21" OEM+ with D4 S8 Wheels
Old Jun 13, 2026 | 06:00 PM
virtualrc's Avatar
Moderator
Default 21" OEM+ with D4 S8 Wheels
Looking for feedback from anyone running OEM Audi 21" wheels on a B8/B8.5 A5/S5. I have a 2011 S5 Coupe (4.2 V8, 6MT) and I'm considering a set of OEM Audi S8 wheels for an OEM+ look.
Wheel specs:
  • Audi OEM Part #: 4G8601025AR / 4G8601025AQ
  • OEM application: 2017-2018 S8
  • Size: 21x9
  • Offset: ET35
  • Bolt pattern: 5x112
  • Center bore: 66.6mm
From what I've been able to determine, these should be a direct fit:
  • Same 5x112 bolt pattern
  • Same 66.6mm center bore
  • Width increases from 8.5" to 9"
  • Offset changes from ET32 to ET35
I'm planning on running a 255/30R21 tire.
I've attached a quick rendering of how they might look on the car. My goal is not a show-car or stance build. I'm after a clean OEM+ appearance using genuine Audi wheels. What I'm hoping to hear from people with actual experience:
  • Are you running 21s on a B8/B8.5 A5/S5?
  • Any rubbing issues?
  • Any suspension clearance concerns?
  • How much harsher is the ride compared to 19s?
  • Any regrets going to a 21?
  • If you went back, would you choose a 20 instead?
I understand the theoretical fitment side of things. I'm mainly looking for real-world feedback from owners who have lived with 21s on these cars.
Thanks!
May be an image of car and text
Old Jun 13, 2026 | 11:39 PM
Lavender speed.'s Avatar
Should fit. and ride like a skateboard.
Not 21's but my car had "hot wheels" worthy 20's and was static slammed. switched to 19's with a mean inset. no issues. - not even close to any arms or shocks
I'm only concerned that you'll rub the fenders. Because inside? plenty of space.
Same suspension architecture should be fine. with updated rims and tires. can you test fit?
Old Yesterday | 06:43 PM
virtualrc's Avatar
Moderator
Thanks for the reply. Unfortunately no options to test fit. I'd have to shell out some bucks for at least one wheel/tire setup and mock up. Maybe if I see some take-offs on FB locally I could arrange a test fit.
When you say ride like a skateboard I assume you mean harsh. Someone else said it'd ride like s*!t.
Santorin Drm pig pal
Jan 20, 2016 03:20 PM
mavila
Wheels & Tires Discussion
Aug 10, 2008 10:21 PM
xlerate93
Sep 22, 2005 10:57 PM
s4rePreSenT`
Jun 26, 2003 10:54 AM
