Anyone have issues with their soft close doors?
My soft close feature works about 60% of the time. Only affects the front doors. Dealer has replaced everything in the driver's door including the wiring harness. Waiting on Audi to say what the next move is. Since the car was new (I've had it a year) the soft close feature would periodically stop working on all the doors but then work fine the next time I started the car. Happened maybe 5-6 times. Then I got a "driver door malfunction" "parking brake malfunction " and "oil level malfunction" all at the same time. They fixed the problems but then the soft close feature began to act up. It may work 10-15 times perfectly and then have a temper tantrum and not work 5-6 times. They know what's wrong - the system doesn't wake up and recognize the door needs to close. The repair eludes them. Audi in Germany is looking at the issue. I've had several other cars with soft close and they worked perfectly.
so far (1 month) it is working perfect.
Originally Posted by Jim Jistel
(Post 25102219)
Had the car since October. Never had a problem.
2 month and no problem.. there was this one time at the night i got rear ended the soft closing didn't work.. but after a couple times i hit lock/unlock it start working again.. and from then 0 issue..
Originally Posted by MCSMCS1
(Post 25102304)
I had intermittent problems with the doors not closing on the driver's side only and usually just the passenger door on the left side. The dealer just replaced all 4 door latches and so far the problem hasn't recurred, but we will have to see. Where in Texas are you?
I have had it intermittently happen here and there usually on my rear doors. Always corrects itself though, so never bothered my dealer with it.
Originally Posted by Meyecul
(Post 25103039)
(Post 25103183)
At first the whole system would quit but then reboot and act normally when I restarted the car. Now the front doors quit working randomly. May not work 4-5 times then work 5-6 times ok. Very annoying.
Originally Posted by timshuwy
(Post 25103213)
seems odd to me that this would even be connected to the computer system in any way. Seems like a sensor should just detect a partially closed door, and finish closing it.
