View Full Version : Q7 MKII Discussion
- Would you do it again?
- New Q7 Dash Configuration -Help!
- Q7 air vs SQ7 air suspension ride comfort
- What is Paint Protection option on MSRP sticker
- Q7 2022 extended warranty and yearly maintenance advise
- Air Vent Adjuster replacement.
- CA: steering torque sensor?
- 2nd key missing with new car
- Roof Racks & Cargo Boxes
- How much PSI drop acceptable in pressure testing coolant system?
- Digital dash switching from MPH to KMP issue.
- 2018 MMI Restarting
- Thoughts on stock SQ7 tires in the snow?
- 2018 Audi Q7 - unable to start in the cold
- When is the Q getting a major refresh?
- Curious about Dashboard Indicator, 2021 Q7 Prestige
- Aftermarket Brake Pad Options for MKII Q7
- High pitch whine coming through center dash (Blower motor? Or is it?)
- Full LED Assembly - Dim Lower Row
- 2017 Air Suspension Drops / Malfunction When Cold Outside
- Floor mat strategy?
- 2018 Q7 Rough Ride
- US Audi Q7 2021 - 4 cylinder vs 6 cylinder
- Please Help, 2017 Audi Q7 Start Noise (With Video)
- UK: Audi Q7 2015 diesel VCDS Scan result
- VCDS Interface : Not Found! Error - Audi Q7 2015 model
- 2020 SQ7 Supersprint and APR Tune
- snow and crud
- Exterior Passenger LED Door Handle Light
- Know a place to source 20” oem black optics wheels from?
- OBDEleven - Module 44 (DSR) Driver Steering Recommendation
- 2021 Q7 Laser Light Headlamps
- Car does not go to park after transmission fluid change
- DIY Black Optic Package 2017 Prestige
- Crazy 2022 Pricing?
- Increased oil consumption
- Q7 3.0 Non Air Suspension Towing Help Needed
- 2017 Q7 maps and software update
- Q7 2017 - brake fluid flush due?
- Help. Need help with a vehicle inspection (Los Angeles)
- Black Optic Touch Up
- Sq7 TDI jerky transmission
- Q7 MK II - continued misfire after plugs replaced
- Stuck between Vredestein Quatrac Pro and the Mich Crossclimate SUV. 3 peak rating
- New Audi Connect Dealer Website Down; Alternative?
- 2022 SQ7 TPMS
- 2018 Q7 cameras not working
- Still happy after 4+ years
- 40k miles service cost?
- Using 18” q5 wheels for winter tire setup?
- 21" OEM titanium wheels for 2017 power coat?
- How do you add CPO after sale?
- Camera vs. Graphic view when reversing
- 2020-2022 Q7/SQ7 Wiper Blade Replacement recommendations?
- Just got my 2021 SQ7 apr tuned
- Hairline crack to Night Vision lens with no signs of damage -- anyone else?
- Buying used, avg warranty cost?
- Left door line light not working
- Turn Off Pre-Sense?
- Looking at '17 - '18 Q7s - please clarify some trim level questions for me...
- Slight whistle at idle
- Q7 plug-in hybrid in NA
- Home Address Disappearing
- Wind Noise
- PSI for Conti DWS06 275/45/20 tires
- 2019 Q7 Wheel Info
- SwissInTexas's Q7 Journey
- Loading system SQ7 stuck in a loop on computer
- Let's see some pictures of 22" wheels!
- Exhaust/Muffler Options for 2019 Q7
- 2022 SQ7 with MGmotorsport Downpipe and Catback Exhaust
- tilt wheel
- Q7 TFSI e - only 20km/14.2miles on full electric with one full charge
- Took delivery of our 2022 SQ7 this week!
- 2017 Steering wheel buttons not working (sort of)
- Audi Care Package for 60/70k $1099 worth it?
- Purchased out of state - registration/Temp Tags question
- 2022s purchased/on order
- Are SQ7 exhaust tips welded on or cliped on ?
- 6 piston calipers suck... change my mind!
- Autostart/stop - Keep on or turn off?
