Can you use the vag to re-calibrate the speedo for different size wheels?
Old Oct 22, 2001 | 03:01 PM
liquidforce's Avatar
Junior Member
Old Oct 22, 2001 | 03:10 PM
donp's Avatar
I've looked high and low for this... big goose egg over here.
Old Oct 22, 2001 | 03:14 PM
DrSmile's Avatar
Junior Member
Default If you could do that you could "calibrate" it to add no or less mileage...
I'm sure the DOT would have a major problem with adjustments like that.
Old Oct 22, 2001 | 03:18 PM
esfor's Avatar
Member
Default yah, but you have incorrect mileage when you have different diameter tires.
So DOT must require a way to calibrate....
Old Oct 22, 2001 | 03:20 PM
Mark P's Avatar
AudiWorld Expert
Tech Guru
Default true, but they could have %limitaions on it. You could just as easily get oversized tires right now
which would make you drive further than your odometer actually shows. If it was adjustable within the settings of what possible tires could reasonably fit on the car, it'd be cool. Of course, then I guess that opens up the window to hacking those %. As I recall, right now there is a one-time resetting of the odometer, but not something you can do through the VAG alone. It does not appear that anyone has hacked that, so I don't see why they couldn't do the above while feeling no differently about security risks. Probably just amounts to the fact that there's no major need for the function. You just put the damn right size tires on that Audi tells you and that's the end of the story! )
Old Oct 22, 2001 | 03:34 PM
Tostao's Avatar
Member
Was is a MB that had that function easily accessible?
Old Oct 22, 2001 | 03:57 PM
idealrides's Avatar
yep, just type in the size and whether they're new or used
am_ver
May 13, 2011 12:31 PM
CO AVANT
VAG-COM Discussion
Jun 28, 2005 11:49 AM
JerseyTT2
Mar 2, 2004 06:01 PM
ex-quattro PETE
Feb 7, 2003 07:28 AM
KenK in TX
Nov 21, 2002 08:28 AM
