View Full Version : Q7 MKII Discussion
- 2023 model: creaking from B Pillar trim or window seal?
- OBD eleven. Q7 4M
- Coolant Shut Off Valve Leak
- Thule Cross bars
- Q7 air suspension - adaptive dampers or no?
- Happy Thanksgiving 🦃
- Restore and Protect ATF
- fuel injector
- Flush rails with "black optics"
- Disconnecting the battery
- 2018 Q7 3.0TFSI cylinder shmoo
- Pre Road-Trip Advice?
- 2018 Q7 disabled, $30K to repair, planning to give to charity, any suggestion?
- Battery replacement
- What is this noise?
- BRAND SPANKING NEW BRAKES!!
- Finished B12 piston soak - getting P2251 oxygen sensor fault code
- Did I make a huge mistake?
- Unfortunately it good riddance to our 2025 SQ7...
- Panoramic Sunshade Replacement - How To?
- RS7 Performance 22" and B4 + H&R springs
- found paint work on the q7 I bought
- remote start 2024 q7 sline
- 3.0 TDI ENGINES AFTER 2013 2014 OIL PRESSURE
- Looking to speak with Audi Q7 2022 or newer owners for research project
- Anyone selling a OBDEleven Device or can Code For Me
- PSA for rear brake replacement
- VCDS Codes for 2025 Q7 Prestige
- Persistent Electrical Buzzing Behind Dash – 2021 Q7 3.0T (Video Included)
- VR&P vs. HPL oil - engine internal pics at BITOG
- Winter Tires
- Condentation under gas tank?
- Q7 Rear Pads
- 2019 Q7 and Extended Warranty Problems
- Laser Light Safety Shut-Down
- New (to me) 2018 Prestige. Suggestions needed
- Wheel Bolt Sensor
- Brake pads 2021 Audi Q7
- P1B1C00 Coolant Pump Malfunction - Short to ground Lamp OFF Intermitted
- my left head light( yellow)
- Q7 Active grille shutter
- 2018 Q7 is it safe to tune stage 1 ?
- I have a 2018 3.0 TFSI w/ 31k miles - time for new spark plugs?
- D5s HID Bulbs ?
- Looking to buy Audi Q7 2017-18 , how to check if it has cylinders damage ?
- Unlock door
- Been unhappy with Q8 ownership experience so far - should I expect same in SQ7?
- Spark plugs change at 60,000 miles
- What preventative maintenance to do while I have the supercharger off?
- Strong Vibration on Hard Acceleration and Reverse Gear Fails When Backing Uphill
- Instrument Panel message/"Christmas tree" lights
- Audi Q7 4M 8 Speed Auto - Transmission
- Q7 Premium plus can you add LED front turn signals and a couple questions
- MMI navigation
- Valvoline Restore & Protect & different viscosity
- Coolant Temperature: too high
- Both Tailgate lights out
- Spark plug interval
- P052E00 - Don't want to pull the supercharger yet?
- Title: 2018 Audi Q7 Prestige - “Drive system malfunction” message + shaking while par
- Rear Bumper Top Protector SQ7/Q7 2020
- Eurowise hitch mount spare tire carrier?
- 2017 Q7 Prestige mysterious noise when turning left only
- Illuminated Rings
- Q7 Exhaust Tip Intall Question
- Replacing rear lower tail light bulb
- VCDS to Level SQ7
- 2022 SQ7 engine under cover replacement
- 2.0T coolant leaks and extended warranty
- Matrix-design LED headlights
- New to Audi bought a part car
- BRAKES BRAKES?
- Drive system malfunction error on WOT - 2018 3.0T
- Any pics of H&R or 034 lowering springs?
- Rear tyres excessive wearing following suspension repairs
- Aftermarket shock options?
- 100k mile club
- Took to dealer and car full of errors
- UK: Parking heater fitting
- 2024 q7 winter tires
- What are these symbols? Urgent!
