Frustrated with crank no start
My question is should it do the same (start then die after a few seconds) for the Q7 even though its a diesel? And if hes correct and its not the ECU, where do I go from here?
Honestly, to get any useful help from a forum with a possibly complex issue such as your no-start condition, you always gotta start off with a full description of your vehicle and post your data for most recent VAGCOM scan of the car (full Auto-scan). Diesels are fairly simple engines, but these do require extremely high fuel pressure from HPFP to start/run, working glowplugs (if it's below certain temp threshold) a working fuel pressure (feedback loop) regulator/sensor on the fuel rail, a working in-tank fuel pump to get the fuel to the filter and the HPFP, a fuel filter that's not clogged, no air or water in fuel lines, good system voltage/battery, a good starter motor, etc., etc. And good fuel/ additives never hurts either, especially if your car's been sitting for quite a while w/o running...diesel fuel breaks down relatively quickly if a stabilizer isn't added for storage.
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 24.7.0.0 (x64) HEX-V2 CB: 0.4643.5
Data version: 20240715 DS356.3
www.Ross-Tech.com
VIN: WA1VMAFE7CD003066 License Plate:
Mileage: 296760km-184398mi Repair Order:
Chassis Type: FE-AU56 (4F0)
Scan: 01 02 03 05 08 09 15 16 17 19 28 36 3C 42 46 47 4C 4F 52 55
56 5F 62 69 6D 6F 72 76
VIN: WA1VMAFE7CD003066 Mileage: 296760km-184398miles
01-Engine -- Status: Malfunction 1010
02-Auto Trans -- Status: Malfunction 0010
03-ABS Brakes -- Status: Not registered 0011
04-Steering Angle -- Status: OK 0000
05-Acc/Start Auth. -- Status: Malfunction 0010
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: Malfunction 0010
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: Malfunction 0010
19-CAN Gateway -- Status: Malfunction 0010
28-HVAC, Rear -- Status: Malfunction 0010
36-Seat Mem. Drvr -- Status: OK 0000
3C-Lane Change -- Status: Malfunction 0010
42-Door Elect, Driver -- Status: Malfunction 0010
46-Central Conv. -- Status: Malfunction 0010
47-Sound System -- Status: Malfunction 0010
4C-Tire Pressure II -- Status: Malfunction 0010
4F-Centr. Electr. II -- Status: Malfunction 0010
52-Door Elect, Pass. -- Status: Malfunction 0010
55-Headlight Range -- Status: Malfunction 0010
56-Radio -- Status: Malfunction 0010
5F-Information Electr. -- Status: Malfunction 0010
62-Door, Rear Left -- Status: Malfunction 0010
69-Trailer -- Status: Malfunction 0010
6D-Trunk Elect. -- Status: OK 0000
6F-Centr. Conv. II -- Status: Malfunction 0010
72-Door, Rear Right -- Status: Malfunction 0010
76-Park Assist -- Status: Malfunction 0010
Address 01: Engine (J623-CATA) Labels:. 059-907-401-V2.clb
Part No SW: 4L2 910 401 HW: 4L0 907 401 D
Component: 3.0TDI FSA H18 0009
Revision: 54H18--- Serial number: CVN: 5B6F114C0000000000000000
Coding: 2A2A4012253600050000
Shop #: WSC 27985 004 1048576
ASAM Dataset: EV_ECM30TDI0114L2910401 002008
ROD: EV_ECM30TDI0114L2910401_002.rod
VCID: 61987DF911CE47C230D-8034
VINID: 9D10667515951D35000030061896D2B1F1
20 Faults Found:
4528 - Coolant Fan Control Circuit 2
P0481 00 [00100111] - Electrical Malfunction
Not Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 296768 km
Date: 2011.08.12
Time: 00:00:01
Engine RPM: 0.00 /min
Normed load value: 0.0 %
Vehicle speed: 0 km/h
Coolant temperature: 15 ∞C
Intake air temperature: 15 ∞C
Ambient air pressure: 1000 mbar
Voltage terminal 30: 11.960 V
Unlearning counter according OBD: 40
Air mass: specified value: 750.0 mg/stroke
Coolant temperature at radiator outlet: actual value: 14.7 ∞C
Heat delivery temperature in cooling system: -273.1 ∞C
Outside temperature: 15.0 ∞C
Coolant fan 2: activation: 11.70 %
Coolant fan 1: activation: 10.00 %
Fuel temperature: 15.8 ∞C
14625 - Glow Plug Control Module (J179)
P0683 00 [00100111] - Electrical Malfunction
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 296768 km
Date: 2011.08.12
Time: 00:00:38
Vehicle speed: 254 km/h
Coolant temperature: 22 ∞C
Intake air temperature: 36 ∞C
Voltage terminal 30: 10.600 V
Glow-control unit: activation voltage: 0 mV
Glow_period_control_unit_ground_offset_voltage: 0 mV
