HELP Audi Q8 - Endless Errors, Unable to erase
I'm having issues, with my Q8, I'm unable to erase some faulty codes.
Long story short, I bought a 2020 Q8 that was previously in an accident. Of cores it didn't come with the front bumper and all the sensors, I had to buy all of them ( parking sensors, cruise control distance senor, collision warning sensors, laser distance sensor, etc. )
Now I've put everything together and when I'm trying to delete all the faulty codes with vagcom, they are still coming back, I'm not sure what I'm doing wrong or what is wrong with it.
I have to mention I'm new to this stuff...
If someone can help with a solution or advice, please.
Thank you!
This are the readings:
Thursday,05,May,2022,11:10:14:08460
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 22.3.1.4 (x64) HEX-V2 CB: 0.4615.4
Data version: 20220407 DS337.0
www.Ross-Tech.com
Chassis Type: F1-AU58 (4K0)
Scan: 01 02 03 09 13 15 16 17 19 36 3C 42 44 46 47 52 5F 61 6D 74
75 81 82 A5 BB BC C4 CA CC CF D6 D7 DB DC DE
Mileage: 34699km-21560miles
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: Malfunction 0010
09-Cent. Elect. -- Status: Malfunction 0010
13-Auto Dist. Reg -- Status: Malfunction 0010
15-Airbags -- Status: Malfunction 0010
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
36-Seat Mem. Drvr -- Status: OK 0000
3C-Lane Change -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
47-Sound System -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
5F-Information Electr. -- Status: OK 0000
61-Battery Regul. -- Status: OK 0000
6D-Trunk Elect. -- Status: OK 0000
74-Chassis Control -- Status: OK 0000
75-Telematics -- Status: OK 0000
81-Gear Shift -- Status: OK 0000
82-Head Up Display -- Status: OK 0000
A5-Frt Sens. Drv. Assist -- Status: Malfunction 0010
BB-Door Rear Drv -- Status: OK 0000
BC-Door Rear Pass -- Status: OK 0000
C4-DC/DC Converter -- Status: OK 0000
CA-Sunroof -- Status: OK 0000
CC-Starter-Generator -- Status: OK 0000
CF-Lane Chge Asst 2 -- Status: OK 0000
D6-Light Ctrl Left 2 -- Status: OK 0000
D7-Light Ctrl Right 2 -- Status: OK 0000
DB-Frt Corner Rdar 1 -- Status: Malfunction 0010
DC-Frt Corner Rdar 2 -- Status: Malfunction 0010
DE-Charger 1 for mobile dev -- Status: OK 0000
Address 01: Engine (J623-DCBD) Labels: None
Part No SW: 4M8 907 559 A HW: 06M 907 309 G
Component: V6 3.0l TFSI H11 0003
Revision: B8H11000 CVN: A185EFD6
Coding: 2A2A00122566010E34286000000400000000000000000000
Shop #: WSC 19950 004 1048576
ASAM Dataset: EV_ECM30TFS0114M8907559A 001003
ROD: EV_ECM30TFS0114M8907559A.rod
VCID: 3D24303ACDF3BE23E49-8068
VINID: 9D10569915810DC500044182205C061993
1 Fault Found:
17156 - Databus
U1123 00 [039] - Received Error Message
Not Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 6
Fault Frequency: 1
Mileage: 34699 km
Date: 2022.05.05
Time: 13:58:52
Engine RPM: 0.00 /min
Normed load value: 0.0 %
Vehicle speed: 0 km/h
Coolant temperature: 29 °C
Intake air temperature: 23 °C
Ambient air pressure: 990 mbar
Voltage terminal 30: 11.040 V
Unlearning counter according OBD: 40
Drivetrain coordinator: ACC fault status-Bits 0-7: 0
Drivetrain coordinator: brake function status-Bits 0-7: 32
Drivetrain coordinator: brake function status-Bits 0-7: 0
Acceleration: 0.000 m/s²
Readiness: 1110 0101
Address 03: ABS Brakes (J104) Labels: 4M0-907-379-PRE-V1.clb
Part No SW: 4M6 907 379 AF HW: 4M6 907 379
Component: ESP9 Premium H06 0857
