View Full Version : Q7 MKII Discussion
- Car Play (specifically Anroid Auto) I am noticing an issue with the menu button
- 2019 Q7 base headlights not the same
- 2017 Q7 Second Row Passenger Seat Won't Fold Up for Third Row Access
- 2019 Q7 Exterior Rear Door trim Removal
- 2018 Q7 still vibrating after exhaust replacement
- 2021 Audi Q7 Sun Visor Attachment Broke
- rattling vibration
- 2020 Audi Q7 Prestiage MMI software update
- SQ7/SQ8 tunes - convince me, please.
- 2017 Q7 clunking sound in front
- 23' SQ7 All Season Tire Challenge
- Q7 - Topping off G13 Coolant with a quart of DexCool by mistake
- 2017 q7 no reverse
- 2018 Q7 t-boned; does side air bags = totalled?
- What are these connectors for?
- Audi Q7 4M Coolant Level Sensor/Switch
- 2017 Q7 Supercharger clutch replacement
- *UPDATE* All back together, but alignment shop had issues, now lots of dash lights
- What’s this and where can I find it???
- 2021 Q7 3.0T Water Pump & Service Manual
- Suspension linkage and torgue/ride height
- 2017 Q7 crank no start
- Coolant Flush for Q7?
- Piston Soak Tips
- Black Emblems on SQ7 Black Optics
- General Question about Self-Maintenance on 18-19 Models
- Q7 87K - Carbon build up killed cylinder #2
- Alignment leads to massive system failure?!?!?
- AWD/Differential 2018Q7 Issue?
- Alibaba grill = immediate regret 🤦♂️🤦♂️
- Does 2021 SQ7 have the 48v mild hybrid system?
- Brake Pads and Rotors
- 2025 Laser Lights -- update
- PA: Adaptation of regulating flap for compressor
- Turn off "Hey Audi"
- USA spec Q7 to Sweden?
- Model 2024, TFSI-e 55 (hybrid) ECU locked
- 2018 Audi Q7 Quattro intermittently chirping
- Spare wheel/tire ?
- Q7 2024 issue
- 2017 Q7 Transmission Failure
- 2025 Q7 Run Flats
- Q7 4M A/C issue
- My Jackal Motorsports Tune Review
- 2018 Q7 front suspension squeak
- 50 TDI Turbo lag or gear too high
- Front License Plate Bracket Missing (2022)
- 2025 Q7 Premium plus
- AUDI Q7 4M Steering Angle Calibration Issue
- FCP Euro Oil Return question
- Q7 and Thule 150cm (60in) SquareBar Evo?
- 22" V-Spoke Wheels Available for Trade
- Antitheft
- Q7 mkII PR code location
- PA: Is there a need of removing the bracket of the valves or the entire supercharger?
- Fuel rail recall for model years 2019+
- SOS emergency call function error
- Front view camera
- 2018 Q7 Alignment
- Modules and Coding to get Dynamic indicators and start up animation - 2020 taillights
- Transmission Shudder On The Highway!!
- Scraping/grinding noise when slowing down 2021 SQ7
- Replacing Q7 4M transmission mechatronic solenoids
- Transmission shifting gears at highway speeds in dynamic mode
- Should I buy this extended warranty? My spidey sense is tingling.
- 2025 Questions about Features
- 25' Q7 55 vs 22' X5 40i(pre LCI)
- Audi Q7 auto start/stop fault
- What is this?
- A couple of Q7 3.0 TDI questions
- Should I get BMW X7 or Tesla Model X to Replace my 2017 Q7 ?
- Intake Runner and Oil Separator?
- ~100K and does NOT burn much oil
- 2021 Q7 Trialer Turn Signal Error
- Picked up my new Q7!
- Maneuver Light
- 2025 SQ7 Pricing
- SQ7 Control Arm Bushings Replacement
- Bluetooth backup camera problem
- R&R V6 with piston land breakage
- 2017 Q7- keep or sell?please help!!!
- Warning message “lane change and exit warning”
- 2017 Q7 Transmission Replacement
- Do you always replace the rotors with new pads?
