Audi A8 D3 Rear Door Issues
Happy New Year!
It has been a while since I posted on here.
I could really do with some support.
Today I replaced my rear door on my Audi A8 d3 as the one that was fitted had several dents which was to much money to get repaired. The donor car is from year 2005 and mine is a 2003 and the new door came with everything fitted, handle, lock, window motor and Bose speaker. I fitted the door and then started the car but the window would not work and the door will not lock. I scanned the car and got an error code 01333 issue with rear left door control module (J388). Does anyone know if I need to code the door to my car? If I do does anyone know how to do this? Thank you so much.
Happy New Year!
Thank you for your reply.
I have swapped over the window motor this morning which I believe also has the door module integrated into it and it did not work.
Do you think the lock actuator also needs to be swapped over?
Thanks.
Balsapal.
Thank you for your message.
I have swapped the wiring loom from the old door to the new door and everything thing works. The only issue is that the door keyless door handle won’t lock but it will open. It must be a broken button on the handle.
Thank you to you all for your support.
