Anyone using 235/45/17 S-03s on a lowered car? Any problems?
Old Oct 22, 2001 | 05:21 PM
BMr Etr's Avatar
New Member
Old Oct 22, 2001 | 05:24 PM
BMr Etr's Avatar
New Member
On stock wheels that is.
Old Oct 22, 2001 | 05:39 PM
Ted K's Avatar
Default I'm using 225/45 YR 17 on 17x8" wheels, but the car isn't lowered. No problems at all...
I know this isn't exactly what you were looking for, but figured I'd let you know anyway.
Old Oct 22, 2001 | 06:10 PM
idealrides's Avatar
Default 8" wide wheel is recommended for 235 tires, FYI
if used with stock wheels which are 7.5" you'd have excessive lateral rolling and mushy handling
Old Oct 22, 2001 | 09:43 PM
flying_low's Avatar
Member
Default Re: Anyone using 235/45/17 S-03s on a lowered car? Any problems?
I have Pilot Sports in that size on stock 17x7.5 with MTM lowered suspension and it works fine. I put some chalk on the suspension pieces to check for rubbing and not one mark. The speedometer is actually more precise on (was a little on the high side before).
Old Oct 22, 2001 | 10:13 PM
meem's Avatar
Elder Member
Default warning s-03's are *very* wide -- be careful!
the s-03's are noticably wider than most tires -- you will probably run into problems, especially if you're lowered. i'd stick with 225.
QTRdrifter
11
Feb 27, 2003 09:28 AM
AUDIOZ A4
May 12, 2002 11:44 AM
dekkard
Apr 15, 2002 10:05 AM
Gop-Dogg
9
Apr 15, 2002 09:07 AM
redy2mod
Wheels & Tires Discussion
Dec 7, 2001 09:21 AM
