View Full Version : Q5/SQ5 MKII Discussion
- 2023 Q5 hesitancy to downshift
- Considering a 2021 Audi Q5 Prestige w/60k miles
- 2018 Q5 Premium Plus Driver Side Headlight Turn Signal Out
- Footwell lights
- Wireless charger not functional
- Line of water from muffler-SQ5 2021
- UK: Little or no heat from Rear passenger footwell/vent
- Audi Q5 oil change question
- Active Lane assist malfunction error
- UK: Washer Motor Warranty in Question
- Coolant
- 2018 SQ5 Fuel Cap won't open
- OBDeleven Pro power-on question; 2018 Q5 Prestige
- 2018 Q5 grille replacement question
- 2018 SQ5 wheel arch trim
- 2025 Q5 New Buyer Advice
- AUDI Q5, 11/2020, engine code DEZ
- Mudflaps on a 2024 S-line Q5
- Driver side door handle comfort access lock not working
- aluminum bits in oil filter
- 2019 SQ5 Oil Leak….added to recently diagnosed water pump leak :(
- Dashboard doesn't display navigation after firmware update
- Errors after replacing the water pump (Audi Q5 2018)
- Mojio Module In Side Compartment - ‘18 Q5
- Water pump/thermostat warranty
- Newbie question on Q5
- A/C compressor on AUTO, does it cycle in winter
- Sunroof Drain Limited Warranty Extension
- Coolant Leak - B9 SQ5
- Wireless Charging- Aftermarket
- PHEV drivetrains are more complicated, has Audi perfected?
- Added fuel to ‘21 Q5 PHEV while FTIV was closed
- Where do these Screws belong? Help with Identification.
- Distance sensing fails
- For AUDI 2018-2021 Q5 B9 CarPlay Car Multimedia IPS Screen GPS Auto Radio Installatio
- Wheel Size? 18" vs 20" - Ride Comfort
- 2024 SQ5 MMI issue when opening apps
- Interior lighting - problem
- Dressing Up
- Transmission Control Module (TCM) Software Limited Warranty Extension
- Water ingress damaging ECU in boot compartment
- Repeated CEL on 2022 Q5
- UK: B&O speaker upgrade with plug and play components?
- 2021 Q5e 0-100% charge in kwh
- Looking for Recommendations: Audi Pure Extended Warranty Sellers
- Molded Mud Flaps
- Driveline Fluids
- Can't tilt up wipers for winter
- Electrical Gremlin - Map light turns on randomly while driving
- 2021 Data Breach - Received $350 check today
- Transfer Case Fluid Change
- 2022 Q5 PHEV - "Loading the System"
- Pre-Purchase: '21 Audi SQ5 P+
- B9 Sq5 washer nozzle problems
- Latest PHEV Recall Thoughts?
- Audi Connect user issues affecting Car Interface
- Keyless Entry Door Sensors not working properly
- Front camera - how can I check if it’s working?
- Clicking from the dash when accelerating or driving
- 2018 AUDI Q5 heat couldn't work stable
- Clunk when pulling away
- Audi Pre Sense is glitchy...
- Installed new filter housing, and weird noise
- moaning when car is turned off
- How to decode style of brake pads on Q5?
- Short trips and the Q5, what is the big deal?
- What type of LED diodes in rear taillight?
- Section of tailgate light not working
- Circuit Breaker Buzzes When Charging
- Lower front fog lights not working
- 22 SQ5 Seat Memory stopped working.
- New SQ5
- Sq5 tire size change
- Loud grinding/shreech/squal noise
- Audi q5 2024
- Parking mishap, need estimate
- Code P2450 Evap Emission Switching Valve Stuck Open
- Distorted windshield
- Advice on SQ5 2024 pricing
- Problem of radiator oil leakage...