CVN: 508629A7
Coding: 28AA149631A30B9A93A45C93088552E2F53A8914288CD0C93A 104A47AF5C91
Shop #: WSC 31414 033 00001
ASAM Dataset: EV_ESP9BOSCHCMP 004011
ROD: EV_ESP9BOSCHCMP_AU58.rod
VCID: 015C8CCAF18B1AC3C01-8054
1 Fault Found:
419328 - TPMS Warning; Front Right Tire
C1057 00 [047] - Flat
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Mileage: 34699 km
Date: 2022.05.05
Time: 13:58:52
6F 00 80 00 C2 03 00 00 20 60
Unlearning counter according OBD-OBD unlearning counter: 28
Address 09: Cent. Elect. (J519) Labels:* 4N0-907-063-V2.clb
Part No SW: 4N0 907 063 KE HW: 4N0 907 063 AE
Component: BCM1 MLBevo H10 0691
Coding: 07000363C0291CDD070E57889CEF9C38130B37110406009701 010A0019331601086309024010000000000303004308185802 000044010104000000000000000000
Shop #: WSC 00008 444 00000
ASAM Dataset: EV_BCM1BOSCHAU651 016011
ROD: EV_BCM1BOSCHAU651_016.rod
VCID: 7BA0FE22936770139AD-802E
Wiper motor control module:
Subsystem 1 - Part No SW: 4M8 955 119 HW: 4N1 955 119
Component: J400FRWISCH 052 0997
Serial number: 904753F0301915605500
Coding: 7DC727
Rain/Light Recognition Sensor:
Subsystem 2 - Part No SW: 81A 955 555 A HW: 81A 955 555
Component: G397_RLFSS H06 0002
Serial number: 24006176X81A955555A0
Coding: 02005D
Light switch:
Subsystem 3 - Part No SW: 4K1 941 501 C HW: 4K1 941 501 C
Component: E1 - LTM H09 0086
Serial number: 14S05.12.1900690704
Garage door opener control module:
Subsystem 4 - Part No SW: 4N0 907 410 C HW: 4M0 907 410 A
Component: USHL5 GX1 H12 0300
Serial number: 0000009600373Z014J02
Coding: 250000
Automatic dimming interior mirror:
Subsystem 5 - Part No SW: 8W0 857 511 B HW: 8W0 857 511 B
Component: Y7_Innenspieg H01 0002
Serial number: GX1CE124091923610284
Coding: 010000
Interior Light Module:
Subsystem 6 - Part No SW: 4K0 947 135 AL HW: 4K0 947 135 AL
Component: Dachmodul H42 0416
Serial number: Q00833799
Coding: 0D0104
Adjustable Steering Column Control Module:
Subsystem 7 - Part No SW: 80A 907 705 HW: 80A 907 705
Component: J866-EVLS-SG H03 0100
Serial number: WA140478000078931449
Coding: 0A0100
Blower 1 for left front backrest:
Subsystem 8 - Part No SW: 4N0 963 575 A HW: 4N0 963 575 A
Component: V512 LLR1SLvL H01 0012
Serial number: Q98BJ33980179
Blower 1 for left front seat cushion:
Subsystem 9 - Part No SW: 4N0 963 575 A HW: 4N0 963 575 A
Component: V514 LLR1SKvL H01 0012
Serial number: Q98BJ33989956
Blower 1 for right front backrest:
Subsystem 10 - Part No SW: 4N0 963 575 A HW: 4N0 963 575 A
Component: V516 LLR1SLvR H01 0012
Serial number: Q98BJ218A6921
Blower 1 for right front seat cushion:
Subsystem 11 - Part No SW: 4N0 963 575 A HW: 4N0 963 575 A
Component: V518 LLR1SKvR H01 0012
Serial number: Q98BJ34099420
1 Fault Found:
405507 - Functional Limitation due to Energy Management
B10CD 00 [009] - -
[Function limitation due to energy management system]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 193
Mileage: 34699 km
Date: 2022.05.05
Time: 14:00:29
average_Voltage_terminals: 11.00 V
Outside air temperature sensor-Resistance: 0.00 kOhm
Outside air temperature sensor-Outside air temperature on CAN: 17.00 °C
interior_temperature: 19.00 °C
Vehicle speed: 0.00 km/h
Terminal activation-Terminal 75 status: On
Terminal activation-Terminal 15 status signal: On
Terminal activation-Terminal 15 via CAN: On
Terminal activation-Term 75: qualification: OFF
Address 13: Auto Dist. Reg (J428) Labels:* Redir Fail!