- 2019 Q7 3.0L Engine - "Purring" at stops
- Rough startup fixed!!
- How to Add CarPlay to a 2018 Audi Q7
- 2018+ Audi Q7 Reliability Questions
- LIN-Bus Wiring broken, Workshop suggested 15k change as one of the options :)
- 2025 Rear Wiper Blade
- False low coolant warning
- 2015 Q7 Blowing fuse 6 'engine valves'
- 2019 Q7 - A/C starts cold, warm 1hour later, cold again after a long stop
- Q7 2025 easy entry problem?
- Side Mirrors Whistle at 45mph
- RS7 performance wheels (22")?
- 2018 Q7 mmi login instructions
- Judder Slowing down and Erratic Shifting with CC on
- Seeking advice on how to replace a broken pin connector
- Hitch Step causing issues with sensor
- Hard thump
- Joined the SQ7 Squad
- Diff Fluid Change
- Audi q7 sill LED
- Outside fresh air ??
- 2018 AUDI Q7 AC COMPRESSOR RELAY
- UK: 3.0 tdi 2016 tap tap tap...
- 2018 Audi sq7 TDI fuel gauge
- Piston Skirt warranty extension letter from Audi
- FS RACECHIP GTS BLACK FOR AUDI Q7 3.0T 4.5M on Marketplace as well.
- WTB Roof rack
- Like new FABSPEED SQ7 downpipes in the marketplace
- Q7 TDI needs a differential...
- Hey how do you remove this lower coolant hose?? please help
- Oil dipsticks
- Telematics / SOS issue - fixed!
- Drivetrain Fluids?
- Phone Storage Q7
- tire size matter ?
- Tire pressure label
- 3 piece folding rear cargo mat
- D3S LEDs Brighter than XENON & Dual Fog LEDs! Perfect combo
- UK: Q7 4M TDI 2016 200K Timing Chain
- Regular Maintenance question
- Q7 4M 84mm TB kit
- Telematics module location?
- Need advice : Audi overfilled my oil, damaged the sensor. Now what???
- Trying to diagnose CREC oil consumption cause: PCV or stuck rings?
- Q7 4M: Best choices for lowering?
- Piston Skirt Issue
- DIY-ish: Audi SQ7 CSF Intercooler Install -- Front Bumper Removal
- Bang and Olufsen Advanced volume fluctuates
- 2025 Q7 Beeping Volume
- Major service on wife's Q7 - what am I missing?
- Advice on Liqui Moly products
- Throttle body issue
- Web radio no longer works
- 2025 SQ7 - Rear Bumper Trim Part #?
- What oil to use, my 83,000 mile Q7 has a new engine.
- How to turn adaptive cruise to regular?
- New Q7 2026
- SQ7 2024 Glove Box Organizer
- Latest firmware for 2019 Q7?
- audi q7 2017 drive malfunction light
- MIB2 updating fw, maps, features...
- Q7 Hitch area cover
- Cargo Cover for 2020 Q7 Prestige
- Rear Tail Light Fault
- 2017 - Need help on how to manually shut sunroof
- 2019 3.0 Supercharged vs. 2025 3.0 Turbocharged
- do 2021 SQ&s have the BSG/48V system?
- Remove & Replace Front suspension, cost and need?
- Q7 MY25 55TFSI SLINE Vehicle stall electrical failure
- Audi Q7 55TFSI in our future? Thoughts and questions (long)
- Diagnostic Tool Scanner recommendation for my Q7
- Ac randomly quit
- Run Flat tires or standard tires...
- Left side mirror shaking and weird noise when unfolding after being folded over time
- Q7 4M - Great Basic Audio System Upgrade Option
- Grey/White Smoke after 40k Service
- 2024 q7
- '17 4M Prestige with a cow/mooing noise when steering [video sample]
- 2025 Wheel and Tire Fitment…Did I make a mistake?
- thinking of buying '17 Q7 w/101K miles...have questions
- Different size tires for my 2018 Q7.
