- Intermittent faults following disc and pads change
- A6 Avant coding
- What's your long term MPG?
- Audi a6 C8 intermittent humming noise
- Drive system malfunction!
- Oil level indicator
- 2022 A6 avant 40 TFSI - clicking noise when turning under load
- Key fobs stopped working
- AutoTuner One Smartphone Flasher Now Supports both ECUs and TCUs!
- Locked out of myAudi MMI after PIN reset / Key User issues
- DIY Install: Audi A6 Motorized Lifting Tweeter Speaker
- red flash?
- How to disconnect connectors? (central panel)
- HD Matrix high beam issue
- Bad Luck or....
- Audi A6 Avant C8 suspension question
- Air suspension/Compressor
- Shark fin ripped out of roof by rabid garage door
- On the market
- Battery dead after prolonged fan operation
- How to remove Kick Panel to access BCM?
- Can anyone identify this mystery trim part?
- foot motion 2019 a6
- Audi MLB Evo Drive Select Custom parameters - RS HUD / RS1 Mode / RS button for C8
- 2023 A6 Prestige Brake Squeek in Reverse
- Blacked Out Grill
- Audi A6 C8 tail lights fault
- Front Brake Pads question
- 2023 Audi A6 with 4 cilynder engine
- Service Loaners?
- ME: How to know if my Bcm is lowline or highline?
- Fuel Sensor circuit PO46100 code
- Dreaded coasting/regen
- Audi A6 C8 Ambient Light Retrofit
- Audi A6 C8 Ambient Light Interior Upgrade|Competitive Pricing
- 2019 A6 Prestige C8 3.0 Quattro HELP!
- Aftermarket dipstick for 2021 A6 55 tsfi
- [crazy thoughts] C8 Station Wagon in US
- Short circuit to Ground
- NZ: Pur
- 2019 a6 3.0 liter 12V battery replacement
- RS6 Exhaust Valve actuator spring
- New 2025 A6’s Sure are Priced Attractively
- EA839 3.0T – Cylinder wall scoring?
- Jerky Shifting on Cold Start (D1/R)
- Disable Guest User Profile (Privacy Setting)
- Camera Software Malfunction?
- notes on Mangoal dashcam
- Audi A6 55 TFSI E
- Do Themes require Connect?
- Reverse gear
- Merry Christmas everyone!
- Auto Stop/Start
- Christmas lights and music
- My first Check Engine light!
- 9J et 35 21 inch
- 2021 A6 2.0T coolant level
- Audi C8 radar identyfication part number by VIN
- Quattro Ultra Clutch Rumble & Transmission Quirks on 2022 A6 – My Journey
- Production date?
- FitcamX Dashcam installation question - Interior Rear View Mirror Trim Cover Help
- New wheels
- CANADA: No Remote Start (Audi App)
- washer pump question
- Questions for 2025 owners
- which diagnostic ross-tech or obd11
- How hot is your heated steering wheel?
- 2.0tfsi weird engine sound
- 2023 Audi A6. What type is factory battery?
- Removal of the driver's seat headrest
- dashboard warning lights on my brand new Audi A6 2025.
- Happy Thanksgiving
- Accoustic windshield and glass windows
- New owner questions
- 2025 A6 Dash Cam Installation
- Clicking sound under/around gear shift
- Audicare for low mileage 2019 A6
- BO - almost no sound from rear
- Suspension options on the A6 and S6 C8
- UK: Engine oil?
- BO Subwoofer Upgrade?
- Wierd Audi Cheapo move...Only One Grocery Bag Hook in Trunk
- Mercedes S-class and the RS7 versus 2026+ A6 (C9 platform)
- Front door panel trim removal
- Extended warranty past 70k miles, yes or no?
- 2019 Audi A6 55 TFSI Quattro (3.0T) help me decide
- Question about missing sensor on front grille
- Fuel gauge
- weirdly looking grille
- A6 C8: Seeking SVM Code for A5 zFAS & J428 Radar – LiDAR Removal / Radar‑Only ACC
- Clicking sound when starting the engine
- CarPlay/AA on HUD?
- Tensioner
- Knocking, rubbing noise
- Has anyone disabled the auto headlights?
- Europrice - CarbonFabrik's Only Premier Stocking US Distributor...
- Stage 1 options for V6T C8 A6
- Disconnect frontsensors
- Metal shavings in the oil filter.
- 2.0 tdi mild hybrid odd starting issue
- 2023 A6 faulty fuel tank valve
- Steering wheel click noise
- SE: Reset warning brakepads?
- Issues with parking sensor button
- PL: A6 C8 2021 55tfsi gearbox failure
- Map Sensor A6 C8 40tdi 2018
- Front end sags, compressor runs randomly
- IE: 2023 European A6 Avant
- Wireless charging
- SN: Audi Connect fonctionne pas au Senegal
- 2025.5 3.0T MHEV ON/Off, Coast and acceleration assist?
- 2019 Reset Transmission Adaption Values (now hesitates from stop to 5 KM/H)
- De-badging 2024 A6 allroad
- Non sline rear valance panel paint?
- 2019 A6 C8 Shifts to higher gears at higher speeds that my same 2019 A8 D5
- Weirdness 2025 A6 55 TFSI
- Disable messages
- transmission fluid
- Audi A6 45TDI high-pitched noise
- Oil change with extractor
- 2025 A6 55 Low Speed Hesitation
- Help please (no start)
- OEM airbox - what does this part do?