Part No SW: 4M0 907 561 L HW: 4K0 907 561
Component: LRR4R H04 0332
Coding: D6659F5C58082C00010360E1000000BE4A1246484481009E04
Shop #: WSC 31414 042 00001
ASAM Dataset: EV_ACCBOSCHAU65X 002023
ROD: EV_ACCBOSCHAU65X_AU58.rod
VCID: 392C242AD9DB8203C81-806C
8 Faults Found:
2342 - Databus
U1123 00 [009] - Received Error Message
[FAULT_ACA_QF_STATUS_DISPLAY_ERROR]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 193
Mileage: 34699 km
Date: 2022.05.05
Time: 13:57:03
Control Module temperature: 37 °C
Voltage terminal 15: 11.0 V
Vehicle speed: 0.00 m/s
Longitudinal acceleration: 0.00 m/s²
Adaptive distance regulation: status: ACC_irreversible error
Steering_angle-Data: 49.600 °
Yaw_rate-Data: 0.000 rad/s
adjustment_calculation: OFF
Misalignment angle: horiz: 0.098 °
Misalignment angle: horiz: fast algorithm: -0.058 °
Congestion pilot: status: OFF
Outside temperature: 17.00 °C
Sensor blindness: radar: no blindness detected
2337 - Databus
U1122 00 [009] - Implausible Message
[FAULT_CORNERRADAR_FL_DATA_TRANSFER]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 254
Reset counter: 193
Mileage: 34699 km
Date: 2022.05.05
Time: 13:57:03
2334 - Databus
[FAULT_CORNERRADAR_FL_ERROR]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 193
Mileage: 34699 km
Date: 2022.05.05
Time: 13:57:03
2338 - Databus
[FAULT_CORNERRADAR_FR_DATA_TRANSFER]
Freeze Frame:
Fault Priority: 6
Reset counter: 193
Mileage: 34699 km
Date: 2022.05.05
Time: 13:57:03
2335 - Databus
[FAULT_CORNERRADAR_FR_ERROR]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 193
Mileage: 34699 km
Date: 2022.05.05
Time: 13:57:03
2340 - Databus
[FAULT_LIDAR_DATA_TRANSFER]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 193
Mileage: 34699 km
Date: 2022.05.05
Time: 13:57:03
15360512 - Component Protection
U1101 00 [009] - Active
[FAULT_THP_EC_INVALID_IKA]
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 193
Mileage: 34699 km
Date: 2022.05.05
Time: 13:57:03
1027 - Databus
U1121 00 [009] - Missing Message
[FAULT_TIMEOUT_ANHAENGER_01]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 193
Mileage: 34699 km
Date: 2022.05.05
Time: 13:57:03
Address 15: Airbags (J234) Labels:| 80A-959-655.clb
Part No SW: 4N0 959 655 K HW: 4N0 959 655 K
Component: AirbagVW31 H12 2720
Serial number: 003YUM00VH19
Coding: AECCFCC000C00000A000003FF20D410000C5
Shop #: WSC 31414 029 00001
ASAM Dataset: EV_AirbaVW31SMEAU65x 001032
ROD: EV_AirbaVW31SMEAU65x_001.rod
VCID: 44D245DEAE19CFEBAB7-8010
Left seat belt tensioner:
Subsystem 1 - Part No SW: 4N0 980 945 A HW: 4N0 980 945 A
Component: BeltPretRevFL H10 0115
Serial number: 00AI2019344303700000
Coding: 02F001
Right seat belt tensioner:
Subsystem 2 - Part No SW: 4N0 980 946 A HW: 4N0 980 946 A
Component: BeltPretRevFR H10 0115
Serial number: 00AI2019345602000000
Coding: 02F001
Seat occupied recognition passenger side:
Subsystem 3 - Part No SW: 4M0 959 339 HW: 4M0 959 339
Component: BF-Gewichtss. H12 0022
Serial number: IBH0000D19000COZN900
Coding: 303134
Crash sensor for side airbag: driver side:
Subsystem 4 - Part No SW: ----------- HW: 480 002 112 19
Component: SideSensor_Df 001 0887
Serial number: 35700000000B5145D34I
