- Replacing/Repairing Head on 3.0T in B8 S4
- 3.0T Exhaust Valve Failure - Anyone Else Seen this??
- B8 Cyl 3 Misfire
- Help - Terrible Smell
- 2012 S4 ZF Trans Swap
- Please turn on the ignition to configure the selected system
- Headlight Range Control module no signal/communication error
- 2013 B8.5 S4 key not recognized at all, ignition will not turn on HELP!
- D3S LEDs - brighter than xenon - cleaner white - instant on - no errors
- Buying a Used S4 w/ 75k Miles
- Rear main leak
- Introducing the SCT X2R In-Line Performance Device for 2007–2016 Audi S4 (B8) 3.0 TFS
- Intermittant Misfire on 2011 3.0T B8 S4
- Oring in Ignition Coil Hole
- Right Swivel Module mechanical malfunction
- Fuel issue after maintence
- B8.5 injectors
- Intake manifold problem
- An S4 body repair
- Upgrade Your Audi S4/RS4 with the Ultimate 12.3" Android Screen! 🚗💨
- B8.5 S4 trouble starting
- Unknown Lines
- The Infamous 1.8–2K RPM Vibration… but Mine’s Exaggerated
- B8.5 S4 Suction Sound When Unlocking Door
- High mileage V6 engines here?
- Coolant full flush
- Should I buy this
- B8.5 rpm stutter issue
- Car won't start
- Discuss the 2009-2016 Audi S4/RS4 Carputech Kit for CarPlay and Android Auto
- Need thoughts - Bushing update and other refreshes
- Steering rack replacement audi s4 b8.5 compatibility
- Shifter Stuck in Neutral?
- Timing Chain condition lookup VCDS
- Rear cabin lights won't turn off - staying on dim
- NEED ADVICE ON POTIENTIAL PURCHASE
- Question for 2013 S4 owners
- Knocking sound coming from engine. Please help identify
- Broken Rear Subframe Mount
- CAP inserts
- Where is this oil leak from?
- AUDI S4 B8.5 WONT MOVE
- Parking Brake Malfunction + ABS Error – Audi A4 B8
- 2011 S5 Cabriolet with 3.0 CCBA engine Valve Covers
- Crankcase vacuum spec for 2016 USA S4?
- Best MMI upgrade
- Wheel offsets
- Help identifying part
- For Audi A4 S4 RS4 2008-2018
- Will B7 RS4 Wheels fit a B8 S4?
- Brake noise
- Air Conditioning Stopped Working - Need Help
- 2012 S4 Seized - Next Steps
- 2013 B8.5 tuning question
- Rough downshift form 2-1 on Audi s4 b8.5
- 3.0 TFSI Still Using Oil - PCV Replaced
- Guidance please on service items for RS4 - just bought
- 2 pin plug
- Clutch slipping on 2013 7spd DSG
- Is my trans cooked?! DSG gearbox & parking brake malfunction
- Continuous Ticking Noise From Engine After PCV Failure
- 2011 S4 with Stasis performance package
- 2016 B8.5 S4 Throwing codes P0172 & P2247
- Just picked up a 2012 6MT with 135,000
- Headlights don’t work when the temp is below +2 Celsius
- Hardwire Dashcam for B8.5 Audi S4
- 2011 S4 gearbox malfunction pls help!!!!!!!!
- Audi s4 3.0t
- Xenon headlight issue after bulb replacement
- oil use?
- P0301 Cylinder 1 Misfire b8.5 3.0T
- Audi motor blown
- Key programming
- B8.5 DRL query
- AirBag light and ParkingBrake light
- B8.5 S4 with sport diff
- Evap purge plug
- sagging headliner
- B8.5 S4 - 58k miles - Keep or let go?
- 2012 Audi s4. ( cooling fan stay on even when engine is cold)
- 09 B8 s4 warning lights on dash in hot weather.
- Exhaust suggestions.
- 2015 S4 - 7th Service (Major)
- S4 B8 6MT Reverse gear problem
- 2010 Audi S4 advice
- Clunking Noise from DSG
- B8.5 S4 clutch master cylinder
- problem with my driver door s4 (b8)
- 2015 Audi S4 6MT Input Shaft Bearing Failure - video short of rebuild
- 2013 s4 B8.5 making clunk sound
- Bad rich/chemical exhaust smell
- Coolant Leak driving me insane
- S4 ccb engine
- sudden stiff steering 2013 b8.5 s4
- Audi s4 2013 won’t start
- B1S1 sensor and rich codes
- Strange timing readings after major work
- Timing and misfire codes, (P0018) also an ECU code (U1008)
- Wheel bearing help
- 2014 S4 with P164B code - Need Help
- audi s4 b8.5 carbon fiber trunk?
- Removal of Andream, what to do with FTC board?
- NO: DESPERATELY NEED HELP WITH TIMING CHAIN JOB!
- A/c
- Door wont open from inside or outside
- intermittent p2006 12 s4
- 2015 Audi B8.5 S4 6MT Transmission Fluid Change how to tips
- B8.5 S4 MMI/Amp Problems
- B8.5 s4 2014 6mt 197,800 pissing all coolant out front of motor
- clutch and flywheel replacement
- dl501 center differential housing bolt size?
- Intake flaps
- RS: Audi S4 B8 battery replacement?
- Widest tire I can use
- Electrical Fault Codes
- Supposed to up shift but down shifted to 2nd smh.
- Oil Pan Drain Plug Mating Surface
- Moderately Researched Mod List - Thoughts?
- S4 B8 All Weather Mats?
