b9 heated steering retrofit?
You need the following hardware.
1. Heated Steering Wheel. If you buy the same shape, you can reuse your airbag.
2. Steering Wheel Stalks, with all the features on your car + the Heated wheel option. Without this, there is no electrical connection to the heating element in the wheel. If you have retrofitted ALA or anything similar, now is the time to buy the stalks with the ALA or required buttons and also the Heated Wheel option.
3. You will need to supply a new power line from the front fuse box to the Steering Wheel stalks. This will include add a new fuse in that fuse box.
Most importantly, you will need to find someone who can Calibrate the Steering Wheel Angle sensor after the parts are swapped out.
No coding is required per se, but you might want to hide the * button configuration screens from the MMI because the new wheel has no * button.
I can't comment on the part number for the Steering Stalks because there are quite a few combinations. You need to look up your own PR numbers and then find one that has them all + the PR number for the Heated Steering wheel.
Audi will definitely be able to code the car.
Did you wire in a new fuse to a blank spot or piggyback off an existing one with an adapter?
How many amps did you use?
Also, what did all the parts cost you?
in the next couple months, I plan on buying a 2018 RS5 coupe (i don't believe heated wheel was an option) or if I can swing it, a '19 RS5 SB with a heated wheel if I can find one, but they are a lot more expensive so i'll probably get an 18 coupe and do the retrofit.
If you don't mind, I may contact you for help on this retrofit. Is that ok?
As for parts, it all depends on where you buy them from. I did all the research and bought all parts in the 3 months while Audi were building my new car. The parts brand new are not cheap so look on ebay. It was incorrectly advised that a brand new Steering stalk was needed, so I bought one. A used one will work fine too, if you can find the exact part number. But you can recover some money by selling the Flat bottom wheel, if it's in good condition. I am kicking myself for not speccing the new car with a flat bottom wheel. Selling the brand new flat bottom wheel would have probably covered the cost of this retrofit.
I wouldn't recommend attempting to remove the airbag yourself if you are not used to doing stuff like this.
I'm used to taking brand new cars apart in week one of my ownership. This car was no different. The coding was a bit hard for me to learn, coming from a BMW. But in the end even that was something I managed myself.
https://parts.audiusa.com/p/Audi_201...4N0907129.html
Hence why, now is the time to decide if you want to add more features that need the relevant buttons in the stalks.
(A4 sedan stuff, but I expect it's the same for the A5 coupe/sportback; I see the same parts listed for the A5 but there's zero details on the PR codes on the A5CO catalog; Audi and their damn parts bulletins)
