to filter?
It's the rubber line that is clamped to the hard line at the fuel rail and has a threaded fitting into the hard line that goes to the fuel filter.
I ordered 4A1201529AA and this is not the correct part that I need. This is the hard line from the filter. I need the rubber line that goes between this line and the fuel rail. As shown below going from next to the brake fluid resevoir to the fuel rail. TIA!
<img src="http://www.hostdub.com/albums/thetatau87_album01/Fuel_line_leak_001.sized.jpg">
Here's a close up of the leak at the fuel rail. The clamp has cut the hose and caused it to start leaking.
<img src="http://www.hostdub.com/albums/thetatau87_album01/Fuel_line_leak_002.sized.jpg">
I need the line that threads into 19A. It is not shown in this pic. It must be show with the fuel rail illustration.
<img src="http://www.audihelp.com/public/FuelLine.jpg">
Old Sep 10, 2007 | 10:18 PM
UrS4boy's Avatar
Tech Guru
Default You are NOT going to like this: As far as I can tell from your photo and the description the part
you need is part of the fuel rail part, including the fuel rail, 034 133 681 R., Item 15 in KATE's picture album, Main group 1, Subgroup 33, illustration 133-73. Price - around $300 (cost).
Sean D. just bought one last week so he might confirm this.
Old Sep 10, 2007 | 10:24 PM
SCarGo02's Avatar
Default #15 perhaps...
<IMG SRC="http://www.audihelp.com/public/FuelLine2.jpg">
Old Sep 10, 2007 | 10:41 PM
ThetaTau87's Avatar
Yes, that's it
Old Sep 10, 2007 | 10:44 PM
ThetaTau87's Avatar
Default Looks like you're correct. In that case I'll have a replacement rubber section made
and clamp it onto the fuel rail like it is now.
Old Sep 11, 2007 | 05:23 AM
UrS4boy's Avatar
Tech Guru
And I said?
Old Sep 11, 2007 | 07:59 AM
SCarGo02's Avatar
Default Posted the diagram when I opened the post to reply...by the time I had you had as well. And?
If you like at the times we posted they're marginally different (6 min / 6 sec apart).
You explained where it was, I showed, isn't that a win/win situation for anyone who reads this post?
Old Sep 11, 2007 | 08:13 AM
SilberUrS6's Avatar
A+++++. Would read this poster again!
Old Sep 11, 2007 | 08:14 AM
20VT90q's Avatar
Default Why not cut off the bad section and use a nice ABA clamp to tighten it down?
It looks like there's enough hose to to snug it up. That and a nice clamp without the grooves will keep the hose in good shape without damaging it.
Old Sep 11, 2007 | 08:23 AM
quattro20v's Avatar
Default That is the fuel supply line and it, along with the fuel rail is all one piece.
Its not cheap, around $400 retail.
