Power Steering Hose
If you want to go OE. It is $$$(400-500), but you should be able to count on the quality. The cheapest OE prices are found at genuinevwaudiparts.com. I don't know the part number off the top of my head(which really helps on their site), but perhaps someone will chime in...
HOH or any local shop won't do clean-up work. If the fat insulation is soaked from long term leaking, you need to clean it up yourself or have a steam cleaner do it. And, clean up the vehicle where the leak has ocurred. This fluid will soften suspension bushings and hoses where it is allowed to remain for long periods.
You should get 4 new o rings to replace the seals at the hose banjo ends. Part # N 904 054 01
The only down-side to the HOH repair is you have to have a pair of SAE inch size wrenches in the tool box for the swivel fittings they install. : - )
CHF 11s? and what are the thoughts about eliminating the restrictor? Has anyone experimented with other types of Metric Hydraulic fittings other than the OEM Banjo ?
My local Hydraulic shop would cut the Steel line beyond the Banjo just at the original Hydraulic hose Crimp fitting, then Swage on an 8mm Compression fitting/Hose adapter.
But what if the Steel line is marginally corroded?
Thanks!
The restrictor is critical; the pump pulses will resonate the system unmercifully. Retain the foam insulator on the hose also. If they crimp new hose on solidly, the orientation of the ends needs to remain exactly the same or you will introduce twisting stress on the hose. The routing of the hose to avoid interference with other parts was carefully worked out with the banjo ends, so you need to consider how the hose position would change if you change connectors. I have never heard of anyone needing to change the banjo ends.
Thanks for the input. I had the same thoughts after raising the questions to this Hydraulic repair facility... Better to stick with proven and familiar facility....I will contact HoH today.
Much appreciated~
LB
