Concert radio display bugs
Old Dec 20, 1998 | 05:04 PM
Mark M
Guest
Posts: n/a
Default Concert radio display bugs
Has anyone else found odd intermittent bugs in the stock Concert head display ? A few weeks ago when I powered up all of the display positions cycled rapidly and continuously through all digits (i.e. every position was rapidly counting from 0 to 9 over and over again). When I turned off and on again display became normal. Then tonight all the radio display was not illuminated - lights were on, center console light normally, but head unit completely dark. Again radio power on/off a couple of times and the display finally comes on normal - spooky.<p>Mark M. 99 A4 Avant 2.8 Tip Q - love it !
Old Dec 21, 1998 | 10:12 AM
sk
Guest
Posts: n/a
Default Re: YOUR Concert radio MAY HAVE SOME PROBLEMS
The first "problem" you described, i.e., "the display positions cycled rapidly and continuously through all digits" is normal when you turn on the radio and press Preset 1 at the same time - this is a diagnostic mode, and it gives you the strength of the radio signal, 1 being the lowest, going up to 0 (like 10) and then from A through E, being the strongest signal. So maybe you pressed the Preset 1 when you turned the radio on. If not, than it could be some short in it, which would then explain the no-lights thing as well. Go to the dealer… Good luck.
bac2h
Mar 1, 2008 02:18 PM
RD Olivaw
A4 (B7 Platform) Discussion
Nov 16, 2005 02:31 PM
kips
Audi A3 / S3 / RS 3
Feb 11, 2004 07:25 AM
Imola Ghost
Dec 18, 2002 09:59 AM
FrankM2.7
Dec 27, 2001 07:14 AM