- Lane change assist
- 2018 washer pump location
- Audi side Assist
- Clutch Slipping on cold start - 2024 Q5
- Need Help with Armrest Height Adjustment in My 2023 Audi Q5
- SQ5 Phone Icon in Interactive Display
- 2026 Q5 PHEV Redesign
- Sunroof pop??
- Trailer hitch
- Best SQ5 Info Resources?
- B9 2018 chain tensioner or rocket arms….
- 2023 SQ5 Oil Consumption Issue, Buy Back Expectation?
- 2019 SQ5 ticking noise on startup goes away after a few miles
- 2021 SQ5 Hatchback trim separation
- New 2024 Q5 Hesitation/poor acceleration
- Convenience Key Not Working - driver's door
- 21 Q5e PHEV range dropped
- hybrid battery not charging to full
- Rear Cross Traffic Alert
- Scratches - plastic Seat back
- Factory-ordered Q5 arrived w/cracked windshield
- 2018 Q5 Reliability
- Length of B9 SQ5 034 Lowering Links to get 1 1/2" drop on all wheels?
- Low oil
- Wheel stud converson with factory bolt caps possible?
- 2021 SQ5 Updates without an SDcard slot?
- 2024 SQ5 winter wheel and tire setup
- Oil Filter Stand Adapter - Recommend Replacement
- MMI & myAudi app - Caribbean :(
- Found bolt under car…?
- 2023 Q5 - Auto Headlights behavior
- SK: Q5 45 tfsi issue after stage 1 re-map
- Help with Automatic Driver Seat Feature
- temperature range mirror heater turns on?
- AudiCare and mileage-based items
- Wheel Stud Replacement
- 2018 Q5 Coolant Issue
- Remote Start - Automatically Start Heated Steering Wheel
- Pre sense limited
- 2024 Q5 - Can I relocate one of the roof rack cross beams?
- Presense braking for no reason on left hand turns
- Ceramic pad upgrade over stock ??
- 2022 Q5 oil viscosity
- Audi Q5
- Dark mode virtual cockpit
- Verizon appears when carplay is starts
- Apple Carplay stops playing music after text msg?
- Help me buy an Audi!
- HELP! 2020 SQ5 TDI Juddering between 1000-2000rpm
- 2018 Q5
- 2019 SQ5 Traffic Sign Recognition question
- Jerky Downshifting
- 2021 SQ5 engine sound generator issue
- 2018 Q5 Key Fob - Will Not Program
- DSG Transmission Service
- First detail and splash guard question...
- Q5 Headlight Aim, RHD
- Apple Carplay on 2024 Q5
- Q5e A/C Fail Round 2
- best way to set up wife iphone with my Android?
- 90S9 Query UK
- Seepage found under the vehicle?
- Audi Q5 B9.5 parking aid system/sensors retrofit or OBD solution?
- DIY effort level on repairs?
- 2018 Q5 Enable cockpit native navigation with Android Auto on MMI
- Rear Bumper Removal 2020 PHEV
- Headlight Xenon Replacement
- DW06 Tire
- Can’t get enuff marketing (myAudi Canada)
- Transmission whine
- Best Changes Using OBD11?
- 2018 Q5 water/electrical probelems
- USB ports for carplay / android auto stopped working
- UA: What are your favorite upgrades/accessories for your Audi?
- Sticker on back of rear view mirro
- 2024 SQ5 First Oil Change - Compared Vacuum Extraction and Drain Plug
- My car stinks like rain seepage. Are there known leak points?
- Trunk Lip guard?
- Virtual cockpit
- Parking Brake Malfunction, Fuse Blowing, and TPMS Error - Need Help Diagnosing
- '22 Q5
- Improved 2024 Q5 MMI
- New 2024 sq5 owner Looking for exhaust info
- Water Pump & Thermostat on 2018 Q5
- Drive System Malfunction - P001900 - SQ5 2018
- PL: How Mild hybrid works in the Audi Q5?
- OBDEleven needle sweep. Only with acc on?
