Temperature Display on Dash - Bulb Replacement?
Soooo...without pulling the whole thing back out, is there a bulb that can be replaced? Or does the whole temperature module come out? I seem to recall on my A4 that the temperature module was separate, but I'm not sure if it had a bulb that could be changed.
Thanks,
Scott
Digi-key part # CM7219-ND
You will have to solder the new bulb into the temperature display.
Good luck
