EPC and traction control light intermittent
Old May 28, 2026 | 04:50 PM
Mikeb2006's Avatar
Default EPC and traction control light intermittent
Recently my A4 (3.0) has developed an intermittent limp mode (EPC and traction control light) I got codes on my obd2 scanner for accelerator pedal low voltage and promptly replaced the pedal.
This did not work so I got it scanned at an audi specialist who suggested an issue in communication between the ecu, throttle body and gas pedal. considering it can be reset by disconnecting the battery I was confident it wasn't a wiring issue and got a replacement throtle body which also did not fix the issue.
At this point I am going to bite the bullet and let an Audi specialist diagnose the issue, but I was also interested in hearing other possible solutions from seasoned Audi owners.
I can also confirm this is not the brake switch as the brake lights do not come on when the dash lights do.
Old May 28, 2026 | 08:46 PM
Cybersombosis's Avatar
What is the code the car is throwing?
Old May 31, 2026 | 08:23 PM
Mikeb2006's Avatar
code is 18047
Old Jun 1, 2026 | 04:48 PM
I hate to say it but it looks like the only thing left is the ECU if you’ve done the throttle body and the pedal and you don’t suspect the wiring.
Old Jun 4, 2026 | 04:08 PM
Mikeb2006's Avatar
Update, After unplugging the ECU and cleaning with wd40 contact cleaner I have no longer had limo mode come back on. This is the longest it has gone without coming back on, so fingers crossed it works out.
SimeonGS
A4 (B8 Platform) Discussion
May 26, 2022 12:23 AM
Chrisw83
Q7 MK 1 Discussion
Oct 15, 2021 08:39 PM
leveTT
TT (Mk1) Discussion
May 16, 2008 05:58 AM
EighTT
TT (Mk1) Discussion
Oct 31, 2005 10:26 PM
BobT(nolonger)A6
Feb 9, 2001 09:44 AM