- Easy Entry only moves back a little bit
- BA: 2021 Q5 - Multiple errors, wont start. Possible CAN bus problem
- Q5 Hitch troubleshooting
- Multiple Issues
- Soundaktor not working on used 2021 SQ5
- 2018 Audi Q5 leaking front axle outer boot lubrication
- Factory service manual options?
- 2018-2019 High Mileage Q5
- 2018 Q5 DSG Fluid/Filters change
- Replacement key fob - your experience?
- Looking at purchasing a 2019 SQ5
- Q5 frim seats
- Used 2024 SQ5 Prestige - good deal?
- Emergency SOS Malfunction
- 2023 Q5 No longer recognizes me as Key User
- 2019 Q5 issues shifting from reverse to drive on cold start
- Q5e Hybrid winter driving questions
- 2018 Audi Q5 front outer CV Joint Boot kit unavailable
- 2018 Audi Q5: Broken Valve (4 months after dashboard malfunction)
- 2024 SQ5 w/Sport package wheels for winter?
- SQ5 Brake Pad Wear Sensor?
- New Q5/SQ5
- Check engine light after installing IE Intake P262B
- Wear Protection & Feynlab Ceramic Coating
- Rattle/vibration from driver side when doing 75MPH + on highway?
- Traffic light recognition
- B9 SQ5 Fluid Spec
- Clacking noise when accelerating in second gear
- 2024 SQ5 - Finance or Lease? I’m Tired of Leasing
- RS: Regarding navigation license
- Q5 MKIII
- '24 SQ5 vs '21 SQ5 - And the Winner Is...
- 2018 Q5 Prestige yellow two pin connector behind grill?
- Does anyone love their Q5 PHEV?
- Farewell to Q5 forum, but now on Q3 forum
- Backup camera issues...and others... help a newbie
- Change virtual cockpit map settings
- B9 SQ5 Differential Fluid Chg
- Carplay won't connect and/or keeps resetting
- MMI restarts randomly with Apple Carplay
- Main Engine Bearing
- Front Windshield Crack need replacement
- Can I reprogram my key fobs to a new lock cylinder
- Audi Q5 TDi 2018 Gateway burned...
- 2025 Q5 hybrid s line
- Need help with Trailer Detection Module
- Protracted repair parts delivery
- 2024 Q5 stop sale notice
- MyAudio App Vehicle Type Changed
- Radiator support splash guard insulation
- Help me understand why Audi/German cars don't use TPMS sensors??
- Recall reminder on MMI
- '18 Keyless Entry Issue + Resolution
- Clicking Steering Wheel - 2021 Q5 PHEV
- Help with two electrical questions?
- 2019 Q5 judder when turning
- SQ5 Sportback held up in port
- "Pop" from roof area
- "Acceptable" Oil Consumption is Bananas
- '23 SQ5 Liftgate opening by itself
- 2024 Rationale and Pricing?
- 2018 Q5 Valve Cover Gasket Leak
- Alarm issues
- 2021 Q5 Front End Diagram
- 2025 Q5?
- 2023 SQ5 hissing sound
- 2020 SQ5 50k Service w/ APR Tune
- 2017 Q5 Starting Issue
- SQ5 Gauge Cluster
- 2018 Q5 Horn Replacement
- New 2024 Q5e Lemon - 2x!!! Help please.
- 40k mile service just done on 2018 Q5 (2.0T), an UPDATE
- 2024 Q5 – 45 – Premium Plus – “Park Assist” Question
- Removing the Phone Box
- 55/50/20 tire fitment 2014 tdi stock 20s
- 2022 Q5 Squeak on Turn
- Q5 Sunroof Class Action
- 2024 Q5e check engine light
- SQ5 Sport Diff oil pressure sensor error
- Serpentine belt
- B9 SQ5 jerky shifts from 1-2-3, reverse sometimes goes to neutral - repair costs?
- Range
