- does a B7 S4 really require 'XL' load range tires?
- 2010 a4/s4 light replacements
- Anyone know of a used catback S4 exhaust?
- Question about tire ratings
- conversion advice.
- Should I put a new clutch in before I sell?
- Best tyres for B7 S4
- Anyone here have experience with SPEC clutches?
- B7 S4 AUX Audio Input
- Xenon lights RH switching off 1 sec after the LH
- a/c compressor critical failure - request opinions - long
- B6 S4 - Temp Gauge problem?
- B6 S4 wheels / tires
- VMR | Wheels - V708 RS4 Style PRE-ORDER
- timing chain replacement?
- VMR | Wheels - July 4th Pre-order Specials!
- Wallpaper
- Factory E-Code Part Numbers?
- Looking for mechanic recommendation???
- Down Pipe question.
- VMR | Wheels - Photoshoot 19x10 All Around
- 2006 S4 Avant iphone integration
- Is There a Fix for Interior Wear?
- thinking its time to sell my S4 avant
- USB port in the Audi nav???
- Car shipping
- VMR | Wheels - V713 Split Spoke Design IN STOCK!
- B6 S4 vs B6 A4 3.0 vs B7 A4 3.2
- New Shoes
- Sorry if posted before; B7 TailLights on B6 S4
- New to the fold - 2004 White S4
- E-Code Headlight Housings...Avaiable anywhere?
- TT RS steering wheel retrofit into B6 S4?
- Wah Wah
- RNS-E upgrade help needed..I did search...:)
- after start engine gargle?
- VMR | Wheels - V709 Multi Spoke Wheels IN STOCK
- looking for a B6 S4 owner in Greenville, SC area...
- Valve cover replacement
- Audi Anarchy 2010 (formerly S-fest West) is now open for registration. Check inside..
- VMR | Wheels - Fitment Availability
- 20 Inch RS4 rims
- what is the power split front to rear on a b6 s4?
- Class Action Suit '04 Sunroof
- 2005.5 S4
- Cat. removal of stock exhaust?
- Radio Code
- 150 Miles a tank...
- Audi S4 2005 vs. Audi S4 2005.5
- B6 S4 Camber kit.
- Anyone have the Bilstein PSS 9/10 Coilovers?
- Performance coil packs.
- Transmission won't shift into gear. Please help.
- What color is OEM Xenon?
- VMR Studio Photo Invitation
- Leaking Oil After Audi Service
- About to go Quattro-less for first time in 24 years!
- C32, S4 or S2000
- ECU tuning
- Question regarding Paddle Shifters B6 vs B7
- Steering issue - suggestions?
- How often do you change your OIL?
- VMR V701 18x8.5 Release
- Speakers
- Buying (maybe) a 2005 S4
- Help? Nut behind the dash, no, really!
- Hi from new owner and audio question
- pairing problem
- VMR Wheels | Massive May Pre-orders!
- B6 Audi S4 (2004) - Servotronic issue
- Ticking noise at start up
- Ignition Coil Failure, or something more?
- About to buy this S4!! for $22k too good to be true?
- 65K service...
- Porsche vs Audi
- Value of 2004 S4 with trashed motor?
- Dropped Valve, Catastrophic Engine Failure!
- 200 mile range, really
- S4 B6 6 speed manual throttle delay?
- Car Cover
- New S4 owner..... Clicking Noise from Front right Of Suspension
- HI to all !!! I need advice on the audi s4
- Anyone looking to sell? I've got a buddy looking for S4 Cab...
- Scratched Steering Wheel- What Can I Do?!
- Abused Flywheel? *pics in post*
- New owner
- v8 badges
- bumper adjustment help
- Trailer Hitch
- Check Engine Light, Flashing when on Throttle
- curb smack
- Things to look for in a 2005 S4 Avant
- Detailer's Domain: Audi S4
- Possible transmission problem
- Audi S4 B7 body kit(s)?
- RPM Idle is not stable
- Looking for shop in Seattle to do a PPI on an S4
- Default hahahaha...anyone still want to discuss the PES M90 supercharger for the S4
- hahahaha...anyone still want to discuss the PES M90 supercharger for the S4?
- Value of 2004 S4 with blown motor?
- 2005 s4 lower springs
- New coil packs, now a dead engine speed sensor?
- XM tuner
- Avant Sub Install Part 1
- :: ECS Tuning :: Auto-tinting rear view mirror - 94% OFF
- A4 to S4 Conversion or more power in A4
- What does the 45K service entail?
- Need Motor mounts?
- 2 Issues: Tiptronic, Gear Holding, and Suspension...
- Where do I start?
- UPGRADING S4 B7 V8 IS DIFFICULT...ANY TIPS?
- Soon to be an owning 2004 audi S4
- Purchashing 2004 b6 s4
- My current hell...I have engine #1066...Bummer...!
- Wheels
- Is a Flexplate the same thing as a Flywheel?