Glow-control unit: calculated glow voltage: 0 mV
Glow_period_control_unit_energy_integrator_calcula ted_value: 0.0 V≤s
Glow cycles upon reaching temperature threshold-Bits 0-7: 0
Glow cycles upon reaching temperature threshold-Bits 0-7: 18
Glow status-Bits 0-7: 0
Glow status-Bits 0-7: 16
Co EOM st Op Mode Short-Bits 0-7: 0
14629 - Fuel Pump Control Module
P025C 00 [10100111] - Short to Ground
MIL ON - Not Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 296768 km
Date: 2011.08.12
Time: 00:00:39
Voltage terminal 30: 11.800 V
Shut-off timer: last engine shut-off time: 2 s
Control module temp.: max. value: 62.2 ∞C
Mean injection quantity: 0.00 mg/stroke
Ambient temperature: 20.0 ∞C
Control Module temperature: 43.4 ∞C
4344 - Implausible Data Received from HVAC Control Module (J301)
U0424 00 [00100111] - -
[Invalid Data Received From HVAC Control Module]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 3
Mileage: 296768 km
Date: 2011.08.12
Time: 00:00:38
Torque request: A/C compressor: 0.0 Nm
Status of compressor release-Bits 0-7: 1
A/C compressor: refrigerant pressure: 65534 hPa
A/C compressor torque: 0.0 Nm
Accelerator pedal travel: 0.00 %
Engine status: COENG_READY
Engine status-Test_Program_Co Eng st COMPU VERB UBYTE: 1
4875 - Coolant Pump 2
P261A 00 [00100111] - Open circuit
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 296768 km
Date: 2011.08.12
Time: 00:00:42
Coolant temperature: 23 ∞C
Voltage terminal 30: 11.680 V
Coolant temperature at radiator outlet: actual value: 23.5 ∞C
Bypass valve for EGR cooler: status-Bits 0-7: 1
EGR cooling function: status-Bits 0-7: 1
exh.gas recirc. (EGR) cooler pump: specified value: 80.00 %
Temp sensor for EGR after cooler: raw value: 25.7 ∞C
Exhaust gas temperature sensor 1: 25.4 ∞C
5111 - Oxygen (Lambda) Sensor B1 S1; Heating Circuit
P0135 00 [00100111] - Malfunction
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 296768 km
Date: 2011.08.12
Time: 00:00:48
Voltage terminal 30: 11.740 V
Air mass: actual value (mg/stroke): 0.0 mg/stroke
Oxygen sensor 1 Bank 1: Status Calibration O2-Signal-Bits 0-7: 0
Oxygen sensor 1 bank 1: voltage raw value O2 signal: -8.6 mV
Oxygen sensor 1 bank 1: voltage value Ri-signal filtered: 3299.8 mV
O2 sensor 1 bank 1: duty cycle O2 heater: 2.45 %
LSU r O2 Adap 0: 0.00063
13828 - Relay for Aux Coolant Pump (J496)
P1927 00 [00100111] - Open Circuit
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 296768 km
Date: 2011.08.12
Time: 00:00:01
Ambient temperature: 15.7 ∞C
Control Module temperature: 44.7 ∞C
5368 - Relay for Low Heater Output
P302C 00 [00100111] - Short to Ground
[Low heat output relayShort circuit to Ground (GND)]
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 296768 km
Date: 2011.08.12
Time: 00:00:38
Voltage terminal 30: 10.420 V
Ambient temperature: 35.9 ∞C
Control Module temperature: 46.1 ∞C
5369 - Relay for High Heater Output
P302D 00 [00100111] - Short to Ground
[High heat output relayShort circuit to Ground (GND)]
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 296768 km
Date: 2011.08.12
Time: 00:00:38
4873 - Exhaust Gas Recirculation Cooling Valve Control Circuit
P2426 00 [00100111] - Short to Ground
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 296768 km
Date: 2011.08.12
Time: 00:00:39
Voltage terminal 30: 10.640 V
Ambient temperature: 36.0 ∞C
Control Module temperature: 44.2 ∞C
9760 - Switch-Over Valve for EGR Cooler
P148F 00 [00100111] - Electrical Malfunction
[exh.gas recirc. cooler switch-over valve 2Electrical malfunction]
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 296768 km
Date: 2011.08.12
Time: 00:00:39
9490 - Engine Oil Pressure Regulation
P06DB 00 [00100111] - Short to GND
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 296768 km
Date: 2011.08.12
Time: 00:00:38
13831 - Relay for Aux Coolant Pump (J496)
P1926 00 [00100111] - Short to Ground
[Auxiliary Engine Coolant (EC) Pump RelayShort circuit to Ground (GND)]
Freeze Frame:
Fault Priority: 2
Fault Frequency: 3
Mileage: 296768 km
Date: 2011.08.12
Time: 00:00:38
5301 - Throttle Actuator Control Circuit
P2100 00 [00100111] - Open Circuit
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 296768 km
Date: 2011.08.12
Time: 00:00:38
