Audi Original "S" Cars Discussion forum for the Audi Audi Ur S4, Ur S6, S2 & RS2
What kind of antifreeze are you guys using?........
Old Jan 25, 2005 | 04:18 AM
UR-Idiot Savant-S6's Avatar
Default What kind of antifreeze are you guys using?........
mine is a little below the Min level and I want to top it off. When I had my timing belt service done this past summer they left the level a little low. My antifreeze is a greenish/brown in color. What should I use to top it off? TIA
Old Jan 25, 2005 | 04:52 AM
tpierce's Avatar
Default you should probably flush it
they mixed the green with the blue it sounds like. It won't hurt it like mixing with the red, but it isn't a good practice. I use Prestone antifreeze. It's kind of a yellow/green color. Seems to work great, and it's cheaper than the audi stuff. As long as the antifreeze is phosphate free (it'll be harder to find an antifreeze with phosphates anymore) you'll be fine.
Old Jan 25, 2005 | 06:07 AM
TurboJew's Avatar
Default Yeah, time to flush...
I have to do mine this summer. It was all green (Autobahn brand) from my last flush in Milwaukee but I topped it off with blue when my aux. water pump cracked and leaked a whole mess of coolant out. My mix is SO off, gotta flush and fill when summer comes.
Old Jan 25, 2005 | 06:17 AM
Anyone have a nice DIY for the flush? TIA
Old Jan 25, 2005 | 07:05 AM
TurboJew's Avatar
Default when I did it for the t-belt service it was a drain and refill job
then you run the car up to temp and allow any air pockets to burp out and you top off. I've never heard any different from any mechanics i've talked to.
Old Jan 25, 2005 | 07:39 AM
Default Yup, think I'm going to replace all coolant hoses at the same time......
they're gettin old and I've been lucky so far.
Old Jan 25, 2005 | 08:03 AM
EvanUrS4's Avatar
Member
I just recently flushed mine with Prestone as well, been working great.
Old Jan 25, 2005 | 08:10 AM
4Driver4's Avatar
Tech Guru
Tech Guru
Default Replace the plastic elbow at the back of the engine too.
Cheap, and more prone to failure than the hoses.
You may change your mind on the hoses when you see how much they cost. Also, it is very rare to hear about anyone having leak problems due to a bad hose.
Old Jan 25, 2005 | 08:16 AM
Yeah, I just saw the kit on Blau, almost $300. Plastic elbow is a must though.
Old Jan 25, 2005 | 08:26 AM
quattro20v's Avatar
G11 (blue) for up to mid 1996 and 1996.5> G12 (red). Pentosin is OEM brand
