Diagnostics questions
Old Nov 1, 2000 | 10:34 AM
BaysideRS4's Avatar
Default Diagnostics questions
What should I make of the following readiness code status exceptions:
Oxygen Sensor Heater
Oxygen Sensor Monitor
EVAP Sys. Monitor
Catalyst Monitor
These were noted as failures or some other thing like incomplete or somethingorother.
Thanks
Old Nov 1, 2000 | 10:39 AM
rao's Avatar
rao
Default It depends - those tests won't even be run for some time after the chip is installed
They are only run under certain conditions. If they are marked failed there should be a corresponding code and a CE light.
Old Nov 1, 2000 | 11:18 AM
BaysideRS4's Avatar
Thanks
Old Nov 1, 2000 | 11:23 AM
frank's Avatar
Default another reason to swap ecu's a few days before a service appt.
it takes a few drive cycles for those readiness codes to go away.
if a dealer really wanted to find out if your playing the chip game. They would first look for a low power fault. and if that isn't there, then they can look at the readiness codes.
most dealers are too busy or lazy or uninformed to do this.
But there are some dealers who are jerks and seem to delight in voiding paying customers warranties evry chance they get.
lesson: be sneakier!
Old Nov 1, 2000 | 11:35 AM
rao's Avatar
rao
Default True, but readiness codes are also reset every time you check for codes using VAG-COM, VW-tool etc.
good legitmate reasons for the readiness codes to be not set.
Old Nov 1, 2000 | 11:57 AM
Richard Solomon's Avatar
Tech Guru
Default I thought the readiness codes were only reset if you CLEAR codes using Vag-Com/VW-tool...
I'm pretty sure the readiness codes aren't cleared just by reading DTCs.
Old Nov 1, 2000 | 12:02 PM
rao's Avatar
rao
You're right, but I hit the clear codes button by habit - tough crowd :-]
Old Nov 1, 2000 | 12:46 PM
Bichon's Avatar
Default You can do what the dealers are supposed to do during PDI, and "set readiness"
The Bentley CD-ROM has instructions about how to trigger all of those tests. At least one requires driving at highway speeds, but the whole suite of tests can probably be run in under 30 minutes.
 Pouria Savadkouei
 Michael S. Palmer
icks90
Jun 11, 2014 07:01 AM
LappS4
Nov 19, 2005 07:22 PM
XCCESS
Jan 16, 2005 10:24 AM
Jeremy Clarkson
13
Mar 14, 2002 08:26 AM
jason@s4.org (NS4)
May 7, 2001 05:16 AM
