BMS and charging
Old Jun 17, 2026 | 08:01 AM
zen beer's Avatar
Default BMS and charging
quick sanity check and guidance. I took the S8 in to get the windows tinted. While there they hooked up a charger to positive and negative battery posts not the grounding post. When I went to pick up the car after it had been sitting for an hour or two it was no start and click instead of crank for one time and then the car was completely dead with no lights at all and really low battery voltage 2.3v. I disconnected the battery until I could come back with VCDS and check everything. Car sat overnight and battery had recovered to 10.1V so hopefully not ruined. Connected negative battery cable and voltage dropped as expected systems came on but no start no crank as expected.I jumped it properly to get it home and it is on charge now. Question I have is did they break my BMS and is there a 100% certain way to test it? Or is it ok to charge direct via battery which I don't think is the case
Old Jun 17, 2026 | 06:42 PM
dvs_dave's Avatar
AudiWorld Wiseguy
Oh jeez, this old chestnut again. Why was a window tint place hooking up a battery charger? WTF were they doing?
Anyway, they’ve blown the battery management module by connecting direct to -ve battery terminal, and not the jumper post.
Read the user manual and/or google to find out the proper way to do it.
Old Jun 17, 2026 | 07:24 PM
zen beer's Avatar
Yeah I went oh F! As soon as I popped the trunk and saw the battery compartment open. I knew what had happened. I was just hoping a charger wasn't enough to blow it.
Old Jun 17, 2026 | 10:16 PM
dvs_dave's Avatar
AudiWorld Wiseguy
Whatever they were doing, they probably actually hooked a jump pack up to it, and then got a case of amnesia.
Geo57
A4 (B8 Platform) Discussion
Mar 2, 2023 09:00 AM
gh0st
Jan 12, 2009 12:21 PM
Yukonr
Mar 3, 2005 08:57 AM
