PDA
View Full Version : Q5/SQ5 MKII Discussion
Pages : 1 [2] 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30
  1. MMI issues
  2. Coolant change for upcoming season
  3. D3S LEDs Brighter than XENON & Dual Fog LEDs! Perfect combo
  4. Added trunk lights
  5. Bilstein B6 for 18 SQ5
  6. Integrated Engineering
  7. Need Some Feedback
  8. Anyone have a list of part numbers for a brake job for a 2021 SQ5 w/sport package
  9. Safety System Malfunction: D'oh!
  10. LTE Data Conx
  11. Dog claw marks on door side panels
  12. Tires Slipping with High Temperature
  13. 2018 Q5 Diagnostic Connector Comes Loose
  14. Feeling like the good times are over with my Q5
  15. Plastic covers
  16. Changing from small short trips to mostly highway driving
  17. 2019 SQ5 trailer wiring
  18. Michelin Tires?
  19. ‘21 Misfire/Valve Cover Gasket Done/Burnt Plug
  20. 2019 Q5 stalling issue
  21. Upgraded My 2019 Audi Q5 with CarPlay
  22. If you don't have the "phone box", what do you have under your armrest?
  23. 2019 oil usage question
  24. Spark plug change
  25. Parking Brake
  26. Help getting OEM part number for lower engine cover
  27. 2021 Q5e Engine Mount Leaking at 49.5K Miles
  28. 2018 Q5 power windows issue
  29. 2021 Q5 Swap regular seats for sport seats?
  30. Throttle pedal vibration during acceleration – feels like ABS or ESP activation
  31. 2018 Q5 - front passenger door replacement
  32. Few issues. Clunk, shimmy, shifting
  33. 100k Miles Today!
  34. Charging from Solar Panels?
  35. pr codes
  36. 3 quesions: Back door cover, metal clips and dashcam position
  37. Rotors slightly warped and only 48k miles
  38. Q5 blower replace and now a water leak
  39. Bluetooth Accept?
  40. Where does this part belong....
  41. Recommended tire brand?
  42. 95 degree heat - A/C not cooling well after long time in car
  43. VAG oil change interval
  44. Turbo issues. No boost
  45. I think I'm going without warranty
  46. Any DIY guides on cleaning the AC Evaporator?
  47. Do same-gen Macan wheels work with Q4/SQ5?
  48. Found A/C code B108D07
  49. Battery health condition test- use Motopower
  50. SD card for UTR
  51. Brake job cost?
  52. Any insight ?
  53. Dealer standard hours for brake job ?
  54. OBD port
  55. More backup camera weirdness
  56. North Carolina inspections - Window Tint
  57. 2025 re-design
  58. 2024 SQ5 Pedal Box Pro favorite settings?
  59. Car wash water intrusion to add to the sunroof drain failures
  60. All Window Sunshades?
  61. Parking Brake rewind
  62. ABS module - anyone ever had problems with it?
  63. Inspection report
  64. Side mirror extension
  65. Car pulling a tiny bit to left - report says otherwise
  66. Brake codes
  67. Weird humming noise at speed…
  68. Extended warranty
  69. '18 Q5 Premium - what are the two pigtails in the left rear corner?
  70. '18 Q5 Premium - random error messages and failures
  71. Sq5 2021 low oil warning during excessive heat wave
  72. Which, if any Audi use the Group 49 battery?
  73. ECU Tuning
  74. AC not working good after a time
  75. brake pad sensors
  76. different calipers/ 7 speed trans
  77. 68k, still no brake pads?
  78. Need help to ID this vacuum/manifold hose
  79. How do I replace the rear cigar lighter socket?
  80. Code out Lane Assist
  81. Rear View Mirror DashCam
  82. Another 3.0T EA839 with a failed rocker arm
  83. 2019 Audi SQ5 DIY tow hitch
  84. Need Help with Brake Codes
  85. 2020 SQ5 - Disable foot activated switch for tailgate?
  86. Towing with Q5
  87. 2021 SQ5 coolant flush
  88. Roof Electronics Control Unit J528 Replacement
  89. Looking for OBD II scanner compatible with '21 Q5 PHEV
  90. Rear brake pads retainer clip question
  91. 2020 Audi Q5e PHEV DTC help requested!
