- Want openpilot on your B8? Looking for testers!
- All New Stance SF11 Rotary Forged - Light Weight Design - Wheel Designers
- New Member needs tips/ -2012 V6 3.0T . with 150miles/ 250k¨
- 2016 S4 won’t crank after hpfp install
- CEL Cooling error code P218100
- Smoking/oil consumption /high presume at oil cap After changing aftermarket/China PCV
- Smoke coming from exhaust of my B8.5
- Question about B8 S4 reliability
- Unknown S4 Tune (B 8.5)
- 20% off NEW D3S/D1S LEDs FOR 2023 –Bright - NO ERRORS - PLUG & PLAY - NO wires!
- 2014 s4 6mt transmission question.
- Stage 2 Velocity AP
- Upgrade to a B8 Audio - recomendations?
- Tcm issues
- Transmission control unit failure
- Audi S4 2014 DSG Transmission Issue, Slight grind when downshifting from 4th gear?
- B8 transmission problem
- Duel pulley failure
- Newbie to Forum Looking for catback exhaust options?
- Supercharged badge
- Vossen Wheels Black Friday Starts 11/20 to 12/2 While Supplies last
- Spark plug replacement, is this normal wear?
- 2009 s4 avant 3.0. Transmission fault
- Looking for OEM Air Intake
- Door sensor only works when I’ve just stopped the car
- Strut wont compress
- BLACK FRIDAY SALE 11/1 to 12/2 While Supplies Last - Stance Wheels
- Remove electric seats without electric power....?
- 2014 Audi s4 side mirror assist fault
- Crank Sensor Position
- B8 S4 Possible Head Gasket??
- B8 S4 Questions
- Weird Suspension Noise
- CCB engine swapped into CGX but old ECU remained.
- Using Audi A4 headlights for an S4??
- 2010 B8 S4: Need Help Diagnosing Possible Engine Noise
- UK: Likelihood of Rear Main Seal Failure?
- CPO Warranty claim
- "Audi A4 S 2009 2.0 TSFI" severe oil consumption/burning.
- Idle shaking pipe and coolant leak
- Audi S4 DSG in limp mode
- Alcon rear brake calipers
- Buyers Guideance
- B&O Subwoofer Replacement
- Audi S4 Fault codes
- Ac doesn't work and Engine burns 1 quart in less than 1,000 miles
- Is my engine done?
- 2010 S4 Tire Pressure Monitoring System (TPMS) Control Module
- B8.5 S4 Fuel Gauge issue
- Thinking of selling my S4. How much can I get for it?
- Help identify these "extra" bolts?
- FORGEDLITE Wheels - 1pc Monoblock & 2pc Modular Forged Wheels - WHEEL DESIGNERS
- All New Klassen ID F07R Form+ Light Weight Design Wheels - Tailored for Each Vehicle
- Is this normal color of oil?
- What To Look Out For Before Buying a 2010 Audi S4?
- S4 vs S5
- weird boiling sound by supercharger
- Rohana RFX Series Cross Forged Wheels - Special Member Pricing!
- water meth
- 2013 S5 - Timing Chain check
- 6-Speed Manual S4 for-sale in classifieds....
- Replacing starter on 3.0T w DSG Any instructions available?
- Coolant Issue! 2014 Audi S4
- B8.5 koni sp active strut issues.
- 2015 s4 rear shocks replacement
- Battery overcharging at 17 volts? Voltage regulator?
- The 034Motorsport SummerFest Dynamic+ Sale Is Here at PartsByTopher!
- A/C Valve N280 VCDS logs question
- S4 2010 Stalling when immediately brought into gear (DSG)
- New clutch / friction plates?
- Question: Audi Pure Protection - PLATINUM COVERAGE PLAN
- 2011 S4 Mechatronic
- 2013 B8.5 Premium Plus potential part out
- 2012 S4 hard to put in gear
- Leak from behind rear diffuser?
- UK: What wheel options are available for me? 😁
- Possible timing chain?
- Will these wheels specs fit my 15' s4 ?