- 3g Turndown for 2017 vehicles
- Maximizing Storage in the 2021 Q7
- Battery and/or Alternator Charging Voltage Issues
- Half of the modules do not work on Q7 4m
- Carista or OBDEleven?
- Tire setup for 22" wheel?
- SQ7 Exhaust ?
- the Break saga continues
- Vehicle Inspection indicator ->Question
- Towing running lights not working correctly
- getAudiparts.com | Your 2021 Black Friday/Cyber Monday Savings are HERE!!!
- Roof racks
- Outside tire worn out
- 2019 2019 Q7 3.0 Premium AWD Doesn't come with rear or engine badging?
- Inflation Relief - Black Friday thru the end of November Sale...
- Brake pedal squeak after brake fluid flushing???
- 2019 QT adaptive cruise control
- 2017 prestige side mirror housing part
- Audi CPO, not what it used to be....
- Charge for diagnosis if no problem found
- Audi Q7 4M installation dynamic rear lights
- Unlocking driver side only ?
- Weird smell coming from front dashboard passenger side
- Oil Extractor Plug Location 2019 Q7 2.0L
- CPO warranty and repairs
- Infrastructure law paves way for adaptive headlights in US
- Audi Q7 Brake Problems
- 2021 Audi Q7 Fuel Indicator Problem
- Approaching 50k
- Service action 96G4 gateway control module software
- Car blows black smoke
- Audi Q7 2017 Prestige
- different wheel same tire as spare
- 2017 Q7 3.0T Prestige Cockpit Fuse Panel
- What should I ask for my Q7?
- 2019 Q7 Prestige issues - Front vents and leaks
- Massage seats for Q7/SQ7 21/22
- 2022 Q7 not recalling seat to saved memory position
- What tune will increase fuel economy? 2017 Q7 Prestige
- Ordering a Key Fob
- Evan's Q7 Evo Build Thread
- Good Indy Mechanic In San Antonio, TX Area?
- 2018 Q7 door handle lock button - disable?
- RSE Tablet 4M0051700 vs 4M0051700-B
- Extended Warranty Options
- Couple Oil Filter questions ?
- Independent Mechanic for pre-purchase inspection
- Trailer assist
- Need Help: 2017 Q7 3.0 Intermittent Coolant Temperature High
- 2017 Q7 coolant leak on passenger
- 2020 Q7. Is there a way to turn off just the rear climate from the front ?
- Anyone replaced front wheel bearings on the 4M Yet?
- Remote Start for Q7
- Time for new brakes... brake pad recommendations?
- Need tire suggestion - Q7 285/40/21
- New to the forum and considering a Q7
- Anyone with 2018 3.0 and APR Stage 1 tune ?
- AU: Minimum wheel diameter for SQ7 to fit snow tires and chains
- 2018 q7 TFSI engine knocking noise at cold start
- Engine knocking/rattle at idle speed (2018 q7 3.0TFSI)
- Fitcamx dashcam on 2021 Q7
- Coolant Temp Sensor?
- Peripheral Camera Control Module Location
- (SQ7) Pilot Sport A/S 4 vs. Pilot Sport SUV?
- Toxic smell emanating from Q7 trunk - what is this?
- Looking to sell my 2013 Q7 S-line and start looking for a 2019 Q7
- Highway speed sign detection mods.
- 2022 SQ7 perm disable start stop ?
- Q7 Air Suspension... How Low?
- 2022 SQ7 how to get 0-60 timer
- Full Tank range?
- 2017 Audi Q7 3.0 premium plus camera error code b127f04
- SQ7 Paddle Shifter Replacement
- New Battery 2017 Q7 question
- Presense in the rain
- Brake Disc Rotor sizing: 350 mm vs 375 mm OEM?
- New Tires for 2018 Audi Q7 - Run Flat 285 45r20
- MY18 Q7 4M fitting after-market side board
- Tire height difference
- 2018 Q7 3.0 Premium Rear Brake Job Question
- What are some issues with higher mileage: 60k -100k?
