So I got the 18" RE's on the car now...I noticed the tire dudes only put in 35 lbs of air...
Old Nov 13, 2001 | 07:00 PM
James R.'s Avatar
Default So I got the 18" RE's on the car now...I noticed the tire dudes only put in 35 lbs of air...
I found this out after about 40 miles of driving...so I doubt there's any tire damage (there damn well better not be) my first tip off was the ride was as good if not better than my 17" wheels and tires. I hopped out and checked...uhh ohh only 35 lbs. weak trash. So I popped into the gas station and pumped em up to 40 lbs which was just a value I guessed at since I used to run 37~38 cold on my Oettingers in 17"
So I guess the question is...is 40 lbs enuf, what are other people running? I guess it's a compromise between ride quality and wheel protection. If you go too far either way you jeopardize the wheel...aka hard *** tire = bent wheel too.
Regards,
James R.
Old Nov 13, 2001 | 07:04 PM
Skene @ PES Tuning's Avatar
Elder Member
Default nothing wrong with running at 35.. this allows your suspension to absorb
whereas running at more pressure it takes an adverse affect on the rims.
Old Nov 13, 2001 | 07:07 PM
plug1's Avatar
I met an Aw'er that was running 40 front and 38 rear on 19's...in downtown CHICAGO, no problems.
Old Nov 13, 2001 | 07:16 PM
Yippers®'s Avatar
Member
35 lbs ??? That's even heavier than the CHs
Old Nov 13, 2001 | 07:21 PM
Catfish's Avatar
Junior Member
I have 40psi front & rear for wheel protection.
Old Nov 13, 2001 | 07:34 PM
BOOSTD's Avatar
Elder Member
MAYDAY MAYDAY WE HAVE HIT ICE
Old Nov 13, 2001 | 07:48 PM
Yippers®'s Avatar
Member
lol
Old Nov 13, 2001 | 08:00 PM
Dead's Avatar
Elder Member
....and the brakes? :-(
 Michael S. Palmer
Old Nov 13, 2001 | 08:40 PM
2R8Sand1RS4's Avatar
Elder Member
i have 18" RE's, i have asked but havent gotten a straight answer, right now i run at about 38
Old Nov 13, 2001 | 08:43 PM
brian@avalonmotorsports's Avatar
Former Vendor
James,40lbs is right on !!
