two newbie questions: leasing and snow tires....
Old Feb 11, 2002 | 09:11 AM
Ptown's Avatar
New Member
Default two newbie questions: leasing and snow tires....
1. if i am currently leasing the vehicle, at any point during the lease can i pay for the entire vehicle? or do i have to wait until the full 36 months are up to then purchase the car?
2. the car manual says that factor installed tired and wheels cannot be used with snow-chains... i am assuming this means i will need to buy snow tires for the car then, since the chains cannot be used on the ones that came with the car, correct?
thanks for the help.
Old Feb 11, 2002 | 09:14 AM
Kris Hansen's Avatar
Head Cat Herder
25 Year Member
Default You can't use chanis not because of the tires, but because of the tight clearances in the front.....
suspension. The chains will come into contact with some very expensive bits under there, and that is not good. If you must travel into snowy areas, get some real snow tires, or at least, some VERY good aggressive tread all seasons.
Old Feb 11, 2002 | 09:16 AM
Just Gizmo's Avatar
Senior Member
Default Lease answer...
Yes, you may buy the vehicle at any time. Simply call the leasing company and ask for a "buyout". They'll tell you what you owe on the car.
Old Feb 11, 2002 | 09:17 AM
ex-quattro PETE's Avatar
AudiWorld Expert
Default answers....
1. You will probably have to pay a penalty for terminating the lease early, and then they will most likely let you buy the car, but don't expect a good deal on it.
2. Even with snow tires, I'm not sure if it's safe to put on chains. I've heard that there is very little space for them. Maybe if you get a smaller width tire, not sure. However, if you get a set of good winter tires, with quattro, you will probably not need the chains anyway.
Old Feb 11, 2002 | 09:23 AM
Ptown's Avatar
New Member
Default Re: Lease answer...
thanks
HiTEC
Dec 12, 2004 10:52 AM
BlueChipBMW
Dec 11, 2004 09:44 AM
supertran74
Nov 24, 2003 08:21 PM
screamin norwegian
Dec 17, 2002 01:01 PM
