What's the interval time to refill A/C? Thank you.
Old Aug 22, 2001 | 04:58 AM
A. Freire's Avatar
New Member
Old Aug 22, 2001 | 05:53 AM
WClark's Avatar
Member
Default A/C as in Air Conditioner?
If so, there is no consumption of coolant so baring a failure and coolant leak, no refill is required.
Old Aug 22, 2001 | 05:54 AM
Tony T.'s Avatar
New Member
Re: I think that there is not a well-defined interval to refill your A/C
Old Aug 22, 2001 | 05:57 AM
A. Freire's Avatar
New Member
Re: Yes
Old Aug 22, 2001 | 06:13 AM
Auditude's Avatar
Junior Member
Default Agreed. Refrigerant is not consumed. If you're blowing cold air you don't need refill.
If you're not blowing cold air you have a leak or other defect.
Old Aug 22, 2001 | 06:14 AM
HDClown's Avatar
when it stops getting cold, fill it
Old Aug 22, 2001 | 06:58 AM
KenK in TX's Avatar
Default Maybe a better question would be A/C service interval...
...I live in Houston, which is unbearably hot and humid - which is quite hard on A/C systems. Although its a closed system, I have heard that there is a filter and/or something to do with moisture that should be replaced proactively in extreme climates like this.
More than one person has recommended proactive maintenance, but this could easily be an urban legend or plain old b.s.
mug23
Feb 24, 2016 06:56 AM
A4NCAR
Jan 26, 2004 10:23 AM
Zzak
12
Nov 18, 2003 04:08 PM
UrSoccer_mobileĀ®
Aug 15, 2003 07:28 AM
Hawaiiannights
May 15, 2001 03:52 AM