- 2022 SQ7 Owner needs advice on few upgrades
- Disable "Stop/start"
- Avoid unlocking doors
- 2017 Q7 VIM via VCDS, is it possible?
- CA: Warranty Start Date?
- clicking from the seat
- Anyone pressure tested 2.0T cooling system?
- $1500 for new front brakes and rotors???
- DIY: 3.0T Water Pump
- $2,812.65 to replace a 2021 Q7 Windshield?!
- Just performed the 60K maintenance myself.
- Oil Consumption Between Oil Changes
- Wireless APPLE Airplay
- Front spoiler removal and replacement
- Looking for a part number
- constant hissing/buzzing noise from under the hood after turned the engine off
- Sim card slot
- Bluetooth Carplay Adapter
- Q7 2025
- 2018 Q7 Progressive Tow Package S LINE 2.0T
- Anyone DIY their water pump?
- Rust ring on the rotor
- 2017 Q7 3.0 spark plug gap size
- Using winter tires as a summer spare?
- 2017 Q7 e-tron - still thinks it's plugged in?
- so tired of break noise
- Did anyone get a real dipstick for the gen2 Q7?
- 2018 Q7 Touch pad MMI does not work properly when it gets hot in sun
- Q7 rear cigarette light trim removal
- 2017 IOS 15 CarPlay Fail
- Oil Change - Miles or Time?
- What should SQ7 10k service cost?
- 2021 Q7 Malfunction warning & black screen
- Ken Block Rips Legendary Rally Machines From Audi's Secret Storage
- sq7 subwoofer swap results
- SQ7 pricing
- 2022 Q7 - No Spare Tire?
- Q7 2.0T Higher Mileage review
- Q7, SQ7 Post-Facelift Hands on Detection Flat-Bottom Steering Wheel Packages
- Q7 4M ACC Retrofit??
- Thoughts on selling high to buy high?
- bluetooth connection
- Does Anyone Have the Newest North America Map Database to Share?
- slight coolant loss
- Auxiliary Heater Core Leak - K Seal, Radiator Sealant
- batch of easy questions. SIM card. rip CDs. DVDs. etc
- Heated Rear seats constantly breaks
- Phares avant endommagés Audi Q7 Premium 2017 3.0L
- 3.0 TSI on Q7
- APR SQ7 Tune is now available
- 2019 2.0L Oil Change Question
- Proximity Key question.
- Can we run 265/60R18 tires?
- Plug & Play Color Changing footwells or solid white, red or blue footwells
- Tire warranty ?
- 2020+ S/Q7 enable Video in Motion with OBDEleven
- 2020 SQ7 Enable Acceleration Measurement
- Creaking when making sharp turns at low speeds
- 2022 Q7 Order Recommendations?
- tire tread peeling
- virtual cockpit center dial (sq7)
- Continental ExtremeContact DWS vs Michelin Pilot Sport All Season?
- SQ7 Start/Stop Memory Module installed.
- 2017 Prestige Q7 3.0T vs 2015 TDI 3.0T premium plus
- Air suspension setting/controller: any way to RAISE height?
- Memory seats.
- buyer's remorse: extended warranty !!
- Is there a tune that could increase the MPG of a TDI?
- MMI local navigation and traffic sign recognition down
- Android Auto disappeared.
- Any one run the urus BMC filters on their sq7/8 ?
- DRL/Headlights won't turn off when car engine off
- Need a '22 Q7 45 Premium Plus Quattro for SoCal photoshoot
- 2022 SQ7 Question
- Brake Dust?
- SE: Q7 e-tron battery
- Disabling notifications (VIM and AudiConnect)
- Broke front Axle - claiming extended warranty
- Low rumble coming from the rear during hard turns at low speed?
- $50k reasonable? 2018 Q7 Prestige
- Distance between roof rack mount points
- 2021 Q7/SQ7 cameras and extended capability query
- Adaptive Chassis, is it really worth it?
- Important update to your Audi connect service
- Q7 MKII Hesitation at constant throttle 1500 -1700 rpm
- Downsize wheel from 20" - what will fit?
- Brake questions
- 2020 Q7 Blackout... Opinions?