- For Sale 2011 S4 Manual 73k miles Boston Area
- Crank no start fuel issue
- 2011 Audi s4 cooling oil valve
- Squeeking Noise Steering Wheel
- EPC Light - On and Off - 2010 S4
- Feeler: B8 S4 DSG Prestige Sport Diff with 48k miles NO ENGINE MODS
- Post Intercooler Troubles
- Starter does not turn, is my engine locked?
- S4 Grill
- Parts for 2016 S4 Premium Plus (US)
- Multiple warning lights
- Don’t engine coolant/oil Leak!!
- Transmission skipping odd gears
- G13 Coolant Colour
- CarPlay recommendations for 2016 S4 Prestige w 2G MMI
- List of software versions for modules
- 2010 86k vs 2012 97k (more details in thread)
- Keyless entry not working
- About to Buy 2010 One Owner// Warranty Worth it?
- Rough estimate for brakes on 2016 S4
- 2010 S4 BCM1 pinout
- Rear camera not working
- Car starts then dies. Replaced ECU. Did the immobilzer module fail?
- BATTERY RESET.. CAR WONT START OR CRANK JUST FANS KICK IN.
- 20% off our bright D1S / D2S / D3S LEDs! These are brighter than xenon bulbs!
- Remote start for S4
- s4 sat for 1.5 years how do i prep it to start it
- Buyer's Remorse - Suspension Potential?
- 2008 Audi s4 Fuel pressure regulator location?
- Audi s4 b8.5 reverse lights not working
- B8 s4 cost to do pcv valve and valve cleaning together
- Oil leak and coolant leak, PCV valve?
- New Stance SF12 and SF13 in 19" and 20" Sizes - Wheel Designers
- first audi! What options do I want?
- New to me 2013 S4; couple of questions
- 2011 Audi S4 3.0 premium plus "supercharged"
- iD Forged 17"- 20" Japanese Inspired 1pc Forged Wheels
- New Vertini RFS2.2 RFS2.3 RFS2.4 19" and 20" Sizes
- 2016 Audi S4 B8.5 DSG Repair
- Cyl 6 Misfire and Cyl Disabling
- DL 501 DSG Bell Housing Bolts location
- MMI DEAD
- AFS Replacement Headlights
- S4 B8.5 - is this a sport diff?
- 034 motorsport tune
- Christmas Holiday Sale
- Squealing Brakes
- Looking into an s4
- 2011 Audi S4 gearbox feeling hot
- TPMS Gearbox Malfunction - 2010 S4
- BLACK FRIDAY SALE,, SuperSprint Italy
- Questions about the platform and with ownership
- Audi S4 no crank/electronics failing issue
- Battery Cut-off Switch Install ?
- Do I Need a Carbon Cleaning
- Driver Door lower cowl
- audi S4 coding
- Forgedlite Wheels Black Friday Sale 11/6 to 11/27
- S4-8K ESP8.0 HELP!
- B8 S4 issues
- Greetings, first post, looking at buying a 2013 S4
- B8 S4 mechatronic printed circuit boards
- Broken 2015 Audi S4
- NEW 20" Brada Wheels - CX1 AND CX3 FORMTECH Series
- Need new motor suggestions
- Time chain issue ( rattle )
- Replace Rear Sport Differential?
- wet goo leak around front drivers side of engine
- US Rear light to Euro spec?
- RS4 2014 rear Bearing noise from 40-60 mph
- Long Crank- Studder and Shutoff - Codes P0087 P053F and P0057
- Which gen dsg do I have?
- MAF Sensor replacement
- Issues with my 2013 Audi S4
- Good mechanic shop in NorCal near Modesto?
- Surging Idle
- New Member *U0101 code*
- intermittent sudden total power loss at high Speed and rpm
- 207mm Pulley Swap Question
- Terminal 30 U140A00 open circuit RS4 B8
- Help! B8 S4 perplexing coolant leak
- Failed Timing chain: 2010 A4
- Heated seat indicator always on
- b8 s4 not starting
- S4 DSG issue in Drive
- Tom programming? Gateway module? B8.5
- b8 s4 front brake pads
- Hard to shift into reverse when parking brake hasn't been applied
- Intercooler bleed screw port broke
- Overheating
- Bought Used Car, Ding in the Door
- Single cyl misfire HELP!
- Buying - Opinions sought
- American message board members.....
- Parasitic Battery Drain - Findings
- Removing cats
- S4 Factory tune
- IMMO DELETE ON 3.0t engine
- Driver door noise
- NL: Stolen in the Netherlands thursday night
- Greetings from SuperSprint Italy
- PL: wheel size custom? audi s4 b8
- Did EPL tuning in CT. go out of business?
- Center differential sealant/gasket?
- question for anyone who replaced their 3.0tsfi chain tensioners
- Tire problems
- Supercharger Ate Rubber Via Intake.
- B8 RS4 gearbox/reverse issue
- Center differential issues
- S4 B8 JXB SHORT SHIFTER PROBLEM
- 2010 S4 no crank no start
- Competitive Prices on Vertini Rotary Forged Wheels - WHEEL DESIGNERS
- 2010 Audi s4
- Audi S4 2018
- 2015 Audi B8.5 S4 6MT IE Stg 2 Build and Exhaust Videos
- B8 Engine goodies !
- Vossen 20x9.5 et40 wheels
- B8.5 3.0t MMI NOT working....
- Weird noise
- Airbag Error on S4 B8 seats
- Door auto lock and trunk lock problems
- Should my airbags have deployed??
- Should I buy this b8.5 S4 2015 25k and 52k miles with all options I want?
- Can I change Audi rings on aftermarket grille?
- No voltage from the alternator
- Honeycomb Grill
- Unknown issues audi s4 b8 avant . Please read
- CH: Only left headlight initializes at start
- FR: Did I mess up? :(
- I was duped into a broken S4 - I need your help
- S Tronic Transmission error while driving.