- New Motor Mind Games?
- New motor mind games
- NO: Audi S4 b8 3.0 tfsi P20070 feil code
- what camber #ers do 034 springs provide?
- DSG issues with high ambient temps
- DSG skipping odd gears
- Dead key fob
- Audi A4 B8.5 S4 changed to Rs4 Quattro grille
- B & O speakers
- s4 wont start
- My first s4 2012 (possibly)
- B8 s4 mechatronic repair failure
- LED License Plate Lamp Impedance?
- Should I do the Intake or Tune first?
- Problem DL501
- B8.5 s4 (DSG) EPC
- B8 s4 clutch slipping with 20k km on clutch and flywheel
- Whirring noise only with gas pedal
- Strange issue with radio/audio
- 2012 S4 Bluetooth Phone Connection
- Help music bluetooth etc
- 2014 S4 - Advice on transmission repair options
- Stance SF01 SF03 SF07 SF10 SF11 Rotary Forged Wheels - WHEEL DESIGNERS
- Avant Garde M580R Light Weight Design 19" 20" 21" - WHEEL DESIGNERS
- 2014 Audi S4 Headlight Issues (Help Please!)
- Audi MMI not working!
- 2010 s4 transmission fluid change?
- WTB: two Pirelli Cinturato P7 tires (AO Audi 245/40R18 93Y)
- Vossen HF1 HF2 HF3 HF4T HF5 HF7 - WHEEL DESIGNERS™
- UK: Please HELP !! info on new Loaded S4
- S4 Injectors/Leaking Supercharger Intercooler?
- Audi S4 Muffler Delete Kit using AWE Touring-to-Track?
- 2012 s4 automatic engine removal
- Autotech HPFP (WORKING WITH PROOF)
- should I keep it? wife totaled S4
- Is this timing chain rattle?
- Options to look for?
- Rear tire hop caused when doing a u turn (sport diff problem?)
- Audi s4 b8.5 cylinder 3 P0303 misfire
- S4 Coolant Loss and Cylinder Misfire
- Dashcam footage of Audi S4 B8 3.0T Customer Car Abuse by VAG Technic in Dudley, UK
- Piggyback
- S4 Widebody Help
- ABS incorrectly coded, help
- Timing chain bad or has it jumped?
- Clutch kit replacement.
- How to connect heated windshield wipers?
- VR Performance Exhaust special
- Considering a S4
- Need help figuring out what’s causing this sound
- XENON - HEADLIGHT BULB UPGRADE HELP
- No heat
- B8 S4 Won’t crank, only turns on fans.
- B8 S4 Mechatronics issue or mechanical?
- 2010 S4 B&O cutting out
- Radio module question MMI
- getAudiparts.com | Your 2021 Black Friday/Cyber Monday Savings are HERE!!!
- Considering 2013 S4 with 84k - Need Expert Help!
- Low fuel rail pressure.
- getAudiparts.com | Genuine Audi Floor Mats Sets!
- seeking good Audi shop in L.A.
- Audi S4 B8 whining under acceleration
- EPC light at redline
- 2010 S4 burning oil?
- 2011 s4 burning oil out exhaust
- New 2012 S4 owner
- Audi S4 B8.5 Timing Chain Rattle (Oil Check Valves???)
- 3.0 TFSI Can engine rattle because of bad PCV valve?
- MY: B8 S5 3.0 A/C not working.
- S4 3G MMI Fault
- Found this bolt from my car
- Coolant leak on S4 - being quoted $1800-$3000 !?
- pulsating pedal vibration at 110km/h (70m/h) B8.5 S4
- Can a 2012 sport diff be rebuilt??
- Replacement S4 grille
- Replace 2012 sport diff with salvaged sport diff?
- Mirror Replacement for 2012 S4
- 20136 - PCV Valve Malfunction Code no CEL only shows on VCDS
- B8 S4 Part Out Worth
- Over-revs & Gear Ratios
- Water Pump Failure followed by Thermostat
- Swapping amp out on B8 Audi S4
- Weird tail/brake light issue
- Ticking noise in my 2012 S4
- Do I really need the Sport Diff?
