Want a chip for my UR S6 Avant but do not want to make turbo lag (Low end) worse?
Any suggestions on chips for this car? 95 S6 Avant
Try MRC through Chips-Ur-S.com or Intended Acceleration or even 034. Hey, you are in Colorado, go to Steve Eiche in Arvada (Shadetree Software). Around $500 including a VMAP (3.0 Bar MAP) sensor so you will be Stage 1+ (around 270-280 hp).
http://www.intendedacceleration.com/
A lot of people have used them and I have never heard anything but praise.
J
If the $1200 quote was only for ECU removal and chip socketting and chip installation they are about $700 too high.
Here is Steve Eiche's contact info through Shadetree:
http://www.shadetreesoftware.com/contactus.html
Its also great on the highway for getting up to the speed-limiter quickly without having to downshift.
Its a Hoppen chip, but only cost about $700.
http://www.hoppenmotorsport.com/Audi.S4.S6.Tuning.htm
Here's a picture of what they look like...
I also recommend the "Reliability Items" below if you dont have them already, or something comparable. The 110 Sport By-Pass Valve is an upgrade over the original, and the K&N filter helps airflow and lasts.
You're also likely to blow a hose with a Stage 1+ kit, if they are originals, I blew 2. Most kits contain 3 silicone hoses for ~$350. The 2 hoses Hoppen shows are the 2 hoses I eventually blew. 034 sells them individually also.
To answer your earlier question about lag, Ned and Alex's 3+ ECU update reduced lag on my car. Going to a stiffer WG spring and the billet diverter also helped things (although the diverter only helps if you're shifting well).
J