Throttle valve adapter: specified value: 95.00 %
Throttle valve adapter: actual value: 100.00 %
Throttle valve adapter: status-Bits 0-7: 0
Throttle valve adapter: status-Bits 0-7: 7
4339 - Implausible Data Received from HVAC Control Module (J301)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 3
Mileage: 296768 km
Date: 2011.08.12
Time: 00:00:44
Voltage terminal 30: 11.760 V
28988 - No Communications with NOX Sensor 1
U029D 00 [00100111] - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 296768 km
Date: 2011.08.12
Time: 00:00:38
Voltage terminal 30: 10.500 V
Limitation: accelerator pedal: 0.0 Nm
CAN status - engine control module-Bits 0-7: 0
Cruise Control System (CCS): status-Bits 0-7: 44
CAN status - transmission control module-Bits 0-7: 0
CAN status - brake control module 1-Bits 0-7: 8
CAN status - brake control module 2-Bits 0-7: 0
selected gear-Bits 0-7: 0
28990 - No Communications with NOX Sensor 2
U029E 00 [00100111] - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 296768 km
Date: 2011.08.12
Time: 00:00:38
4713 - No Communication with ABS Brake Control Module
U0121 00 [00100100] - -
[Lost Communication WithAnti-Lock Brake System (ABS) Control Module]
Intermittent - Not Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 296768 km
Date: 2011.08.12
Time: 00:00:38
5307 - Throttle Valve Actuator Control System
P2101 00 [00100111] - Malfunction
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 296768 km
Date: 2011.08.12
Time: 00:00:38
Voltage terminal 30: 10.620 V
Throttle valve adapter: actual value: 95.50 %
9127 - Actuator Module for Turbocharger 1
P00AF 00 [10100111] - Stuck
Freeze Frame:
Fault Priority: 2
Fault Frequency: 3
Mileage: 296768 km
Date: 2011.08.12
Time: 00:00:41
Voltage terminal 30: 11.040 V
Charge Pressure Actuator: activation: 50.00 %
Charge air pressure actuator: acknowledgment: -4.82 %
Turbocharger boost control: offset closed: 0.00 %
Turbocharger boost control: offset open: 0.00 %
High press turbocharger actuator: actual uncond volt value: 258.8 mV
Readiness: 0 0 0 1 1
Address 02: Auto Trans (J217) Labels:| 0C8-927-7XX-V1.clb
Part No SW: 0C8 927 750 S HW: 0C8 927 750 S
Component: AL1000 AISIN 001 3408
Serial number: CVN: 44BD1086
Coding: 001378
ASAM Dataset: EV_TCMAL991031 002112
ROD: EV_TCMAL991031_002_AU56.rod
VCID: 3C26EC8DD6EC4A2A43B-8068
2 Faults Found:
12809 - No Communication with Engine Control Module (SAE ECM/PCM)
U0100 00 [00100111] - -
Freeze Frame:
Fault Priority: 2
Reset counter: 0
Engine RPM: 0.0 /min
Transmission input speed: 0 /min
Transmission output speed: 0 /min
Engine torque: -4 Nm
ATF temperature: 14 ∞C
Accelerator pedal position: 0.0 %
Clutch_C1: Open
Clutch_C2: Open
Clutch_C3: Open
Clutch_C4: Open
Clutch_B1: Open
Clutch_B2: Open
Lock Up Clutch: Open
EOP target revolution: 65534 /min
EOP actual revolution: 65279 /min
Engine Speed signal Current: 65279 /min
EOP failure status with EOP without HV 1: Motor normal stop
EOP target current: 65278 mA
12810 - No Communication with ABS Brake Control Module
U0121 00 [00001001] - -
Freeze Frame:
Fault Priority: 2
Reset counter: 198
Engine torque: -60 Nm
ATF temperature: 18 ∞C
Clutch_C1: Open
Clutch_C2: Open
Clutch_C3: Open
Clutch_C4: Open
Clutch_B1: Open
Clutch_B2: Open
Address 03: ABS Brakes Labels:. 4L0-910-517-V1.clb
Part No SW: 4L0 910 517 A HW: 4L0 614 517 A
Component: ESP ALLRAD MK25E1 0130
Revision: 00H22001
Coding: 0033809
Shop #: WSC 31414 790 00001
VCID: 280E20DD3EF4F68A373-807C
6 Faults Found:
00668 - Supply Voltage Terminal 30
001 - Upper Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100001
Fault Priority: 2
Fault Frequency: 1
Reset counter: 198
Mileage: 304209 km
Time Indication: 0
Date: 2006.11.23
Time: 12:07:58
Freeze Frame:
Count: 0
Count: 8453
Count: 129
Count: 49408
002 - Lower Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 2
Fault Frequency: 2
Reset counter: 158
Mileage: 0 km
Time Indication: 0
Freeze Frame:
Count: 128
Count: 15104
Count: 128
Count: 22784
01826 - Sensor for Steering Angle (G85); Supply Voltage Terminal 30
000 - - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 2
Fault Frequency: 2
Reset counter: 158
Mileage: 304209 km
Time Indication: 0
Date: 2006.11.23
