Cross-over point of 'subs' on 2000 Bose factory system
I am having an amp and 8" sealed Solo-baric installed on Friday.
Does anyone know the cross-over point of the factory 'subs'?
One shop I talked with about a JL Audio Stealth box said that the factory 'subs' were removed with that set-up, so the 8's could vent through the existing holes, and the amp was set to 'full range', utilizing the factory cross-over point.
It may make sense to do the same thing with a Solobaric, if the cross over point is low enough.
Any input is appreciated.
I like to get an adjustable crossover and play with it to tame midbass boom while trying to make a seamless transition.
Using the same values with a different woofer is generally not very helpful, as the woofer response itself affects results.
You probably want to roll it off around 80-120 Hz.