  92. Longevity of the 7 speed dual-clutch DSG transmission
  93. 2021 sq5 headlight issue
  94. Quattro Ultra Vibration When Turning
  95. Michelin 255/45ZR20 XL Pilot Sport All Season
  96. Exterior door handle issue
  97. 2018 Q5 rattling sound in transmission when slow speeds, coming to a stop fast, and R
  98. Door Drain Clogged?
  99. Ad blue fault trick.
  100. Recall: got a screw loose
  101. 2021 SQ5 Sportback. Black Exhaust tips
  102. SOS! My 2019 Audi MMI Has Gone Rogue (and is reading my texts!)
  103. OT for interest: Apple Watch
  104. EPB MALFUNCTION
  105. Audi 2021 Q5 no power no start condition
  106. 2024 P+ S-line Q5 - is this "normal"?
  107. Small Cover in Engine-bay Missing... needed?
  108. Seeking Advice on 2019 Audi Q5 2.0T Issues
  109. 20 mm spacers on 2025 SQ5
  110. On Board Computer
  111. Please help ID this hose location from SQ5 engine
  112. Brake Controller
  113. MIB update from USA to EU - I have VCP, can someone help me how to do it?
  114. Audi side assist and exit warning: malfunction! Please contact Service
  115. Has anyone figured out the window sticking issue?
  116. Q5 2022 Premium Plus door pockets
  117. Negative Feedback Through Steering Wheel- SQ5 2025
  118. 2025 Front License Plate in California?
  119. 2020 Audi Q5 Certified Pre-Owned Issues: Oil Consumption & Transmission Problems
  120. 2018 SQ5 Oil Leak and Seal......towing
  121. A/C Not working 4 Codes U062A00, U062B00, U062C00, U062D00
  122. 2024 Q5 dashcam installation (front + rear)
  123. Q5e. Will not start
  124. Floret Silver over Atlas Beige?
  125. Audi Connect
  126. 2025 SQ5 Sportback (Prestige) – Heated Steering Wheel Not Working?
  127. Air suspension issues
  128. Adding a Battery Tender Quick Connect
  129. Just bought my first Used Audi
  130. Driver Passenger Headrest removing
  131. 2018SQ5 P039300 and limp mode
  132. Picked up our new (to us) 2019 Q5 Prestige this week
  133. Acoustic Glass worth it?
  134. 2021 SQ5 40k Service
  135. Possible Oil Leak at Head Gasket??
  136. 2019 SQ5 w/40k miles - needs new engine
  137. Service Intervals
  138. AC cleaning service dealer wants 400 bucks…
  139. 2023 Q5 - What settings can be altered?
  140. 2019 Q5 P0039 code
  141. 2018 Q5 Center Console USB Port Replacement
  142. Buying 2019 Q5, what bot look for?
  143. Keyless entry broken wires
  144. How to force engine to start 2024 Q5 POHEV
  145. Looking for pictures from a 2019 Q5 Prestige of the base of the rearview mirror
  146. Driver's Storage Compartment Lock?
  147. Car looks strange in MMI camera
  148. Did my Control Arm Go Bad?
  149. LED Ambient light issue
  150. 2018 Q5 Fuse diagram
  151. 2023 Q5 Vehicle Code?
  152. Dash camera
  153. 2020 SQ5 - Is it possible to change the auto start/stop and side mirror defaults?
  154. Part number for 2018 Q5 rear bumper side marker light bulb holder?
  155. Audi Q5 80A FY 2018 rear lights conversion USA to EU
  156. 2018 q5 Transmission Isssue
  157. Fault code p2002
  158. The coolant is leaking...
  159. Need help with outer CV joint
  160. Stalling after auto stop/start tries to restart
  161. 2019 SQ5 B9 camshaft position sensor
  162. New to Audi
  163. 2018 Audi Q5 Headlight Replacement P/N?
  164. Q5 Dipstick?
  165. Q5 FY Facelift 2022 Lower Rear Tail Light Question
  166. Audi Sound system - can unlock independent level control for subwoofer Q5 MkII?
  167. 2022 Q5 leaky shock?