Time: 12:00:13
Freeze Frame:
Count: 192
Count: 13061
Count: 297
Count: 46592
01314 - Engine Control Module
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 205
Mileage: 296768 km
Time Indication: 0
Date: 2011.08.12
Time: 01:14:08
Freeze Frame:
Count: 128
Count: 8453
Count: 8194
Count: 44544
00778 - Steering Angle Sensor (G85)
005 - No or Incorrect Basic Setting / Adaptation
Freeze Frame:
Fault Status: 01100101
Fault Priority: 2
Fault Frequency: 1
Reset counter: 205
Mileage: 296768 km
Time Indication: 0
Date: 2011.08.12
Time: 01:14:07
Freeze Frame:
Count: 128
Count: 8965
Count: 8215
Count: 44544
18055 - Check Coding of ECUs on Powertrain Data Bus
P1647 - 000 -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 2
Fault Frequency: 1
Reset counter: 205
Mileage: 296768 km
Time Indication: 0
Date: 2011.08.12
Time: 01:14:08
Freeze Frame:
Count: 0
Count: 8453
Count: 197
Count: 44544
Address 05: Acc/Start Auth. Labels:. 4F0-910-852.clb
Part No SW: 4F0 910 852 B HW: 4F0 905 852 F
Component: FBSAUDIC6 ELV H05 0130
Revision: 00H05000 Serial number: 10603401893047
Coding: 0000135
Shop #: WSC 44055 001 1048576
VCID: 251029E949E6EBE20C5-8070
Subsystem 1 - Part No: 4F0 910 132 L
Component: FBSAUDIC6 EZS H03 0020
Subsystem 2 - Part No: 4F0 910 335 B
Component: FBSAUDIC6 KSG H03 0020
Subsystem 3 - Part No: 4F0 910 220 G
Component: FBSAUDIC6 IDG H01 0053
5 Faults Found:
00190 - Driver's Door Handle Touch Sensor (G415)
007 - Short to Ground
Freeze Frame:
Fault Status: 01110111
Fault Priority: 3
Fault Frequency: 1
Reset counter: 205
Mileage: 296768 km
Time Indication: 0
Date: 2011.08.12
Time: 00:03:30
00192 - Rear Left Door Handle Touch Sensor (G417)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 205
Mileage: 296768 km
Time Indication: 0
Date: 2011.08.12
Time: 00:03:30
00193 - Rear Right Door Handle Touch Sensor (G418)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 205
Mileage: 296768 km
Time Indication: 0
Date: 2011.08.12
Time: 00:03:30
02241 - Engine Control Module; Immobilizer Data not Adapted
Freeze Frame:
Fault Priority: 1
Fault Frequency: 1
Reset counter: 245
Mileage: 296768 km
Time Indication: 0
Date: 2011.08.12
Time: 00:01:16
00446 - Function Limitation due to Under-Voltage
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 245
Mileage: 296768 km
Time Indication: 0
Date: 2011.08.12
Time: 01:29:52
Address 08: Auto HVAC (J255) Labels: 4L0-910-043.clb
Part No SW: 4L0 910 043 D HW: 4L0 820 043 AJ
Component: KLIMA 4 ZONEN H15 0070
Revision: 00---026 Serial number: 00000030208767
Coding: 0004A036
VCID: 251029E945E6EBE20C5-8070
Subsystem 1 - Part No SW: 8K0 959 772 D HW: 8K0 959 772
Component: SLR-B8 H05 0006
Serial number: 0012461892
Coding: 070000
Subsystem 2 - Part No SW: 8K0 959 772 D HW: 8K0 959 772
Serial number: 0012461828
Coding: 070000
3 Faults Found:
01592 - Air Quality Sensor (G238)
014 - Defective
Freeze Frame:
Fault Status: 01101110
Fault Priority: 3
Fault Frequency: 9
Reset counter: 205
Mileage: 296768 km
Time Indication: 0
Date: 2011.08.12
Time: 00:43:45
Freeze Frame:
Temperature: 21.0∞C
00819 - High Pressure Sensor (G65)
009 - Open or Short to Ground
Freeze Frame:
Fault Status: 01101001
Fault Priority: 2
Fault Frequency: 1
Reset counter: 205
Mileage: 296768 km
Time Indication: 0
Date: 2011.08.12
Time: 00:43:45
Freeze Frame:
Temperature: 17.0∞C
Temperature: 20.0∞C
Load: 8.8 %
Temperature: -55.0∞C
RPM: 0 /min
Absolute Pres.: 1.0 bar
Current: 0.005 A
Temperature: 21.0∞C
02874 - Control Module 2 for Central Convenience (J773)
008 - Implausible Signal
Freeze Frame:
Fault Status: 01101000
Fault Priority: 2
Fault Frequency: 1
Reset counter: 205
Mileage: 296768 km
Time Indication: 0
Date: 2011.08.12
Time: 00:43:45
Freeze Frame:
ON
Address 09: Cent. Elect. Labels: 4F0-910-279.lbl
Part No SW: 4F0 910 279 AG HW: 4F0 907 279 C
Component: ILM Fahrer H31 0400
Revision: 00000000 Serial number: 4F0907279
Coding: 0139123
VCID: 6E8216C5DC90E8BABDF-803A
Subsystem 1 - Part No: 4L1 910 113 Labels: 1KX-955-119.CLB
Component: Wischer AU716 H18 0110
Coding: 00064792
Shop #: WSC 31414
Subsystem 2 - Part No: 8K0 910 557 Labels: 8K0-955-559.CLB
Component: REGENLICHTSENSORH04 0003
Coding: 00150059
Shop #: WSC 31414
No fault code found.