- Newbie with a 2007 S4 Questions
- Help needed...Engine Designation on a 2004 S4
- lowering s4 2005
- 2005 S4 Cab replace tail lights with '07/'08 lights
- trunk size
- Stratmosphere Hyperflow Induction
- White soot on rear of car and not sure why - any answers?
- Anyone have the Bilstein B16 PSS 9/10 System installed?
- Upper link bushing replacement - how much?
- Magnaflow 14851- 2k mile Exhaust Review
- Bad Engine Vibration
- B7 S4 & B7 RS4 diferences?
- 2005 Audi S4 - Maintenance advice
- just bought one
- 2005 S4 Cabriolet with 7040 miles
- Convertible car seat recommendations?
- Revo Technik Spring Sale Marth 27th - April 11th 2010
- Turbo S4 or V8 S4?
- Newbie
- S4 revving/slipping on acceleration (automatic)
- B6 S4 Cabriolet ski pass thru fit a snowboard?
- Tail light replacement with LED?
- Rough Idle
- 2010 Audi S4 Review
- RSN-E
- VMR Updated Wheel Inventory!
- Am I missing something ... where are all the DIYs?
- B6 S4 diy oil change?
- new here
- broke a belt tonight
- Diagnose my car?
- I have 3x ContiSport Contact 2s and 1 (bent) OEM 18" rim up for grabs in Chicago...
- Just bought new (used) '04 S4...
- S4 Cabrio Check Engine Light
- Does anyone use ATE Super Blue brake fluid?
- Softer suspension
- VMR | Wheels - V718 Mesh *Photos Updated*
- Wind Guard?
- buying this car...trying to locate original owner 05 Avant - Black in PA
- 05 S4 tire size
- PureMS: New Stern Motor Mounts for B6/B7 S4
- 05 Battery Drain - Radiator Fan
- Anyone in Toronto with Aftermarket Exhaust?
- 2004 A4 avant Trip 83k mls 16K
- Buying '04 S4, here's my deal...Input ASAP please...
- HELP pop/bang comin from suspension
- Anyone have a good source for a 4.2 S4 engine other than dealer - new or used?
- 04 S4 Air conditioning not working
- Just got an S4 - Needs Electronics Update - What Should I Get?
- Why would I only be getting right side XM?
- B7 S4 newbie - Need help to see if anything is missing on this S4
- Oil Problem
- A Moral Dilemma
- A/C Heat Climate Control Fan Rattle
- What the hell do I have here?!?!
- Coil Packs ...
- X-post: Dyno Day at ASP 03/27 Post up interest
- Where's my speed limiter?
- looking for an avant
- How do I route the GPS antenna cable from the sharkfin antenna?
- best short shifter?
- My RNS-E arrived From navplus, do I need the radio PIN code?
- How much would you pay for this S4...?
- Coolant smell...?...:(
- Can anybody recommend good indy shop in N.NJ?
- Getting new wheels and tires...HELP!
- need purchasing input
- New Stern Motor Mounts now available!
- VMR | Wheels - V718 Signature Mesh!
- Bad smell when I get on it
- CEL PO171 Help (2004 S4)
- advise on 2004 S4 after market warranty
- 2004 S4 Cabrio B6 Aftermarket Tail Lights?
- Trailer Hitch
- Got a flat tire, have questions regarding replacement & quattro
- Trade 135 for B7S4?
- 2004 Audi B6 S4 Remaining Part Out
- .:EuroCode Tuning:. KW Inox Line Suspension Specials for AW Members (all chassis)
- 05 S4 Cabriolet, Thermostat Replacement
- 04 S4, Question about rearview mirror
- Desperately Need your help!!
- sway bar settings
- Have new oil filter and couple spark plugs...
- FS: B6 S4 Gray/Black Alcantera Seats Central PA
- Coolant leak with 04 S4 - Help!
- Traded in the 2004 S4 Cab, now selling parts
- understeer into snap oversteer
- cold start problem & electical fault
- do these B6 wheels fit the B7?
- Replacing aux radiator
- Check Engine Light.
- S4 with iPod prep, need to charge iPhone 3GS
- 2010 Audi S4 MTM ECU Tuning Module
- Most HP possible
- Potential new B6 S4 owner questions
- VMR Wheels | V709 Multi Spoke
- Exhaust!!!!
- Throttle Body Adjustment via VAG-COM
- B6 S4 selling prices
- 2005 S4 - Supercharger Upgrade? Help!
- lug bolt locks
- Need help with Engine Replacement
- Helix LED Euro tail lamps
- Finally, Google Earth for GPS...
- VMR Wheels | V710 18" and 19"
- Burning Oil
- Thermostat replacement
- Price: Sedan vs Avant
- VMR | Wheels - V708 RS4 Style Wheel
- Starting issue???
- new here!
- S4 Seat Replacement
- In search of a NICE exhaust for my B6 Audi S4 automatic
- Temperature question
