Rich vs Lean? Can someone please explain this (causes, etc)?!?
Old Nov 14, 2001 | 10:07 AM
audi168's Avatar
New Member
Old Nov 14, 2001 | 10:10 AM
markbradford's Avatar
Rest In Peace
Summary: Rich = too much gas. Lean = Too much air
Old Nov 14, 2001 | 10:31 AM
Ray Khan's Avatar
Default Think I'm running rich...always get some black crap on the lower part of my exhaust tips after
cleaning them. I think I should be getting slightly better mileage too...so that adds to my theory. I need to get someone with a VAG to confirm this.
Old Nov 14, 2001 | 10:33 AM
Rest In Peace
Never gotten a rich DTC and I have the same symptom.
Old Nov 14, 2001 | 10:35 AM
MikekiM@PureMS's Avatar
Former Vendor
Default re: rich vs. lean
A car generally runs ideally with a certain air to fuel ratio. Call it's A/F ratio, or number. A rich condition exists when th ratio is smaller than the prescribed A/F number (or the F is bigger than it's supposed to be), and a lean condition exists when the A/F number is high than prescribed (or the A is bigger than it's supposed to be). On a carb car, lots of things can cause a car to run rich, or lean, however on a fuel injected, or computer controlled injection, like the A4, it's a little more difficult. Usually faulty parts cause the situation, like a faulty O2 sensor, a torn boot, or hose, a faulty air flow meter, etc.
Old Nov 14, 2001 | 11:11 AM
Ray Khan's Avatar
Default weird...ever ask other APR chip owners about this? Ask APR?
My tips are blackened very quickly after cleaning...probably in 2-3 days.
Old Nov 14, 2001 | 11:27 AM
Rest In Peace
Newp - I think all tips get blackened that quickly.
Old Nov 14, 2001 | 11:50 AM
JWG's Avatar
JWG
Member
Default Causes: (1) O2 or other sensors not functioning properly; (2) ECU poorly programmed/malfunct. . . .
(3) mechanical malfunction/blockage in fuel/air systems.
Just think through how too much/little fuel/air could get into the cylinder; you get fuel from the fuel pump-rail-injectors and air through the airbox-MAF-plenum-TB-Manifold. The ECU should correctly control the mixture if everything works right.
Despite our advances in electronics and technology, we remain like our prehistoric ancestors playing with fire. The internal combustion engine remains a fairly primitive invention, because fire will always require fuel and oxygen in the proper amounts to burn.
 Michael S. Palmer
Arcteryx::Stock Rods
22
Mar 23, 2006 10:47 PM
oldyellar
12
Apr 11, 2005 12:49 AM
JohnStr
Oct 6, 2004 07:35 AM
KD
VAG-COM Discussion
Mar 29, 2003 05:52 PM