Address 15: Airbags Labels: 4L0-910-655.clb
Part No SW: 4L0 910 655 A HW: 4L0 959 655 B
Component: 73 AIRBAG AUDI8RH43 0230
Revision: 07H43000 Serial number: 0038QD09VDZ9
Coding: 0014131
VCID: 2B04DFD12F02DD92DA1-807E
Subsystem 1 - Part No: 4L0 910 339 A
Component: BF-Gewichtsens. H03 0030
Subsystem 2 - Serial number: 6332QSME180D265AK
Subsystem 3 - Serial number: 6342QSME180D2C78R
Subsystem 4 - Serial number: 6352QSME195E225AP
Subsystem 5 - Serial number: 6362QSME685C2972T
Subsystem 6 - Serial number: 63734SME315C3C7CD
Subsystem 7 - Serial number: 63834SME045B217E3
1 Fault Found:
01316 - ABS Control Module
Address 16: Steering wheel Labels: 4F0-910-549.lbl
Part No SW: 4F0 910 549 B HW: 4F0 953 549 F
Component: J0527 0830
Revision: 00H07000 Serial number: 90025111660484
Coding: 0012242
Subsystem 1 - Part No: XXXXXXXXXXX
Component: E0221 H03 0030
Address 17: Instruments (J285) Labels:. 4L0-920-KOM-V3.clb
Part No SW: 4L0 920 984 R HW: 4L0 920 984 R
Component: KOMBIINSTR. H22 0411
Revision: 00000000 Serial number: LMZ04009C
Coding: 8BD664040900CF05020205
VCID: 42DA9275B4883CDA097-8016
2 Faults Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 245
Mileage: 296768 km
Time Indication: 0
Date: 2011.08.12
Time: 00:43:43
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 245
Mileage: 296768 km
Time Indication: 0
Date: 2011.08.12
Time: 00:03:31
Address 19: CAN Gateway (J533) Labels:. 4F0-907-468.clb
Part No SW: 4F0 907 468 Q HW: 4F0 907 468 G
Component: GW-BEM 5CAN-M H06 0047
Revision: MB300033 Serial number: 3300M11819012B
Coding: 00C303
VCID: 3D20E189CD764322745-8068
Subsystem 1 - Part No SW: 8K0 915 181 D HW: 8K0 915 181 D
Component: J367-BDM H07 0125
Serial number: 00000000002790354551
2 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 245
Mileage: 296768 km
Time Indication: 0
Date: 2011.08.12
Time: 00:03:31
Freeze Frame:
Bin. Bits: 00111
Voltage: 12.50 V
Count: 7
Bin. Bits: 10011
Time: 0.40 s
01044 - Control Module Incorrectly Coded
000 - -
Freeze Frame:
Fault Priority: 1
Fault Frequency: 1
Reset counter: 205
Mileage: 296768 km
Time Indication: 0
Date: 2011.08.12
Time: 00:04:04
Freeze Frame:
Bin. Bits: 10111
Voltage: 11.90 V
Count: 7
Address 28: HVAC, Rear Labels: None
Part No SW: 4L0 910 158 HW: 4L0 919 158 AB
Component: KLIMABETAETIGUNGH06 0060
Revision: 00---010 Serial number: 00000000293140
Coding: 0000006
VCID: 688E60DDFE74368AF73-803C
2 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 205
Mileage: 296768 km
Time Indication: 0
Date: 2011.08.12
Time: 00:43:49
Freeze Frame:
ON
01320 - Control Module for Climatronic (J255)
013 - Check DTC Memory
Freeze Frame:
Fault Status: 01101101
Fault Priority: 2
Fault Frequency: 1
Reset counter: 205
Mileage: 296768 km
Time Indication: 0
Date: 2011.08.12
Time: 00:43:50
Freeze Frame:
ON
Address 36: Seat Mem. Drvr (J136) Labels: None
Part No SW: 4F0 959 760 D HW: 4F0 959 760 D
Component: MEM-FS H08 0064
Revision: AA000000 Serial number: 00000013015459
Coding: 00581B00000011110000
VCID: 323AC2B504288C5A997-8066
Address 3C: Lane Change Labels: None
Part No SW: 4L0 910 566 C HW: 4L0 907 566 B
Component: J0769_SWA_MasterH01 0050
Revision: 00H01000 Serial number: 6PZ 009 014-10
Coding: 0010001
VCID: 2E02D6C51C10A8BAFDF-807A
Subsystem 1 - Part No: 4L0 910 568 C
Component: J0770_SWA_Slave_H01 0050
Subsystem 2 - Serial number: 6PZ 009 014-30
Subsystem 3 - Serial number: 5F19.08.1100H010003C912704ˇ
Subsystem 4 - Serial number: 912704ˇ
1 Fault Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 5
Reset counter: 245
Mileage: 16 km
Time Indication: 0
Date: 2011.08.12
Time: 00:43:45
Address 42: Door Elect, Driver (J386) Labels:. 4F0-959-793.clb
Part No SW: 4F0 959 793 T HW: 8K0 959 793 M
Component: TSG FA H12 0362
Revision: Serial number: 0000012886533
