Is the A4 made for winter?!
Old Dec 23, 1998 | 06:11 AM
Frank Fejes
Guest
Posts: n/a
Default Is the A4 made for winter?!
Hello all. Let me first start by saying that one of the main reasons I purchased my A4 was for what I felt would be a superior winter driving experience here in Chicago. However, now that temperatures have dropped, I am questioning my decision. Since temperatures have been < 30 degrees, it has taken 5-10 minutes for the engine to warm up. It takes close to that time for the heater to start giving off warm air. And, what really began to tick me off yesterday (when the temperature guage read 2-9 degrees) was that the brakes squeaked LOUDLY until the car had warmed up. I have owned this 98.5 1.8TQMS for < 5 months and, except for a few rattles and vibrations that I have fixed, I have been very happy with the car. But I cannot believe the car could feel so...I don't know...*fragile* in the cold, especially when every Honda I have owned has never displayed these characteristics.<br> Is this something I should worry about with my particular car or is this common? Thanks.<p>--frank<br>98.5 A4 1.8TQMS All-Weather, Bose
Old Dec 23, 1998 | 06:44 AM
DaveL
Guest
Posts: n/a
Default I think you may be over reacting a bit....
Cars may offer features that make winter driving safer or more comfortable (quattro, heated mirrors, heated seats, etc), but I think the issues you raise are going to be the case in any car on the road.<p>At temperatures in the single digits, ANY car will take time to warm up! Imagine sitting outside all night long in sub-zero wind chill. It would be quite a technological advancement to have a car warm up in an instant. Personally, I like the feature where the heater doesn't blow air unitl it's warm enough. I'd rather just sit in the cold, than sit in the cold with cold air blowing at me as well. Plus the seat heaters set at 6 are awesome!<p>As for the sqeaky brakes, that is not necessarily a product of the cold weather. There are many Audis and other german cars with sqeaky brakes even in the warm weather. The sqeaking and brake dust are a result of the brake pads that german car makers choose to use. All of my family's 7 Audis have had squeaky brakes a t one point or another, and many friends with BMW, VW, and M-Bs have had them as well. Brake performance, however, has always been excellent!<p>Wait until you drive try the quattro in some heavy snow...you won't regret your decision to buy an Audi!!! <p>Maybe you should invest in a remote starter, if you really want to be warm when you get in the car.<p>Dave<br>'97 1.8TQMS<br>
Old Dec 23, 1998 | 06:58 AM
Frank Fejes
Guest
Posts: n/a
Default Re: I think you may be over reacting a bit....
I never claimed to expect a car to be warm immediately. I do NOT think it is too much to ask for an engine to be warmed up and the heater to be spitting out warm air before 5-10 minutes. As I had said, all the Hondas I've owned have done both in less than 5 minutes and even the american rental car slugs are around there (and most of their heaters are even quicker).<p>--frank
Old Dec 23, 1998 | 07:00 AM
Todd W
Guest
Posts: n/a
Default Drive it harder, and change brake pads
It would be a shame to hate a $25K+ car for $200 in mods. Also, the harder you drive it the quicker it warms up, heater and brakes. :-)))))) (Just let the oil warm up a little first)<p>I have found that Audis love to play in the winter, but prefer to sleep in the garage.<p>Todd W
Old Dec 23, 1998 | 07:17 AM
John
Guest
Posts: n/a
Default Re: Is the A4 made for winter?! Hell, yes.
Sorry to say so, but I think you have your priorities somewhat backwards.<br>Put some nice 5W-30 Mobile 1 in to protect your engine. Then turn on your seat heater! It takes your engine some time to warm up because it's cold! Let it warm up with easy driving. Take care of your A4 and it will take care of you. I am very warm in my seat long before my coolant temp gets to 12 o'clock.<br>Your seats have electric block heaters for your body, how about getting one for your poor engine?
Old Dec 23, 1998 | 08:03 AM
DaveL
Guest
Posts: n/a
Hopefully the 5 minute difference won't make you regret your purchase...I love mine!
Old Dec 23, 1998 | 08:04 AM
JimV
Guest
Posts: n/a
Default heater optimal settings for a quick warm up
The owners manual specifically says to put the climate control on 75 degrees and medium to max air and the car can most efficiently get the car warm.<p>Its under 'using the heater' in the manual.<p>I owned two hondas (acura) before this and I think the Audi heats up sufficiently and as quick as the Hondas. Be glad you arent driving american.
Old Dec 23, 1998 | 08:07 AM
Paul Henne
Guest
Posts: n/a
I own a 98.5 1.8TQS/Tip and this has not been my experience.<p>In fact, just this morning it was 19 deg. (F) and I had heat in less than 5 minutes, nor were my brakes sqealing. The engine was a little sluggish at first, but I keep my foot out of it when the engine is cold to keep the boost levels down (boost isn't the greatest for a cold engine).<p>One thing that I do which may make the difference is put the Tip in manual mode at first so I can let the engine wind it's way up to 3000 RPM before shifting (obviously people with manual transmissions can try this just as a matter of course). I don't give it much throttle, I just sort of let it gradually wind up there and then I shift. The road away from my home is 35 MPH and I leave it in 4th for the duration of this drive (1-2 minutes). When I hit the main road I put the gear selector in 4 (not D) and allow a bit more throttle, enough to cause the Tip to rev up to just over 4000 RPM before it shifts. Driving it this way I usually have heat within 30 seconds after hitting the main road. I've never timed it, but it's about 3 minutes, even quicker than the Saturn I used to drive, which always took at least 5 minutes to start giving heat.<p>Anyways, I hope this helps.<p>Paul
 Michael S. Palmer
Old Dec 23, 1998 | 08:38 AM
KAZ
Guest
Posts: n/a
I noticed this morning (first really cold night) that it really does take the 1.8T a while to warm up... longer than my Corrado did with same size engine. The seat heaters however kick in like gangbusters sending a nice warm feeling through the bones. I'd say that if you've had cold weather experience with your A4 and this bothers you, get a block heater. I've only had my A4 for 500 miles so I haven't adjusted yet from the 7 years I've driven my Corrado.
Old Dec 23, 1998 | 11:04 AM
AndyD
Guest
Posts: n/a
Yesterday morning it was minus 11 F and this morning it was minus 4. My seat heaters kick in within a half mile of the house and the heater is starting to pump warm air within two miles. The engine is fully warmed up between 4 and 5 miles from home, although the oil temp is running much cooler than in the summer.<p>That's quick enough for me, but as someone said in another thread, thank god for seat heaters.<p>Andy 1.8TQm