- Center Diff (Transfer Case) Fluid
- 2025 Q7 Rear Cross Traffic Assist Issue
- 2025 Laser Lights
- Cold Start - Shift Flare/ Driveline Lash? 2.0T
- BG: Q7 2017 - Strange and Insane Oil Consumption
- Well it happended BSG Failed 21 Q7 55
- '19 Q7 Resale value?
- 2017 Q7 “Nav not available; Bluetooth is Deactivated”
- 2017 Radiator Shutter Adaptation OBDEleven Help
- 2018 Q7 low rpm jerkiness - SC clutch replacement
- 2018 Q7 - Headlight - Only half of LED strip lights up
- Black Rings/Badges SQ7
- MAF sensor and EGR temp sensor faults
- Warning Message: Brake Booster Function Limited?
- Found an exhaust system
- Q7 aftermarket glass replacement
- Q7 burning a qt every 300 mi. Can I keep topping up or is engine failure imminent?
- Weird brake noise and warning “brake: servo restricted”
- "Turn off engine and check coolant level" - but coolant levels are fine
- Steering malfunction
- Anyone have torque specs for MKII sway bar install?
- Rear Suspension repairs - which parts to order?
- DIY: 3.0t Engine Mounts ( Easy way , No need to lower Subframe)
- 295/35/22 vs 285/35/22 SQ7/Q7 Air Suspension Sport
- Anyone have an OEM Audi Q7 MKII sunshade to sell?
- Disappointed in the build quality of my Q7
- Please help me figure this out
- Fresh outside air via climate system?
- Adaptive Air Suspension and Acoustic Glass
- Help identifying sound present after startup 3.0 CREC
- Audi Q7 2021 Front Breaks Change at 23K?
- 48v battery
- Coolant leak
- Ant infestation?
- Anyone upgrade to Pure 900 Turbos in SQ7/SQ8?
- Trim removal guides/manual?
- Q7 dedicated AT/offroad wheel/Tire advice
- Replacement handle cover paint options?
- Weight distribution or sway control for towing with 2019 Q7 ?
- 2020 Q7 alarm wouldn't stop, dealer can't replicate
- Audi Q7 gearbox malfunction warning
- Creaking on '23 SQ7
- Q7: Michelin CrossClimate 2 Review
- Could anyone offer some guidance on running rich at idle error?
- ACC Stops Working in Heat
- Frontend creaking sound Q7 2018
- 22SQ7 rear pads
- Looking at a 2020 Q7
- Q7 4M 2017 3.0 TFSI (CREC): Camshaft results
- Considering buy first Audi Q7. Is Audi Q7 DIY ?
- 2021 Audi Q7 Prestige Audi pre-sense and emergency SOS currently unavailable
- Water pump class action
- SQ7 or SQ8
- 2021 SQ7 Wheel arch trim fell off
- 2019 Q7 Coolant temp too high message
- Click sound when press on gas pedal and when let go
- 2019 Prestige screen retract while driving
- UK: 2021 - Q7 - after sale queries, MoT
- 285/40/22 or 305/35/22 on SQ7
- What is this button for? (Audi Q7 2017)
- 2018 Q7 3.0 Prestige Battery
- Any opinions on OEM SQ7 sway bars on a Q7?
- Dealer estimate for repairs?
- MMI versions and updates to firmware
- 2016 Q7 seat frame parts required - rotating latch and spring for locking mechanism
- Squeaky Rear Doors on New 2025 Audi Q7
- P305400 - Starter does not turn
- Is it a normal engine sound?
- P200600 & P200700 - Intake Manifold Runner Control Bank 1 & 2 Stuck Closed
- New Q7 on the way, RIP Q5 TDI
- Battery coding question after engne swap [2017 4M Prestige]
- 2018 Q7 Dealer wants to replace the engine
- Soon to be new owner questions
- Alternative repair shops in Toronto, ON. area
- Heavy Gas Smell after PCV, Ignition Coil, and spark plug change
- 2018 Audi Q7 Oil Consumption need help
- lowering links - rear only anyone?
- Integrated Engineering SQ7 tune
- Q7 V6 Diesel engine Ticking Noise Horrible
- Turn signal tap for external LED hood light strip
- 2017 Q7 3.0 Spark plug removal question
- Audi Engine Bay Harness Bracket 06E971845L OEM Part #: 06E-971-845-L
- DIY ACC alignment.
