Heater fan, AC
Do others have the same experience?
And worse, the air that come out is HOTTER than the outside air (AC not running; I don't like to use the AC unless it is really hot outside).
a) why is so little air volume/speed coming out of the vents? Has someone tried to upgrade (larger volume fan?)?
b) is assume the (no AC) air is getting hot since the piping is not insulated and/or too close to the hot engine bay? Is there anything that can be done? Or is the fresh air INLET sucking in hot engine bay air?
c) any suggestions to improve the situation?
Plugged cabin filter is unlikely if this just began out of the blue, but I change my filter annually anyhow...just for allergies.
If you verify the fan runs normally and changes speeds with manual control use of fan set speed, then suspect the doors aren't opening correctly, so the air just isn't routing properly. Need VCDS or similar if you want to activate and do a system blend doors test, etc., but just be sure to verify diagnostic scan / no faults exist, etc, before you go down any rabbit holes.
