Boost problems (con't)
Old Oct 31, 2000 | 05:12 PM
adam99rs's Avatar
New Member
Default Boost problems (con't)
I reset the ecu today by disconnecting the + battery cable for a couple minutes, then putting it back on and tighteneing it down. My radio settings were still there, but I had to reset the time/date. I let the car sit in the "on" position for 1 minute, then started it up, and let it idle another couple minutes.
Proceeded to drive home...dusted a Civic Si that kept "lurching on me" in the next lane. About 15 minutes into my drive, boost went away again. Mind you, there is still bost, but not nearly as much as before"it" happened......you just feel it.
I did some food shopping, got back in, and once again, all was fine. I am really nervous to goto the dealer for obvious reasons. This has got to be an electronic isue IMHO, not a hose issue, since it goes away after to restart the car. What can I do?
Anyone on LI own a VAG tool...are VW scan tools the same? I want my quicker S4 back!!
Also left a voicemail for Pete/Bob @@ Strat where I bought the chip.
Old Oct 31, 2000 | 05:15 PM
frank's Avatar
Default is this a 2000 or 2001?
just curious,
also for get the batterycable and try unplugging the ECU for 15 minutes to be sure the Flash memory crap has dumped out
Old Oct 31, 2000 | 05:21 PM
adam99rs's Avatar
New Member
Default 2000 with MTM chip....what "flash memory" do you mean (more)
I don't have any ce light either....weird.
Old Oct 31, 2000 | 05:23 PM
rao's Avatar
rao
Good luck - I think he means taht you need to deprive the ecu of power for a while to reset it
Old Oct 31, 2000 | 05:27 PM
frank's Avatar
Default maps are stored, like Rao said it takes a bit for the power to drain out and completely erase them
it's just a good starting point
to help diagnose the problem
RR's Avatar
RR
Flash memory does not need power to retain data....
Old Oct 31, 2000 | 05:28 PM
frank's Avatar
I know bad choice of words..... BOO!
Old Nov 2, 2000 | 06:29 AM
KevinH's Avatar
Junior Member
Bad gas and the ECU is dialing back the boost to prevent detonation?
 Pouria Savadkouei
 Michael S. Palmer
USATrade
Apr 15, 2011 04:26 AM
TTempted
Jun 7, 2006 10:19 AM
quattrorally
Nov 9, 2005 02:58 AM
Angel B7
Florida Discussion
Nov 4, 2003 03:46 PM
Bob W.
Jul 4, 2003 04:36 PM