Coding: 011F57205E40440004
VCID: 48CE805D92B4168AD73-801C
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 245
Mileage: 296768 km
Time Indication: 0
Date: 2011.08.12
Time: 01:29:52
Address 46: Central Conv. Labels:. 4L0-910-289.lbl
Part No SW: 4L0 910 289 K HW: 4L0 907 289 K
Component: Komfortgeraet H11 0120
Revision: 0120 --- Serial number: 01556943850000
Coding: 3569693
VCID: 382EF09DEE54660AA73-806C
Subsystem 1 - Part No: 1K0 951 605 C
Component: LIN BACKUP HORN H05 1501
2 Faults Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 19
Reset counter: 245
Mileage: 296768 km
Time Indication: 0
Date: 2011.08.12
Time: 00:01:43
Freeze Frame:
Fault Priority: 3
Fault Frequency: 3
Reset counter: 245
Mileage: 296768 km
Time Indication: 0
Date: 2011.08.12
Time: 00:03:33
Address 47: Sound System (J525) Labels: None
Part No SW: 4L0 035 223 H HW: 4L0 035 223 G
Component: BOSE G3 Q7 H03 0130
Revision: CH003000 Serial number: 00000000009532
Coding: 030000
VCID: 270C23E13FEAF9F23E9-8072
1 Fault Found:
03278 - Functionality Limited due to Missing Messages
Freeze Frame:
Fault Priority: 6
Fault Frequency: 4
Reset counter: 245
Mileage: 296768 km
Time Indication: 0
Date: 2011.08.12
Time: 00:44:07
Freeze Frame:
Bin. Bits: 00001000
Address 4C: Tire Pressure II Labels: 4F0-910-274.clb
Part No SW: 4F0 910 274 B HW: 4F0 907 274
Component: J793 RKA+ H04 0110
Revision: 00000519 Serial number: 00005190106726
Coding: 0758477
VCID: 231437F147D215D2621-8076
4 Faults Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 245
Mileage: 296768 km
Time Indication: 0
Date: 2011.08.12
Time: 00:43:49
Freeze Frame:
Hex Value: 0x0000
Hex Value: 0x0000
Hex Value: 0x0001
Voltage: 12.80 V
Temperature: 15.0∞C
(no units): 0.0
013 - Check DTC Memory - MIL ON
Freeze Frame:
Fault Status: 11101101
Fault Priority: 3
Fault Frequency: 9
Reset counter: 205
Mileage: 296768 km
Time Indication: 0
Date: 2011.08.12
Time: 01:14:08
Freeze Frame:
Hex Value: 0x0000
Hex Value: 0x0000
Hex Value: 0x0001
Voltage: 12.30 V
Temperature: 15.0∞C
(no units): 0.0
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 245
Mileage: 296768 km
Time Indication: 0
Date: 2011.08.12
Time: 00:03:31
Freeze Frame:
Hex Value: 0x0000
Hex Value: 0x0000
Hex Value: 0x0001
Voltage: 12.80 V
Temperature: 21.0∞C
(no units): 0.0
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 205
Mileage: 296768 km
Time Indication: 0
Date: 2011.08.12
Time: 00:43:49
Freeze Frame:
Hex Value: 0x0000
Hex Value: 0x0000
Hex Value: 0x0001
Voltage: 12.80 V
Temperature: 15.0∞C
(no units): 0.0
Address 4F: Centr. Electr. II Labels: 4F0-910-280.lbl
Part No SW: 4F0 910 280 HW: 4F0 907 280 D
Component: ILM Beifahrer H14 0100
Revision: Serial number: 00000000095857
Coding: 0012001
VCID: 5EE246052C30783A0DF-800A
3 Faults Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 5
Reset counter: 245
Mileage: 262136 km
Time Indication: 0
Date: 2011.08.12
Time: 00:43:00
Freeze Frame:
Voltage: 12.800 V
Temperature: 21.0∞C
Freeze Frame:
Fault Priority: 3
Fault Frequency: 5
Reset counter: 245
Mileage: 262136 km
Time Indication: 0
Date: 2011.08.12
Time: 00:03:00
Freeze Frame:
Voltage: 12.700 V
Temperature: 77.0∞C
Freeze Frame:
Fault Status: 00110010
Fault Priority: 3
Fault Frequency: 1
Reset counter: 245
Mileage: 262136 km
Time Indication: 0
Date: 2011.08.12
Time: 01:30:00
Freeze Frame:
Voltage: 7.200 V
Temperature: 77.0∞C
Address 52: Door Elect, Pass. (J387) Labels:. 4F0-959-792.clb
Part No SW: 4F0 959 792 T HW: 8K0 959 792 M
Component: TSG BF H12 0362
Revision: Serial number: 0000013387741
VCID: 47CC83619FAA19F2DE9-8012
2 Faults Found:
02126 - Central Locking Button; Exterior Door Handle
Freeze Frame:
Fault Priority: 3
Fault Frequency: 6
Reset counter: 205
Mileage: 296768 km
Time Indication: 0
Date: 2011.08.12
Time: 00:43:50
