Battery replacement - Remote control key (aka key fob)
As info the battery model is CR2032 (3 volt button type). The original battery was Panasonic brand. Will replace with a new Energizer CR2032 lithium battery.. and will change the battery in the other key fob at the same time. Found a great deal for this model Energizer battery at Target - a 6-pack for $4.39. Web link: https://www.target.com/p/energizer-2...6/-/A-53449036-------------------------------------------------------------------------------------------------------------------------------------------------------------
Cheers
Richard
I won't be the only person to face this problem.
I've discovered that after you remove the battery holder the first time subsequent removals are a bit easier (no tools necessary). The wiggle thing certainly helps.
/R
Great advice rbreeze on getting it apart. This is one of those catch22 situations though. If it's easy to come apart, then it feels junky and it falls apart in your pocket. If it's tight, it's a PITA but feels better.
