TT install question...
Old Feb 10, 2002 | 04:38 PM
RedBlackYellow's Avatar
Default TT install question...
I suck at soldering, is it *required* that i solder the connections or just good practice?
Old Feb 10, 2002 | 04:43 PM
Matt H. (Silroan)'s Avatar
Member
Do you really want to risk it?...
Old Feb 10, 2002 | 04:54 PM
Default frankly i don't see what the big difference is between soldering it and just wrapping it
tightly w/ elec. tape.
Old Feb 10, 2002 | 04:59 PM
CMC's Avatar
CMC
I used tape when I installed my TT. It's worked fine for the past 3 years.
Old Feb 10, 2002 | 05:00 PM
Yippers®'s Avatar
Member
Default Often the difference is trouble free life of the wiring looms vs electrical gremilins or
that icky burning wire smell if the connection corrodes or loosens. I'd solder personally.
Old Feb 10, 2002 | 05:01 PM
Pizzicato's Avatar
Member
With time it will loosen up and oxidize !! better off soldering it
mech IFR's Avatar
Default soldering is just the "permanent" solution. it's more professional....
But I don't see why you couldn't get by with just wrapping em. I just soldered em because I dont want to worry about them again. Tapping them well will give you the same result as if you had soldered them, but you just dont have the "comfort factor" included, at least it wouldnt for me.
Old Feb 10, 2002 | 05:22 PM
James R.'s Avatar
Default Pay someone to solder it then...solder is IMHO the only REAL option
it's that or wire tap connectors which are designed to keep pressure on the wire so it can't come loose. Sure you might get away with wrapping...but it's seriously shady, contact resistance goes up...the wires get hot...it's not good stuff to have going on behind your dash...do the right thing and solder.
Regards,
James R.
 Pouria Savadkouei
 Michael S. Palmer
maray4
TT (Mk2) Discussion
Jan 11, 2010 01:43 AM
roseyman87
Dec 16, 2009 02:28 AM
reis713
Jan 25, 2006 06:47 PM
wakko
Jun 22, 2004 02:10 PM
wakko
May 30, 2004 08:08 PM
