The Race Store has agreed to refund my money...
It's bad enough when someone puts an intake on car in a dyno bay and claims increased airflow (with the hood open and none of the normal airflow that the stock system is utilizing) but to simply make a blanket and ludicrous claim about horsepower OBVIOUSLY without having tested it...there ARE actually laws against it.
I'm ALWAYS skeptical and that's why we did dyno day because I don't believe it unless I see it for myself. Go to Honda world and they SWEAR by those cold air intakes. They're UTTER BS, I've tested them on a race track with sophisticated timing equipment and they cause a MEASURABLE LOSS of performance over the stock system with ducting to the outside of the car. I'm sure if I boxed the CAI in carefully and cut holes in the car etc...etc...I could MATCH the stock intake but that crap is generally pure BS.
Your cars have turbos...think about that. They're electronically controlled and create boost...the whole IDEA of a intake is to "add air" to the engine to boost it like a form of supercharging but you are TURBOCHARGED...you aren't getting any more air than the turbos can force into the engine.
1. a coincidence that it worked
or
2. a carefully designed system that exactly matches the car.
In some cases on the board, #1 happens and occasionally #2 is at work here.
The Race Store product was generic and not tailored to ANY cars in particular. Note with the 996, if you increase intake air you get lean running and lose power...the ECU is "smart" enough to know exactly how much air it's SUPPOSED to have but not "smart" enough to adapt to too much "extra" air. To see any benefit on that engine, you need to chip the ECU to compensate. I'd guess that some intakes happen to match the chips that are on the car but the consumer doesn't really have any way to know which are which.
