2007 S6 AC pressure sensor replacement help
Old Jun 13, 2026 | 08:49 AM
marcika8001's Avatar
Default 2007 S6 AC pressure sensor replacement help
Hey,
AC stopped working in my 2007 S6. We have checked it, the pressure is perfect on the H and L side too. I mean phisycally perfect.
The error code it throws is the 00256. In real time data, the sensor reports absurd numbers 50+ bars, so I thought this would be worth a shot to replace the sensor.
So, I removed the bumper already, and I am at the sensor. Shaking the cables a bit and clean the connector did not have any effect. But, I am not sure, how to get it out. Should I loosen that 16mm one that I marked by the arrow? Or the sensor starts only at the green line, and should come out after the 16mm screw? I don't want to accidentally loosen the valve itself and lose all coolant...
Thanks a lot for the advices!
Old Yesterday | 06:15 PM
das60's Avatar
That is not the OE sensor. It is what I had on mine. IIRC it can be removed without unloading the system. Mine sheared off as it was corroded. I wound up replacing the condenser, dryer and sensor. The correct sensor has a 24mm set of flats. PIA
Old Yesterday | 10:01 PM
Hey,
What do you mean not OE?
And yeah, I was looking for a 24mm one too, but this is the only sensor there, connected to the condenser. The connectior plug seems to be identical to the 24mm version however. My only idea is, that maybe it is different because it is an S6 and not an A6?
bagged_gti
Q5/SQ5 MKII Discussion
Mar 26, 2026 01:40 PM
Kmuni
A4 (B8 Platform) Discussion
Jul 20, 2024 09:07 PM
DanAudi-A4
A4 (B9 Platform) Discussion
Nov 13, 2021 02:14 PM
UrS4boy
Audi Original "S" Cars
Oct 18, 2008 03:08 PM
DJ Springer
Misc. Models Discussion
Dec 28, 2000 03:49 PM
