Brake Pad Replacement
Old Dec 23, 1998 | 12:15 PM
Rob Mack
Guest
Posts: n/a
Default Brake Pad Replacement
Have the Raybestos pads in my hands... now, do I go to my dealer who's kinda pricey, or do I go to my local garage, who does good work and is cheaper than my dealer? If any good shop can do it, why bother with the dealer? Warranty issues? Good installation job? Impressions, comments, suggestions appreciated. <p>Rob 1.8 TQT soon to be w/o dirty wheels...
Old Dec 23, 1998 | 02:27 PM
SteveW
Guest
Posts: n/a
Default Re: Brake Pad Replacement - Rob do it yourself!!
It is VERY easy and you will have the satisfaction of knowing how to do it yourself. Check the archives for the info or Jack up and remove the wheel, pull the plastic caps off the hex bolts (7mm I think), remove bolts, pull off the spring voila the pads are out, reverse proceedure for install. Just make sure the three prong thing on the new pads fits tightly (to avoid rattle noise and squeel) I used brake quiet to be extra sure. Takes about 20 min for both. Archieves will give you step by step if needed. it is easy give it a try - we'll make you a do it yourselfer and you can take out the wife or girlfriend for a nice dinner.Hope this helps..
Old Dec 23, 1998 | 09:37 PM
Fly Boy
Guest
Posts: n/a
Don't forget to cut the rotors!
Old Dec 24, 1998 | 05:13 AM
Rob Mack
Guest
Posts: n/a
Well, if I had ANY tools whatsoever and the slightest hint of any mechanical aptitude w/ cars, I would jack that baby up and replace the pads myself. BUT, since I have neither of the above and I don't feel like learning, I ask the question again: dealer or local garage? Replies appreciated<p>Rob
Old Dec 24, 1998 | 07:52 AM
mywheels
Guest
Posts: n/a
I did mine myself, I have average mechanical abilities. I had never done brakes before. It was a piece of cake. If you don't want to do it, take it to your local independent that you trust (should be cheaper than the dealer).
Old Dec 24, 1998 | 07:54 AM
mywheels
Guest
Posts: n/a
Default "cut the rotors"? What does this mean?
TIA
Old Dec 24, 1998 | 11:28 AM
Andy Hedin
Guest
Posts: n/a
Default It means to resurface the rotors on a brake lathe (more)
The brake lathe will remove part of the surface of both sides of the rotor. It evens the surface out and makes sure that it is perfectly flat. Local garages should have this equipment. Some local auto parts stores will also do this for you.
Old Dec 25, 1998 | 01:29 AM
Guest
Guest
Posts: n/a
aka &quot;turn the rotors&quot;
 Michael S. Palmer
Old Dec 25, 1998 | 11:52 PM
mywheels
Guest
Posts: n/a
Heard &quot;turning rotors&quot; before, but not &quot;cutting&quot;... learn something new every day
salvadorik
A6 (C7 Platform) Discussion
10
Nov 6, 2012 02:57 PM
joaudi
11
Dec 27, 2004 01:40 PM
George Burdell
Sep 27, 2004 05:39 AM
f3d
Oct 27, 2002 08:32 PM
CraigB
Oct 29, 1998 09:02 AM