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 245
Mileage: 296768 km
Time Indication: 0
Date: 2011.08.12
Time: 01:29:52
Address 55: Headlight Range Labels: 4F0-910-357.lbl
Part No SW: 4L0 910 357 B HW: 4L0 907 357 B
Component: AFS 1 H01 0010
Revision: 00000001 Serial number:
Coding: 0000031
Subsystem 1 - Part No: 7L6 941 329 A
Component: AFS-Modul links H07 0004
Subsystem 2 - Part No: 7L6 941 329 A
Component: AFS-Modul rechtsH07 0004
2 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 205
Mileage: 296768 km
Time Indication: 0
Date: 2011.08.12
Time: 00:43:51
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 205
Mileage: 296768 km
Time Indication: 0
Date: 2011.08.12
Time: 00:03:30
Address 56: Radio (R) Labels:. 4F0-035-0xx-56.clb
Part No SW: 4G0 035 082 B HW: 4G0 035 082
Component: Radio U SIRIU H52 0076
Revision: AB001007 Serial number: 156I50B7547359
Coding: 020007010000000000
VCID: 1F1C3B0167BA3132469-804A
1 Fault Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
Reset counter: 245
Mileage: 296768 km
Time Indication: 0
Date: 2011.08.12
Time: 00:03:38
Freeze Frame:
Bin. Bits: 00000000 00001100
Address 5F: Information Electr. (J794) Labels:. 4E0-035-6xx-5F.clb
Part No SW: 4L2 035 746 B HW: 4L2 035 746
Component: H-BNT-NA H42 0422
Revision: -------- Serial number: 097I.0B7503442
Coding: 180200060004E3EF51002345EF632003140000000100000000
VCID: 2D00D1C91D16D3A2C45-8078
Subsystem 1 - Part No: 8R0 060 884 AD
Component: NAR 2011 0505
Subsystem 2 - Part No SW: 8F0 919 604 HW: 8F0 919 604
Component: DU7 High H42 0094
Serial number: 9466GT0A0034437
Subsystem 3 - Part No SW: 4L0 919 614 C HW: 4L0 919 614 C
Component: E0380 Bedient H01 0060
Serial number: 00000001906487
Subsystem 4 - Part No: 8R0 060 961 B
Component: CD-Database 3371
2 Faults Found:
03157 - Functionality limited due to Communications Disruption
000 - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
Reset counter: 205
Mileage: 296768 km
Time Indication: 0
Date: 2011.08.12
Time: 07:07:04
Freeze Frame:
Bin. Bits: 00001000 00000000
Bin. Bits: 00000000 00000000
Freeze Frame:
Fault Priority: 6
Fault Frequency: 5
Reset counter: 245
Mileage: 296768 km
Time Indication: 0
Date: 2011.08.12
Time: 00:03:38
Freeze Frame:
Bin. Bits: 00010110 01100000
Address 62: Door, Rear Left (J388) Labels:. 4F0-959-795.clb
Part No SW: 4F0 959 795 P HW: 4F0 959 795 P
Component: TSG HL H11 0362
Revision: Serial number: 0000013005192
Coding: 010E57204040230004
VCID: 46D28E6598A000FA25F-8012
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 245
Mileage: 296768 km
Time Indication: 0
Date: 2011.08.12
Time: 01:29:52
Address 69: Trailer (J345) Labels:. 4E0-907-383.clb
Part No SW: 4E0 907 383 J HW: 4E0 907 383 J
Component: Anhaenger H09 0100
Revision: 2A001001 Serial number: 00000156551204
Coding: 0200000000000000
VCID: 3138CDB9012EB742E0D-8064
3 Faults Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
Reset counter: 245
Mileage: 296768 km
Time Indication: 0
Date: 2011.08.12
Time: 00:01:41
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 245
Mileage: 296768 km
Time Indication: 0
Date: 2011.08.12
Time: 00:03:31
00532 - Supply Voltage B+
011 - Open Circuit - Intermittent - MIL ON
Freeze Frame:
Fault Status: 10101011
Fault Priority: 3
Fault Frequency: 1
Reset counter: 245
Mileage: 296768 km
Time Indication: 0
Date: 2011.08.12
Time: 00:01:17
Address 6D: Trunk Elect. Labels: 4L0-910-945.clb
Part No SW: 4L0 910 945 HW: 4L0 827 851 E
Component: ValeoHeckdeckel H57 0500
Revision: --H57001 Serial number: E5030000B
Shop #: WSC 98765 666 38354
VCID: 6C861CCDEA8C1AAA93B-8038
Subsystem 1 - Part No: 4L0 910 946
Subsystem 2 - Serial number: E5030100B
Subsystem 3 - Serial number: RD08.09.11--H57001001A0268ˇ
Subsystem 4 - Serial number: 1A0268ˇ
