Did the licencse plate mod on my lunch break..
You can't use the nylon spacers, the screws are not long enough, but with out those it fits fine with the screw caps and what have you.. I think it looks nice and I suggest it to anyone wanting to do a quick mod...
Really just cutting off the black on the bottom that sticks out and the two corners..
This mod is to make the plate fulsh with the black spacer behind it, it needs to be done if you want to add a frame to the back of your car.
I will take pics and have them up in a couple days.
The license plate is screwed into a black plastic backing that is hex screwed into your car.
Remove license plate
Remove hex screws. Pull Black plastic backing off of car (it is held on by some black goo - just pull. Leave car in sun for awile to loosen it up)
Use a Dremel -w- cutting wheel and take off @1/2" of the bottom. Don't use fastest speed as the plastic will melt as you cut. There is a honeycomb pattern on the back of this black backing. A horizontal honeycomb is at exactly 1/2" - a perfect guide for you.
Once it is cut, use a sanding drum and smooth it. This part is messy.
Restick the black backing (no need for additional adhesive) onto your car. Hex screw it on. Screw in your license. Viola!
