K04 + DP + Milltek?...ou non?
right now im running milltek exhaust...but i was wondering with the DP's, would the millteks be flow enough for the 3'' piping? or would it be bottlenecking...
because i realize that a6's and s4's exhausts are totally different, i ddint know how anything effects stuff like that.
Thanks
1) Remove the rear mufflers and have an exhaust shop bend some pipes for ya and purchase some custom tips. This will increase sound dramatically.
2) Remove the center muffler and have an exhaust shop make some straight pipes for you. I do not recommend this because you will get a lot of drone at lower rpms, unless that's what you want.
Since the angle of the bends are not great, press bends will do if you cannot get mandrel bends.
3) Have an exhaust shop just create a custom exhaust for you. Again, the bends are not huge so pressure bends will be fine. You can run dual 3" through two bullet-shaped mufflers in middle and just pipes out the rear to some custom tips.
Maaan! I wish our S4s had your configuration, the custom exhausts I could create! 8^)