Coding: 2D2D2D
Front Passenger's Side Airbag Crash Sensor:
Subsystem 5 - Part No SW: ----------- HW: 480 002 012 19
Component: SideSensor_Pf 001 0887
Serial number: 35800000000CC140E34N
Coding: 2D2D2D
Rear Side Airbag Crash Sensor (on driver's side):
Subsystem 6 - Part No SW: ----------- HW: 480 030 912 19
Component: SideSensor_Dr 002 0149
Serial number: 351002C0053575111B5O
Coding: 2D2D2D
Passenger side rear thorax airbag crash sensor:
Subsystem 7 - Part No SW: ----------- HW: 480 030 912 19
Component: SideSensor_Pr 002 0149
Serial number: 352002C005353910EC0X
Coding: 2D2D2D
Crash sensor for front airbag: driver side:
Subsystem 8 - Part No SW: ----------- HW: 480 031 911 19
Component: FrontSensor_D 002 0149
Serial number: 355002C00E7C9A204A8H
Coding: 2D2D2D
Crash sensor for front airbag: front passenger side:
Subsystem 9 - Part No SW: ----------- HW: 480 032 902 20
Component: FrontSensor_P 002 0149
Serial number: 356002C0434412614A5T
Coding: 2D2D2D
Crash sensor for side airbag: B-pillar: driver side:
Subsystem 10 - Part No SW: ----------- HW: 480 030 912 19
Component: SideSens_B_Df 002 0149
Serial number: I0P002C007B422606ED-
Coding: 2D2D2D
Crash sensor for side airbag: B-pillar: passenger side:
Subsystem 11 - Part No SW: ----------- HW: 480 030 912 19
Component: SideSens_B_Pf 002 0149
Serial number: I0Q002C0053D31114C5K
Coding: 2D2D2D
2 Faults Found:
1073925 - Databus
[NWD: 0xTBD MRR_VL_SensorHeader error value MRR_VL_Fehler]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 193
Mileage: 34699 km
Date: 2022.05.05
Time: 13:57:02
1074181 - Databus
[NWD: 0xTBD MRR_VR_SensorHeader error value MRR_VR_Fehler]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 193
Mileage: 34699 km
Date: 2022.05.05
Time: 13:57:02
Address 19: CAN Gateway (J533) Labels:* None
Part No SW: 4K0 907 468 Q HW: 4K0 907 468 C
Component: Gateway H06 0272
Serial number: 1AF02101475201
Coding: 020100050004064054960000005B0132DC9A00471000000009 7D078E10000000
GVL: F1513C080800000002DC88008000C800110C00700000000000 00000000000100
ASAM Dataset: EV_Gatew31xAU65x 003190
ROD: EV_Gatew31xAU65x_AU58.rod
VCID: 42DE43C6B40DC1DB99B-8016
Multifunction steering wheel control module:
Subsystem 1 - Part No SW: 4M8 951 523 A HW: 4M8 951 523 A
Component: J453 MFL H07 0004
Serial number: 20191118232907 32331
Battery Monitoring Control Module:
Subsystem 2 - Part No SW: 4K0 915 181 A HW: 4K0 915 181 A
Component: J367-BDMConti H03 1050
Serial number: 758852020019121900EA
2 Faults Found:
8519683 - Energy Management Active
U140B 00 [009] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 193
Mileage: 34699 km
Date: 2022.05.05
Time: 14:00:20
EM_vehicle_state: 00 10
Static current shut-off stage: Deactivation stage 1
Auxiliary heater activation restriction request-Parking heater: Permitted
Auxiliary heater activation restriction request-Allowed parking heater runtime: 0 min
[KS_Active_1]
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 193
Mileage: 34699 km
Date: 2022.05.05
Time: 13:57:02
Address A5: Frt Sens. Drv. Assist (J1121) Labels:* 4N0-907-107-V2.clb
Part No SW: 4KE 907 107 AR HW: 4N0 907 107 H