- How to make your AC cold again
- Need Advice with Rear Speakers not Working
- Mmi issue
- Belts broke off and shredded. Any guides to help me fix jt?
- parts manuals B8-S4
- MMI controls location: dash vs center console
- BRAKE warning light
- 2013 Audi S4 Moldy Smell from A/C
- 2010 S4 Cats
- Dsg transmission noises
- Audi S4 ECS Tuning intake
- 2011 S4- Intake runner flaps stuck closed on both banks
- DE: Coolant level too high
- 2014 B8.5 S4 noise at front of engine
- DOOR UNLOCK CONTROLS-LONG STORY-NEED HELP
- Mmi failing?
- s4 b8.5 - stock going to stage 2+ single pulley (s/c) Unitronic - any thoughts?
- Loose rubber pipe coming from a radiator?
- I need help with 2012 Audi s4
- P0018 code post cam chain tensioner replacement
- 09 S4 License Plate Light Camera help
- Sport differential fluid change?
- Rough starts from stop position - 2010 Audi S4
- Nasty Scratch - (Scratch remover recommendation)?
- 2012 S4 in car timing tensioner replacement
- Unlocking and Locking
- Advice on buying a 2012 Audi S4 Prestige
- P2007 and P2006 engine codes?
- ECP and Check Engine Light
- Looking to add a little balls
- Trunk Lid Liner Removal
- ECU tune and CA smog?
- B8 Power Steering Flush / Reservoir Screen
- B8.5 s4 17psi max boost
- Misfire and engine light
- b&o mmi replacement
- GROUP BUY | Schwaben Professional Scan Tool 25% to 40% off | Closes April 1st, 2021
- 2012 S4 w/o B&O: any audio upgrade options?
- Blue liquid and water in boot/trunk of 2015 S4 (Help)
- Audi S4 2015 Making Weird Noises.
- Issue with accelerator pedal
- It'S PeRforMaNCE wEeK! up tO 25% Off yOUr FAVoRiTE BraNDs!
- Smoking under hard acceration 2012 b8
- What is this pipe behind the engine going into heat shield?
- Buying 2011 S4 with 89k km (55k miles)
- Replacing Rear Left Outer Taillight
- 2018 S4 Scheduled Maintenance- Necessary ?
- Light vibration/clunk when doing slow turns
- What to look out for when test driving?
- Considering an S4
- What’s after the ultra charger?
- Retrofit/After-market Dynamic Suspension options
- S4 engine noise under load 90 and above
- Urgent feedback needed - 2011 S4 Failed Clutch Slave Cylinder. Need advice
- Looking for a reputable Indy shop in central NJ
- Audi s5 dsg problem
- Monitoring Injector PW
- Does this S4 have a B&O system?
- getAudiparts.com | Last Minute Holiday Savings Promo Code: HOLIDAY2020
- Audi 2011 S4 A/C Pressure switch - pigtail wiring colors
- how to Tune-up your Audi A4/s4 b8/b8.5
- S4 Engine trouble
- 2011 S4 wiper problem
- deAutoLED Black Friday and Cyber Monday sales are LIVE NOW! Best prices of the year!!
- coolant flush
- AWE Black Friday 2020
- I’m having issues with my 2010 s4
- 3.0T Engine Swap Q7 to S4??
- B8 S4 Lurching Issue Please Help
- NG: Audi A$ vs S$ ?
- New s4 owner here (B8) - couple of quick questions
- S4 B8 Louder
- CZ: Audi S4 suspension issue?
- Looking to sell S4 wheels & tires - New
- Side Mirror Popped Off
- Is it possible to disconnect speedometer/odometer wires from engine/transmission?
- Control arms
- Introducing OEM Folding Mirror Packages...
- 2010 Audi S4 idle issue
- Need advice; a full rebuild..
- Rack and Pinion
- How to get missed error code
- B8 S4 Shocks
- Receiving text messages
- Reco wanted - Tire pressure on Michelin PS 4 S?