- PL: Audi Q7 4M: Night Vision
- Seat Belt Tensioner control module
- Transmission malfunction error
- SQ7 Retrofit Trailer Hitch
- 2017 Q7 Air Suspension Malfunction - Level Sensor
- 2023 w/Branded Title?
- MMI stuck on Engineering Screen
- Transmission oil change ?
- NEED HELP! Swapped engine and have 5 extra boltls
- Pirelli scorpion weather active vs Toyo celsius sport
- 2018 Q7 Transmission Help!
- Tire Place Says Couldn't do a Alignment Because Rear Bolt "Stuck"
- Remote Start installed on 2019 Q7 Prestige
- Audi Cuts Out Every 60 Seconds
- Opinion on drivetrain maintenance
- Water near center of the car dripping
- 2021 CPO SQ7 purchase
- Best Product to remove water stain.
- Green Fluid Under Q7
- 23" wheels on a 22 Q7?
- Q8 Roof Rack Fit on Q7?
- Why Doesn’t Tire Rack Recommend Off-Road Tires for SQ7?
- Thinking of buying 2021 SQ7 - Pre-Owned not CPO
- Selling my old 3.0 TFSi motor with a bad exhaust valve, what's it worth?
- How old is too old?
- [3.0TFSi] Supercharger clutch adjustment
- What Oil Type for 2019 Q7 3.0?
- Audi ABT SQ7, Which version is better in your opinon?
- O2 sensor location 2017
- Timing chain rattle???
- OBDEleven vs new VAG-COM cable
- Fuel Rail replacement cost?
- Help with Hitch and Brake controller wiring please!!!
- Automated Emergency Braking System Settlement
- Air Bag warning after front passenger seat bottom replacement
- 2018 Q7 AC Problem
- Gas prices in MMI
- 2025 Q7 55 Premium Plus - Matrix headlights?
- Engine Misfire in Cyl 2 even after changing spark plug and Coil
- UK: SQ7 4.0L Diesel V8 - Oil Filter stuck !
- Coolant sensor help
- Newish 2023 Audi Q7, hood air pressure after a drive
- Switched from ROF tires today to standard
- Drive system malfunction/limp mode/supercharger clutch
- I think I may have cured my Oil Consumption!!
- Banged up turbo blades! How would this happen?
- 2019 q7 PP - 255/55 R19 to Smaller / Larger Size for Michelin Defender?
- Rear dust covers falling apart
- problem air suspension
- 2017 Flex pipe broken again after 30k miles
- Coolant flush pipe/valve location - Audi Q7 2018, 2.0T, Premium Plus
- Recommendations for 21" A/S tires
- Production question
- Brake wear pattern
- 2017 Audi Q7 130k Miles Maintenance
- Fitting a retractable tow bar UK
- Atturo Tires?
- Audi q7 Matarod color used car - is it safe color to buy
- Rattling drivetrain while acceleration
- Q7 Push Start relocated?
- Traffic sign issue 2019 Q7
- 2022 Rattle sound from AC panels
- 2013 Audi Q7 for sale
- Audi Q7 2017 - Premium Plus headlight wiring diagram
- Oil Leak 2017 Q7 3.0 - what is this part?
- Replace tensioners with belts 2019 Q7?
- Any clues what this is
- Jump to SQ7.. Worth it?
- Oil coming out oil cap of Supercharged 2018 Q7 3.0 TFSI
- 2023 Audi Q7 Roof Bars
- Q7 2022 Not Charging after crash
- One has to raise the engine to replace alternator belt on 55 V6 with MHEV? No, right?
- Driver Assistance with Area View, is it in? Or, out in 2025 Q7 Premium Plus/Prestiege
- 2022 Adventure Q7
- Youtube and Netflix
- Paint color for 2018 Q7 bright silver 21" wheels?
- Audi Q7 requires service "each year"? What kind of car is this. Scam ?
- 2019 Q7 map/nav issue
- Location of power steering fluid reservoir for 2018 q7, 2.0t ?
- Talk me into (or out of) 2025 Q7 55 Prestige, anyone?
- MMi replacement
- 2025 Audi Q7 has remote software update from over the air?
