About the N75 Wastegate Bypass Regulator Valve. (m)
Old Nov 28, 2002 | 12:06 PM
VonK :: Retired's Avatar
Default About the N75 Wastegate Bypass Regulator Valve. (m)
I haven't been around this forum for over a year. So, when I visited again yesterday, a post about the N75 "race valve" caused me to look into this matter. I haven't time to search the whole past, so some readers might find this just another review. Nonetheless, here's my take for anyone else who might be interested. I'm motivated to do this by people who think they can go the Audi engineers one better by screwing with the unit's calibration screw. The following will explain why this is a dangerous undertaking.
Figure 1 shows how the Waste Gate controls boost, and Figure 2 shows how the ECU controls the Waste Gate by means of the Wastegate Bypass Regulator (N75).
<img src="http://pictureposter.audiworld.com/12010/audiWasteGate.jpg">
Figure 1
<img src="http://pictureposter.audiworld.com/12010/audin75.jpg">
Figure2
In your imagination, connect the outlet of high pressure from the Impeller (blue) in Figure 1 to the bottom inlet (green) in Figure 2, and the right side outlet (gray) in Figure 2 to the Waste Gate actuator (Pressure Unit) in Figure 1.
Here's how this appears to work:
A "No-Flow State" exists during idle, when there is no boost and the Waste Gate is held shut by the spring in its actuator (Pressure Unit).
When you step on the accelerator, boost builds up, and so does the pressure in the green bottom port of Figure 2. This also pressurizes the gray outlet of N75 leading to the actuator (Pressure Unit) in Figure 1. Once the air pressure in that actuator overcomes the spring pressure, the Waste Gate opens and allows some of the exhaust gases to bypass the turbine wheel. However, this action alone would open the Waste gate at lower boost pressures than are desirable. Here's where N75 comes in.
Notice the Restrictor in Figure 2. It allows only a small amount of air to enter from the green port below. As a, result the pressure above the Restrictor (that goes to the Waste Gate actuator) can be regulated by bleeding off controlled amounts of air through the left side purple port of N75. The bleed-off rate is controlled by how far the electric coil pulls up its central plunger, allowing air to escape under the blue cap at its bottom. That pull-up distance is precisely controlled by a pulse width modulated signal from the ECU. To achieve the intended results, N75 is factory calibrated by a screw above the plunger that sets the proper spring pressure of a spring between the plunger and the blue cap.
It's easy to see that one might get a little more boost by turning the calibration screw up a bit, thus increasing the bleed-off rate and reducing the pressure to the Waste Gate actuator. But wait, if the ECU finds the boost higher than expects, it will modify its signal to N75 to correct the situation within limits. If those limits are exceeded, surging will set in, particularly under part load.
The moral of the story: Don't screw with the screw. Trying to fix any drivability problems this way, only hides some other fault.
Sorry about the lecture. :-)
Graphics courtesy of Audi of America
Old Nov 28, 2002 | 12:09 PM
jyoteen's Avatar
A ghose from the past reappears! welome back to the mayhem.
Old Nov 28, 2002 | 12:12 PM
s4what?'s Avatar
Good info - thanks
Old Nov 28, 2002 | 12:15 PM
Thanks, glad to be back. :-)
Old Nov 28, 2002 | 01:04 PM
AlanL's Avatar
Default Sigh - I would settle for an N75 that is working correctly right now.
Mine seems to be causing all sorts of odd boost behaviors right now and will be heading into the dealer service center soon for further investigation.
BTW - Thanks for the explanation. I am just now learning the details of this critter while investigating DTC 17965 and your verbage has helped.
Old Nov 28, 2002 | 01:47 PM
AUJ's Avatar
AUJ
Printed. Thank you. Was actually thinking about getting one rather than chipping before your post.
Old Nov 28, 2002 | 01:51 PM
AUJ's Avatar
AUJ
17965-Charge Pressure Contr. Positive Deviation.
Old Nov 28, 2002 | 02:32 PM
AlanL's Avatar
Yup - that's the one. Did a search and have read all the previous posts now.
Old Nov 28, 2002 | 05:04 PM
Milpitas2.7T's Avatar
Default What's interesting is there are more people here that turn it down then up
Due to surging in factory configuration, so a blatant, don't screw with it, is in accurate.
I agree 100% this is not to be used to increase boost, but this is a nice tuning mechanism to dial out unwanted spikes in your boost delivery.
Before spikes of 1.4, now a constant 1.23 on **** gas and a bit less on great gas!
I think with the proper checks in place, one can absolutely tune the N75 to function properly if not set by factory properly (in most cases)
Old Nov 28, 2002 | 05:06 PM
ed@4induktion.com's Avatar
Former Vendor
Great Explanation...Nice meeting you at Summit Point (nationals)...you going to VIR next week ?