  168. Tires on Q5
  169. DIY on new SQ5
  170. 2020 Q5 PHEV battery problems - anyone having problems as well?
  171. Rear center vent removal/replacement
  172. Swept up by a NorCal Flood in my Q5
  173. Q5e Plugin Recall
  174. Map sensor
  175. 22 Q5e Prestige Lease ending-what to do?
  176. Window Trim sizes the same for Audi SQ5 2018 (B9) - 2024 (B9.5)?
  177. Warranty Expiring Question
  178. Extended warranty 21 Q5e
  179. Question about MMI Wi-Fi & Audi Connect on 2018 Q5
  180. Hitch question - possible new owner
  181. Microphone problem
  182. Sq5 CEL
  183. Electronic Noise/Sound in the Cabin
  184. Cannot remove lower tail light - Anyone else have this issue?
  185. Strut tower brace bolt torque
  186. No Heat
  187. Non-Responsive MMI Touchpad / Dial
  188. My wife’s Audi thru multiple codes.
  189. Fuel tank capacity versus miles remaing readout
  190. Strange sound in engine
  191. Reverse/backup camera stopped working
  192. shift interlock (emergency neutral) cable, how to replace
  193. Ambient foot light from Ali
  194. Oil cap movement when pushed down?
  195. Turbo bypass valve failure
  196. A rare nice surpise from Audi
  197. Armrest - Unlocking the Length Adjustment
  198. Android Touch Screen For Audi Q5 B9 2018-2021 | Apple Carplay & Android Auto
  199. p2006 p2007
  200. UA: PLS Help find owner
  201. shocks with lowering springs
  202. Driver parking assist not available
  203. Service Intervals (MMI & OBD eleven)
  204. Help with dipstick for 2022 q5
  205. Weird chirping noise/maybe a belt issue?
  206. SOS Emergency call function: malfunctioned
  207. Remote start missing?
  208. Q5e 55 launch control?
  209. Heated Steering wheel issues
  210. Question for any 2020-23 factory NAV users
  211. Finding out if software is loaded
  212. 2021 Q5 phev - does anyone have detailed wording of the EV battery warranty?
  213. New to Q5 PHEV... let me know...
  214. Audi recall 93AA - High-voltage battery
  215. 2019 Q5 Center Display Speed reads km/H only.
  216. Q5 2021 Shakes when Started
  217. Multiple Malfunctions
  218. Buzzing in appliances when charging Q5 PHEV
  219. Check Engine OBD-II device/app suggestions
  220. Keyless Entry Strange Issue.
  221. 2022 Q5 vibration around 1250 RPM
  222. Dashboard fuel capacity
  223. Comparison -- Q5e and MB GLC 350e
  224. No-start/hard-brake problem solved?
  225. IN: 2021 Q5 45 TFSI Problem
  226. 2018 SQ5 premature rack failure
  227. Top view Camera
  228. Gas smell when starting car
  229. Fuel/Gas Filter location ?
  230. 2017 sq5 exhaust
  231. OBD11 and the Garage Door Location pairing
  232. Rear door handle won’t open
  233. Self-leveling headlight suddenly pointing at the ground
  234. Tire pressure monitoring system broken or it's just bad?
  235. Replacement Battery 2018 Q5
  236. Q5 2018 Backup light fix
  237. TSR - Does it recognize only speed limit signs, or should it recognize all other sign
  238. 2018 Audi Q5 PPI - Expensive Issues: Buy or Pass?
  239. Advantages of using a Audi Factory certified Bodyshop?
  240. Shaking on rought Idle
  241. Is the newer Q5 (B10) the right car for me?
  242. 2018 Q5 Factory Hitch Cliff Notes / Part Numbers
  243. Exhaust valve after cat seized
  244. Audi Pre Sense - Left Turns
  245. CarPlay suddenly stopped working
  246. 2024 Audi SQ5 with(factory trailer hitch/electronics) Triton Trailer with LED problem
  247. Error: Electrical System Malfunction! '21 Q5 PHEV
  248. B9 (2018-2021) SQ5 thumping suspension noise
  249. From service to malfunction
  250. Sunroof Drain Limited Warranty Extension
