View Full Version : Q5/SQ5 MKII Discussion
- Red warning alert
- Way to leave engine running if I park and exit to get a coffee?
- Loading personal settings. Please wait...
- Q5 Sportback grill - Dealer drilled holes for plate - is this the whole grill?
- Q5 Driver Seat Mind of its own
- SOS Malfunction limited B18BD11
- Some issues with 2024 Q5
- Q5 Poor Heat
- Odd Message on my Screen
- 2019 SQ5 coolant temp sensor location
- Q5 Tail Light Faulty (But it's not)
- OEM battery lasts very long so how to tell if it's weak?
- Under Dash Sound Generator
- Tire Pressure for 21” wheels on 2018 Q5?
- Finicky EV Mode Button
- Keep adding coolant but the dealer can't find leak
- Heartbeat Soundbite on Exit
- 2024 SQ5 No Longer Available with Tow Package?
- Screwed up rear brake change
- 2018 Q5 Progressiv (Canada) - Back Up Light Error Message - Which Bulb Is This?
- C10AC07 Steering- Mechanical malfunction, but drives fine?
- gas vs electric
- Replacement battery for 2019 Q5
- Q5, SQ5 B9.5 Matrix LED Headlight Activation Information...
- Steering assist / steering rack failure SQ5
- Coolant smell in cabin.
- Auto headline feature
- Can 2023 SQ5 hug seatbelt when the engine starts?
- Anyone running Revo software on their B9?
- Service at dealership or not?
- Weather Radar on the MMI
- 21 SQ5 20” Tires-Opinion so Far
- 2020 Q5 TFSIe P030300 Cylinder 3 Misfire
- 20' SQ5 Left Taillamp Faulty
- Q5e JB4
- 2021 Audi Q5 Front Grill to S Line Honeycomb grille
- 2018 Audi Q5 Prestige
- 11089 - Engine Coolant Temperature Sensor 3
- Q5e super cold temperatures
- CV Joint failure
- 2016 Q5 does not start!
- SQ5 condensate drain location
- Porsche Macan EV
- AU: 2.0 TDI sudden power loss pls help!
- CPO Vehicle Protection Package (Powertrain, Gold, Platinum)?
- Q5 scan tool (shade tree mechanic)
- Tailgate closing automatically
- 2023 Q5e PHEV transmission malfunction
- 2022 Q5 PHEV Battery (12v) Bad?
- From my 18 SQ5 w/JB4 to a 2020 SQ5 IE Stage 1
- UK: Help diagnosing a pressure sensor issue
- New (to us) 2021 SQ5
- Level 2 charger for 2021 Q5 e
- Anyone ever try the 034 Motorsports Drivetrain Mods?
- 2020 Q5 Outer Bumper Grille - Mount Panel Clips?
- Transmission Lag/Clunk When Accelerating?
- 2021 SQ5 PP Sport - help OEM trailer hitch wiring work around
- Q5 Import to Switzerland from US - required changes?
- VC Phone Signal Strength Does Not Match MMI
- Mileage difference between dash and MMI
- Side-mounted Cargo Nets in Q5 PHEV
- Intermittent Malfunctions on 2021 Q5e
- Battery replacement causes car alarm
- Help trying to diagnose a pre sense communication error.
- Need help with wiring. Where does this go? 2017 q5
- 2023 SQ5 Remote Start Option?
- Should this be covered under warranty?
- Can I get a Q5 P+ Or Prestige without a sunroof?
- What is the little dot on the drivers seat heater button?
- 2021 Q5e rear fuse box: Am I too blind to find it?
- 2022 Q5 Towing limit
- Fastest Level 1 Charger for Q5 PHEV
- 2021 Q5 PHEV charging with 120
- Emissions codes - P245000 and P240700
- Lower left tail light replacement
- What's the deal with rear pads pre and post 2020 ??
- Average Cost of Charging My 2022 Q5e?