- B Pillar loud motor noise
- How much extra warranty on 2021 q7 teknic
- Starting my oil consumption mitigation journey
- Possible TT revival
- Mounting a front license plate
- over kill topic (brakes)
- Wrapping my 22 SQ7 prestige
- 2025 Front Plate filler?
- DRLs turned yellow
- The end of my 2018 Q7
- 2017 q7 3.0 transfer case replacement/rebuild options
- 2018 Q7 Not blowing cold air out of vents
- Odd humming noise from the front wheel - at specific speeds
- 2021 SQ7 tores
- Farewell To My Q7
- Does coolant leak cause fire?
- Post-windshield install calibration question
- Roof racks for panoramic roof
- 2022 Q7 3.0l Quattro installing hitch and lighting.
- Finally Got One!
- YouTube - CREC 3.0T teardown
- Audi q7 bang olufsen problem
- SQ7 21x10.5 or 9.5??
- 2019 Q7. Doesn't start. How to check the battery?
- Flexible exhaust pipes cracks
- AC Issue - Front Hot, Back Cold
- Towing Modifications
- Navigation screen not available while driving
- Q7 2017 2.0L turbo, coils failing at 70K miles, 2 of 4, just me?
- Tips for DIY maintaining Q8/Q7 with 3.0T V6
- Okay to Replace Brake Pads Only?
- Waterpump inspection on 3.0T
- Audi Q7 2017 3.0T Aircon issue - Tricky one
- Recoding for 2017 HID headlight to 4.5M Facelift matrix headlight upgrade?
- What is this part called?
- Oil In The Engine Bay
- “Audi pre sense currently limited: see owner’s manual”
- Rear AC Controls Removal for Repair
- 2025 Virtual Cockpit
- Q7 vs X5
- Side marker light deactivation-Icarsoft CR MAX
- AI Powered Service Manual
- Tire pressures when towing
- What trans fluid, 3.0 ZF
- Kill It With Fire!
- Tire pressures
- 2023/2025 Audi Q7 55 TFSI – RPM Spikes in Automatic Mode (Confirmed on Multiple Cars)
- 2017 Q7 CarPlay Option Missing
- Windshield Replaced, now HUD is blurry/ghosting
- 45 vs 50 TDI (2022 reg)
- Tail light wiring diagram
- Yamalube
- 20mm and 30mm spacers
- AC. Sometimes it's cool. Sometimes it's not. Any ideas?
- Control Arms, Rev. 2
- lOWERING SPRING RIDE HEIGHT
- Main Battery Replacement
- Coil Spring
- 2018 Q7 service
- Arem rest console trim cover
- SQ7 Pre Sense warning settings
- SQ7 sound settings
- 10 Things Audi Does Better Than Most Other Automakers (what a joke!)
- AI RSQ7
- SHW Rotors and Akebono Brake Noise
- Bought Another Q7
- Oil Consumption Treatment Advice
- 2023 Q7 w/v6 gas mileage drop
- Evan's SQ7 Build Thread
- Recommend Oil Changer Fluid Extractor, Oil and Filters
- Electric Load Cover Clips - How to replace??
- 2019 audi q7 door warning marker lights
- Need Decode VIN
- Cold air intake
- Spark plugs: 3.0L interval?
- RS Q8 Brake Cooling Ducts
- Key Fob Issues with Unlock
- Rear bumper assembly
- Q7 randomly makes an air release or popping noises when parked
- Q7 Center Console Armrest w/Charging Pad
- 2017 Q7 3.0 Engine Ground Connections
- Air intake breather hose fell off - fixed
- UTR 1.0 Password Reset
- We’re working on our next generation car scanner and would love your feedback!
- Beware alibaba steering wheels
- 2017 Q7 Steering Clunk While Stationary — Lower Control Arm? Strut Mount? Val joint
- How many years do people keep their Q7?
- Is this piece correct? Please help
