Transmission Leak(s)
The fault code and it was 009987 (I will attach photo of the VCDS printout).
This afternoon I went under the car to get a better look at my leak. Here are some photos:
The connector feels physically damp/wet. The drain port has a drip.
I am struggling with the oil here. Both the weep hole that is half moon shape and the little one under the lines appear dry.
I got the car up and to my eye level to check the trans fluid. It is Lifeguard 8 and was done 40,000 miles ago. I was a bit surprised as about a cup came out the moment I removed the plug. I was surprised by the color - more of a muddy brown and it had lost all trace of the green.
The flywheel is absolutely dry, a q-tip into the half moon drain hole yielded some black but nothing brown and wet, the small circular hole was similar. But, I can't see how fluid would migrate to that area from the harness seal(?). The belly pan shows a fair amount of fluid directly under the connector an very little in the center.
Any thoughts?
My question is: to replace the harness seal am I dropping the Mechatronic unit in addition to the pan? Or can I get to it just by removing the pan?
I drained the old fluid into a Rubbermaid tote lined with a contractor grade plastic bag. Between this and the pan, I would guess I got 2.5l out if that. For whatever reason, I got every Torx wrong. The pan were T-27 and the Mechatronics were T-40. Once the Mechatronic unit was out replacing the seals on the sleeve was easy. In retrospect, I should have ordered a new sleeve, mine was covered in sand and grit on the outside part of the sleeve. I also replaced the bridge seal and filter. The magnets after 40,000 miles seemed pretty clean; only a thin film of material was present. No porcupine, nothing thick.
I had cleaned out my Motive brake fluid pump in anticipation of using it for the fill but bailed out thinking I would never clean it out. I wound up using a large funnel at eye level on my bike stand plus some hose, clamps and a little hook shaped fill tube from FCPEuro. It was a helluva mess and something I will not repeat. We still ended up with 3 unused liters and maybe got 4.5-5 in?
The car is buttoned up. I still have what I would call "hard" shifts between 1 & 2 and 2 & 3 when the car is first started. Once it is warm, if shifts beautifully.
No more leaks on the garage floor either.