- Lost SiriusXM 360L
- Minor rear end = total loss. Mind blown
- SQ5 brake issue
- S-line grill
- Side assist retrofit mirror housing
- How to tell if 2023 Q5 has 40 or 45 TFSI Engine?
- Minimum oil level marker appears every few miles.
- Best OBD scanner?
- 2023 Q5e PHEV
- New Battery in 2019 Q5 - Now Showing Errors!
- New recall for 2021 Q5 e
- Rough ride suddenly on 2023 Q5 with 10k miles
- OBDeleven battery adaptation variables
- Curious about random noises, clicking and whoosing, when opening doors
- Steering Wheel Heater malfunction...
- Audi Q5 Brake Parts
- Odd error and air bag light is on
- Door speakers out and rattle or buzzing
- q5 not allowing me to skip songs on wheel while in carplay
- Audi oil?
- recommendations on repair shop
- Q5 Start/Stop, Cruise Control, Limp Mode Fault
- 2020 SQ5 Tuning Question
- Hotspot and SIM card slot
- “No data connection available”
- RO: 2020 Q5 TFSIe Low battery coolant level?
- Phone Mount?
- torque specs?
- 2018 Q5 Battery replacement
- Help with parking controle module location
- 2016 Q5 3.0 TDI Leak in driver’s rear panel. If not sunroof, what else could it be??
- 2018 Q5 Screw in rear tire
- 2024 Q5 vibration and wind noise
- Nav Sat Image
- Indie shops in South L.A.?
- Not able to login MMI as key user
- Dipstick Needed
- 2016 Audi Q5 2.0t 66k miles hesitation rough idle start
- Heater temperature when engine is cold (2.0T)
- Roof Rack Tie Down
- Retractable cargo cover part number
- 2023 Q5 45 2.0T Technik comes with matrix headlight
- Wait Until 2025 Model Is Available?
- Lumbar support control specifics
- Need help identifying this coolant hose
- Tires for 2019 Q5 (not run flat)
- WORST CUSTOMER SERVICE EVER!!! BK-Motorsport, Inc. for SQ5 Rear Bumper Kit
- 2017 sq5 winter rims work on a 2024
- 18 SQ5 - Radio on, no volume
- P00B700 code
- Audi Connect Canadian Spec car in United States?
- Retractable Cargo Cover
- Update for pre sense & ACC ? or tips and tricks
- Radio station spontaneously changes
- Anyone know where to get a shop manual?
- 23 q5 45 prem plus transmission question
- Empty Favorites entry
- Ambient Lighting in 2023 SQ5?
- Just got my best MPG ever
- SE: Planning for first time use in deep winter
- Q5e owners: cover for charger nozzle in snow and rain
- Engine ticking noise
- BLACK FRIDAY SALE,, SuperSprint Italy
- silly pet peeves
- BLACK FRIDAY SALE / CYBER MONDAY ON NOW @ deAutoLED.com – bright error free LEDs
- Parts Online?
- Fuel level indicator never full
- 2022 Q5e hybrid startup hesitation, drive system malfunction
- Pioneer D1004 Amplifer Question
- Tyre wear Pirelli Scorpion Verde Run Flat
- MMI will connect to Wifi or Bluetooth, not both
- 2023 Q5 - click from trunk when turning on/off the car
- Troy's 18 SQ5 P+
- B&O microphone
- Driver Assistance System Camera CODING
- UK: 2016 SQ5 Plus Gearbox cover
- Disable Foot Control for Tailgate
- Dealership says new intake manifold and water pump
- New wiper blades
- No heat coming out of my 2018 Q5
- Audi SQ5 2021 Stuck in 3G
- Traveling with a Saint Bernard without Destroying the SQ5 Interior
- Front Brake Pad Sensor - How to Reset?
- 2019 Q5 Turbo replaced at 50,500 miles
- Active Lane Assist error message
- 2018 Q5 blown engine 34k miles
- Inspection Due message
- Q5e has rough shifting when battery is depleted
- 2023 Q5 U142100 U14200 U111100 U112100 Error Codes
- Radio On, Ignition Off
- 2018 Audi Q5 60K maintenance worth it?
