SQ5 custom courtesy door lights
3 Attachment(s)
I couldnt find these anywhere so had some specially manufacturered.These are not off the shelf items and you cannot buy these anywhere else in the UK or abroad.
You can even rotate the projection so it can sit across the door entrance or in line with the door itself. Attachment 73627 Attachment 73628 Attachment 73629 |
can we make a custom image. it is as easy as replacing the sheet of film with your own design?
They are not a basic film insert.
They image is built into a small projection unit. |
can you please elaborate. is it a JPEG type of file and it a has a small CPU that runs a small projector system?
It is an image printed onto a lens which is then built into a projection tube lit by an LED.
OK tnx. that is an expensive way to do it
why not like the old slide projectors. they could even done it like professional slides, where the image was sandwiched between two pieces of glass so that it would remain flat even with hot air from the bulb. not a case here with LED |
You run the risk of damp ingress and discolouration
So are you selling them?
Originally Posted by NorthValley
(Post 24806781)
https://www.audiworld.com/forums/parts-sale-201/audi-sq5-puddle-door-courtesy-led-projector-canbus-error-free-lights-x-4-a-2899744/ |
These are all over ebay / amazon and have been for some time. I'd rather buy from them personally then some guy reselling them for a profit. gl tho
