need some input!
Old Nov 13, 2001 | 03:19 PM
wingba45's Avatar
New Member
Default need some input!
thinking about getting a 1997 or 1998 A4 1.8t but not sure what year is better and if i should get QUATTRO? i need some input from people that have either or. thanx
wingba45
Old Nov 13, 2001 | 03:22 PM
Sal R.'s Avatar
Default If you can...stick w/ the 98 as 97 has had problems w/ wastegate rod failures...
...and quattro would be nice. If you going to mod (i.e. exhaust, suspension), it'll be easier if you have quattro as there is a wider aftermarket support than the FWD market. Go figure.
Old Nov 13, 2001 | 03:23 PM
Au[)! 4 LIFE's Avatar
Junior Member
Quattro would be nice to have, i don't
Old Nov 13, 2001 | 03:25 PM
audi2001a4's Avatar
New Member
i second sal r. stick w/ the 98 and get quattro
Old Nov 13, 2001 | 03:26 PM
wingba45's Avatar
New Member
Default Re: If you can...stick w/ the 98 as 97 has had problems w/ wastegate rod failures...
i hear that quattro make the A4 alot slower then just FWD. True/False
can i get better performance with quattro?
wingba45
Old Nov 13, 2001 | 03:30 PM
Sal R.'s Avatar
Default Well...
...it's true that quattro will make the car heavier and have higher driveline losses that will result in lower wheel hp than our FWD counterpart. Off the line, quattro will take a FWD easy, assuming they're both A4's with the same amount of mods. However, if you take the time to search around for parts and mods, you'll find that there is a greater aftermarket support for quattro than FWD. If you going to mod heavily, might prove to be more difficult, but it can be done will a lot of research and possibly custom work.
wingba45's Avatar
New Member
thanx boyz needed that. anything else i should look out for?
Old Nov 13, 2001 | 03:37 PM
Jon G's Avatar
Member
'98 Quatto
 Michael S. Palmer
Old Nov 13, 2001 | 03:44 PM
wingba45's Avatar
New Member
what if i get an auto with a shift chip? will that make up for not going with stick?
Old Nov 13, 2001 | 05:16 PM
BoostLad's Avatar
Default Re: need some input!
My vote (and i'm a little partial) is to go with a 98.5 if you can- alot changed in that half-year, plus you get the look of the newer A4s (no orange tails, etc). Tis the best for the buck. Good luck. Oh yeah- definately Quattro.
