Replacing Brake Pads as in FAQ Question
Old Dec 21, 1998 | 10:04 AM
Howard Kim
Guest
Posts: n/a
Default Replacing Brake Pads as in FAQ Question
How difficult is the brake pad replacement as described in the FAQ. Any input from people that have done it would be great.<p>Thanks,<br>Howard Kim<br>98 A4 1.8tms(neu)
Old Dec 21, 1998 | 10:27 AM
SteveW
Guest
Posts: n/a
Default Re: Replacing Brake Pads as in FAQ Question
A piece of cake. after the hex bolts come off and the spring is off they are apart. Be sure to remove the caps covering the hex bolts. Use some break Quiet on the inner pad the one with the prongs - and spread the prongs apart so it fits in tight to avoid squeel - this is important if you don't want to mess with them again.
Old Dec 22, 1998 | 03:31 PM
Steve S.
Guest
Posts: n/a
Default Corey and I did his....
The hardest part was :<p>1) The first one we did<br>2) Depressing in the brake doohickey, so that the shoe would fit (the brake fluid rises as you do it.)<p>I would suggest doing it with a friend. We did all four of his brake shoes...and my two front brembro brake rotors in about 2.5 hours. Atleast I think we did. :-)<p>Steve S.<br>97 2.8QM
ColoradoMark
A6 (C7 Platform) Discussion
Jun 2, 2017 01:40 PM
life4sk8
Apr 16, 2014 01:41 PM
Reinman
Sep 15, 2007 07:13 AM
a4avant99
Mar 18, 2007 05:00 PM
eldoj
Jul 6, 2005 09:57 AM
