I just installed the Bentley CD-ROM repair manual, but it won't run
Old Feb 10, 2002 | 12:24 PM
criptik's Avatar
New Member
Default I just installed the Bentley CD-ROM repair manual, but it won't run
And I'm running Windows XP with a Pentium 4...is this the problem? I already emailed Bentley about it...anyone know if I can do anything in the meantime to make the program work?
Old Feb 10, 2002 | 12:26 PM
bugbbq's Avatar
Default are you reading the info off the disc or on the HD?
I had troubles with it also, then I just copied all the files to the HD and it worked fine for me.
Old Feb 10, 2002 | 12:28 PM
criptik's Avatar
New Member
Default I just installed it according to the CD-ROM's instructions...
I should copy the entire CD-ROM to my hard drive, then install it from there?
Old Feb 10, 2002 | 12:45 PM
addifan's Avatar
Default Did XP...
Give you the little warning box that the program has not been tested? Maybe it's not compatible with XP. What exactly is happening when you try to run the program? One thing, if it is compatible with Win '00 it should work fine with XP.
Old Feb 10, 2002 | 12:50 PM
criptik's Avatar
New Member
Default This is the error message I get:
Java Virtual machine Launcher
Could not find the main class. Program will exit!
criptik's Avatar
New Member
Another weird thing is that I can't uninstall it through Control Panels
Old Feb 10, 2002 | 12:54 PM
D3NN77's Avatar
New Member
Where did you get it from I am looking for one my self
Old Feb 10, 2002 | 12:56 PM
VicG's Avatar
Not all Win2k apps run rite on XP. Roxio CD creator is one example. VERY pickey...
 Pouria Savadkouei
 Michael S. Palmer
Old Feb 10, 2002 | 12:57 PM
bugbbq's Avatar
Default you're lucky I'm tech support.
go to www.microsoft.com/java and download the latest VM (virtual machine) build.
Old Feb 10, 2002 | 12:58 PM
criptik's Avatar
New Member
Default I forget...but www.alloemaudiparts.com has them.
<ul><li><a href="http://www.alloemaudiparts.com">http://www.alloemaudiparts.com</a</li></ul>