Component: zFAS Var C H09 0295
Coding: 020182000000000000FBD60000F0450C139F76000000000000 00000000969401019BA8000000000000000080000000000000 000000000000F980400000000000000078D000800090008000 80000000000080400000E0
ASAM Dataset: EV_ZFASAU516 001007
ROD: EV_ZFASAU516_001.rod
VCID: 0F78BAF2B7DF7CB3465-805A
5 Faults Found:
2114642 - Databus
[MRR_VL_SensorHeader_MRR_VL_Fehler]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 193
Mileage: 34699 km
Date: 2022.05.05
Time: 14:04:14
2114643 - Databus
[MRR_VR_SensorHeader_MRR_VR_Fehler]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 193
Mileage: 34699 km
Date: 2022.05.05
Time: 14:04:14
4108 - Databus
[irreversibler_Fehler_im_ACC_System]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 193
Mileage: 34699 km
Date: 2022.05.05
Time: 14:04:14
65537 - Intersection Assistant
C12D8 F0 [009] - Status Feedback for HMI Implausible
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 193
Mileage: 34699 km
Date: 2022.05.05
Time: 14:04:22
Profile master status intersection assistant-Nominal status: On
Profile master status intersection assistant-Actual status:: Malfunction
65540 - Following-Distance Warning (High)
C12DA F0 [009] - Status Feedback for HMI Implausible
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 193
Mileage: 34699 km
Date: 2022.05.05
Time: 14:04:16
Profile master status distance warning high-Nominal status: On
Profile master status distance warning high-Actual status:: Malfunction
Address DB: Frt Corner Rdar 1 (J1089) Labels:* None
Part No SW: 4N0 907 669 F HW: 4N0 907 669 A
Component: MRR_VR H12 0266
Coding: 001000
Shop #: WSC 31414 041 00001
ASAM Dataset: EV_FrontCorneRadarS1AU651 001018
ROD: EV_FrontCorneRadarS1AU651.rod
1 Fault Found:
[Component protection is active]
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 193
Mileage: 34699 km
Date: 2022.05.05
Time: 13:57:01
Control Module temperature: 50 °C
Voltage terminal 30: Measuring value not available
Terminal 15 status: On
Voltage terminal 15: 10.80 V
Register_check_info-Register_check_info_parameter: 0
C1_critical_signals_info-C1_critical_signals_info_parameter: 0
C2_critical_signals_info-C2_critical_signals_info_parameter: 0
Address DC: Frt Corner Rdar 2 (J1088) Labels:* None
Component: MRR_VL H12 0266
Coding: 001000
Shop #: WSC 31414 200 00001
ASAM Dataset: EV_FrontCorneRadarS2AU651 001018
ROD: EV_FrontCorneRadarS2AU651.rod
1 Fault Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 193
Mileage: 34699 km
Date: 2022.05.05
Time: 13:57:01
Control Module temperature: 46 °C
However as uberwgn mentioned if there is a CP on some modules you will have to visit Audi dealer or the car electronics specialist which will be able to remove the CP. Otherwise you will have permanent errors and these components will not work
Did you install new or used parts? If used parts it would explain why there is a CP which has to be removed.
Yes, I've installed used parts, is there a reason for the CP? security or something.
They need to recode the parts or just to remove the CP?
CP can be removed by Audi dealers or some specialists which have a proper software to do it. It can be done remotely.