- 18 Sq5 - Zero Boost. Need help/3.0 turbo experts! p0299 / 34203
- Low Oil and Temparture Gauge
- People flashing their high beams at me - aiming headlights?
- scan tool
- 2024 Audi PHEV Q5 CA Clean Air sticker
- Traded in 2014 TDI for 2021
- Michelin CrossClimate 2 265/40/21 Installed
- Brand new SQ5 Pre-Sense activating prematurely.
- LT: AWD all the time or not?
- Sq5 front tower strut brace? Anyone done ?
- Question about Oled taillights
- Gateway Control module questions
- Small oil leak? 2018 SQ5
- Helping friend with faulty MMI on 2018 Q5
- Cobb Tuning AccessPort Support for the B9 B9.5 SQ5/S4/S5
- Alignment, or something else?
- 2018 Audi Q5 sunroof drain leak damage - should I keep it?
- 12volt Solutions remote start Sale
- Air Suspension Changes
- Rear bumper tail light bulb part number
- Garge door opener?
- No data connection could be established.
- Disable Apple Car Play
- What makes your SQ5 worth that much more than a Q5?
- Audi 2021-2023 driver side fuse box diagram
- 2024 vs 2025 Q5 PHEV
- Q5e phev 2023. Save battery hold option.
- 2023 Q5 Trailer Hitch Wire Harness??
- Audi care and other protection programs
- 2022 Audi Q5e PHEV oil change interval question
- 2023 Q5 Heated Steering Wheel
- Windshield defrost
- Anyone else buy the ridiculously overpriced Audi Gecko?
- Idle sound and feel doesn't seem like a luxury vehicle
- Audi Q5 2018 Engine vibration when Idling
- Just bought used 2020 q5e with 40k miles. Did I make a mistake?
- Homelink No Longer Works
- Carplay/Android auto USB replacement
- 2023 SQ5 Soundaktor
- New User Advanced Key Settings Help
- 2019 Q5 P+ front brake rotor questions
- New owner questions
- New Q3 vs Demo Q5 Decision?
- 2022 Q5 Dash Rattle
- New 2022 Q5 Premium Plus 55 TFSI e Owner; Getting Electric Charge up to 45 Miles
- Thinking of a 2019 SQ5 Prestige model
- Flooded Q5 in NYC?
- Black Box/GPS Data Download
- Q5 oil change. Is this price right?
- Q5e vs SQ5 - an allroad driver wants to know
- 2.0T engine and weird failures and maintenance
- 2020 SQ5 suspension issue?
- 2018 Q5 Engine failure at 50K
- Winter wheel/tire help
- 18 sq5 blow by
- What are "Car" favorites for?
- 23' SQ5 throwing P859B (Unsure what this code is)
- Random issues with MMI (SQ5 2022)
- UK: Real motorway fuel economy 40 TDI Q5?
- Audi connect
- Lease-end tire wear and tear question
- Why do interior door handles light up red ?
- Remove phone box sliding tray
- Are you interested in the upcoming Q6 Etron as a EV Q5?
- RO: Q5 fy headlights auto adjustment?
- New mats?
- G 055 529 A2 transmission fluid
- POI with navigation
- 2021 Q5e Jerking when accelerating from stop
- Q5 Rear Center Seatbelt Tensioner
- Brake Pads: limit reached light just popped, how long can I drive before replacing?
- Diagnosis help - ventilation / fan does not blow
- Spark Plugs every 40k?
- 2023 SQ5 windshield sprayer
- Auto start/stop is ridiculous, even in high heat
- Outside controls wont open tailgate when engine running
- 2021 Q5 Premium Remote Gate / Hatch Close
- SiriusXM not loading today
- LT: Sound settings (bass, sub, 3D etc.)
- Recurring engine coolant leak
- Bad expansion valve