- 2025 A6 45 2.0T -- Piggy Back Tuning?
- 2019 A6 55 3.0T front shock replacement
- 3.0T owners: what is your fuel economy?
- 2025 A6 55 3.0 -- NO Exhaust tips
- Quattro badge on front grill removal
- front pads and rotors
- 2019 A6 – AC cold on driver side, warm on passenger (B1980 F7 code). Need sensor loca
- Brakes… Rotors and Pads… Finally!
- 2025 A6 55 Premium Plus, Remote Start
- 2019 A6 issues still not fixed after dealership repair
- Engine Air Filter Access
- Transmission blew up, with pics
- Best Audi repair shop in Fairfield County, CT
- Extended test drive tomorrow - advice?
- Oily substance building up on windshield exterior after I detailed my car
- New tire discussion for a 2023 A6 Premium Plus with 19 inch wheels
- Headlight replacement
- Rear suspension sagging
- Top speed of my car??
- VCDS tool Recommendations & why
- Oil Drain Plug Question, after entire oil came out while driving
- parking camera activation speed change?
- The difference between USA matrix headlights and European matrix?
- Got my hidden cup holder coming
- Audi a6 prestige with advanced b&o system
- Digital speedometer
- RS6 C8.5 Interior Problems
- Wish I had known how bad...
- NOx sensor bank 1 sensor 2 fault 50tdi
- Headlights Help!
- The C8 Activations + Retrofits Information Post...
- Rear passenger foot pan soaked.
- Front and Back Brakes Questions
- Opening Door - opened all the windows?
- Engine rattle/bad noise
- 2021 Audi A6 DPF replacement
- Rear defrost fuse
- MATRIX Headlight for A6 Avant UK
- Audi A6 C8 2020-2021 Display upgrade on MIB3
- Km/h to Mph
- Need Help - Completely Disable Lane Departure
- Audi A6 2019 Prestige Ticking noise from glove box
- MMI Question
- Battery Replacement
- A6 45TFSI GER
- Good tuners for audi in the Delaware/ pa area. Or off the shelf tunes.
- C8 S6 Exhaust Wiring Harness Part Number
- A6 warning lights?
- Missing MMi code
- Audi MIB3
- Car cover
- 2019 A6 maneuver assist coding help
- Replace Matrix to HD matrix ?
- Rear Crank Seal Leak (2019 A6 50 TDI)
- BE: A6 55 TFSI E is glowing?
- Retrofit loudspeaker active sound system/Engine sound system
- climate control
- CANBUS Location?
- GPS location problem
- Audi a6 c8 gateway fault
- Has anyone tried taller 255/50-20 tires vs. stock 245/45-20?
- A6 C8 Facelift grill replacement on old 2022 model
- Audi MMI update? - tiles layout
- New Product - OEM A6, S6, RS6, A6 allroad Highline Taillight Packages
- Driver Assistance failure - Heavy Rain
- Am I missing a tool?
- 8G1 to 8G4 Headlight retrofit coding
- Key User Message
- Trickle charger installation
- PR CODES LABEL
- Audi A6 TFSI45
- Virtual Cockpit Adaptation
- Audi A6 headlight issue
- Impossible to enable Video In Motion on A6 C8
- Gearbox tune ?
- Door handle sensor interference?
- Audi abandoning naming strategy change
- Large List of TSB's
- Disable Google Maps in virtual cockpit
- 2021 A6 2.0T - extended warranty worth it?
- ABS Wiring harness part number?
- Camera lane assist
- Sunroof rail replacement
- New or old rocker arms?
- Passenger Seat Power not working
- Rear view camera retrofit
- Rear camera - retrofit
- 2021 Audi A6 C8 VCDS coding
- Rapid oil consumption after oil change A6 3.0 C8
- Parking brake malfunction
- Audi A6 2019 Ambient Lighting Color Not Changing for Passenger Front
- Ac wiring
- Glow plug fault
- A6 Quattro 50 TDI sport suspension to standard
- What mods should I get?
- 6-8 weeks in garage.... Tires, battery???
- Auto Headlights low beams staying on during bright daytime light
- 2019 Audi A6 bad engine
- C8 A6 Allroad 12V Battery Replacement DIY
- Front plate mounting blocks removal
- "Pre Sense" mode of driver assistance
- Water on rear passenger side 2020 Audi A6
- IPA (intelligent parking assist) CB rear axle coding problem
- Quattro ultra clutch
- Rename Navigation Favorites or Shortcuts???
- Little vibration and noise when going in reverse
- google maps (carplay version) smoothness?
- Aftermarket alloys cracking on potholes
- A and B pillars vent
- A6 Avant Automatic - Rattle at low speed
- C8 360deg camera system issue
- C8 Gearbox malfuntion
- EA839 2.9T/3.0T Billet Oil Filter Cap/Housing, any bad consequence?
- Sound when driving
- A6 mild hybrid
- TDI extended emissions warranty in Germany
- Water Pump
- 2021 S6 - many sudden alerts/issues
- AdBlue/Def Failure
- 48V generator: Air-cooled replace previous liquid-cooled one
- "Touch" Opening and Closing door and trunklid won't work
- Tires conundrum
- Apple Car Play unable to activate without cable