Address 6F: Centr. Conv. II Labels:. 4L0-910-290.lbl
Part No SW: 4L0 910 290 A HW: 4L0 907 290 A
Component: ILM HINTEN 2 H07 0080
Revision: AAH07080 Serial number: 118895293-----
Coding: 0003595
VCID: 26122EE534E0E0FA05F-8072
Subsystem 1 - Part No: 4L0 910 591 A
Component: J_245_EE16_SKB10H11 0220
Subsystem 2 - Part No: 4L0 910 591 A
Component: J_394_EE16_SKB10H11 0220
Subsystem 3 - Part No: 4L0 910 591 A
Component: J_392_EE16_SKB10H11 0220
3 Faults Found:
02906 - Control Module for Sliding Roof; Rear (J392)
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 205
Mileage: 296768 km
Time Indication: 0
Date: 2011.08.12
Time: 00:44:02
02907 - Control Module for Roof Shade (J394)
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 205
Mileage: 296768 km
Time Indication: 0
Date: 2011.08.12
Time: 00:44:02
01512 - Control Module for Sliding Roof
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 205
Mileage: 296768 km
Time Indication: 0
Date: 2011.08.12
Time: 00:44:03
Address 72: Door, Rear Right (J389) Labels:. 4F0-959-795.clb
Component: TSG HR H11 0362
Revision: Serial number: 0000013005343
2 Faults Found:
008 - Implausible Signal - Intermittent
Freeze Frame:
Fault Status: 00101000
Fault Priority: 3
Fault Frequency: 22
Reset counter: 245
Mileage: 296768 km
Time Indication: 0
Date: 2011.08.12
Time: 00:57:56
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 245
Mileage: 296768 km
Time Indication: 0
Date: 2011.08.12
Time: 01:29:51
Address 76: Park Assist Labels: 4Fx-910-283.lbl
Part No SW: 4L0 910 283 C HW: 4L0 919 283 C
Component: Parkhilfe 8-Kan H03 0500
Revision: 00H03000 Serial number: 37361123701717
Coding: 0231266
VCID: 2A0ADAD520F8C49A217-807E
1 Fault Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 5
Reset counter: 245
Mileage: 296768 km
Time Indication: 0
Date: 2011.08.12
Time: 00:44:05
End----------(Elapsed Time: 02:35, VBatt start/end: 12.1V/12.1V)-----------
Just to clarify, everything with a wired connection on this car...doesn't matter what it is; a sensor/ECU/Battery, etc., that you've disconnected on your car is generally going to create a trouble code in some control module simply because you disconnected it. In the case of the battery or major components, such as the ECU or other control modules, disconnecting those will create trouble codes for everything that lies beneath their 'umbrella of control'...that they are connected to or monitor, etc. Reconnecting items again does not remove the stored fault/error codes from a control module, which often will have negative impact, as the car still thinks something is wrong. This is pretty huge deal when talking about no-start conditions, as this car's ECU monitors so many data point and feedback loops.
The first thing you do when working on this car is scan it fully to see what the car can tell you about what is wrong, which also gives you a baseline to work from. After working on this car, the first thing you do is clear any fault codes that popped because of what you disconnected/reconnected, etc., so this would be compensating for what errors you created while working on the car.
Once you've cleared all codes post-repairs or services to restore parity, then you do a complete auto-scan to see if anything returns as a hard code (active, intermittent, etc., but not going away), and that's what we mean by give us a 'clean, full auto-scan' to look at.
There's also some great VCDS videos online for how to use most effectively, as well as focused on use of both basic and more advanced diagnostic functions. You don't have to figure it out...there's lots of VCDS support / educational how-to info on the internet, and I've watched several of these to expand my personal understanding of how to use it more effectively.
Look forward to reviewing a clean auto-scan.
